Old 09-01-2010, 03:49 AM   #1
choleaoum
Member#: 255484
2010 EVO
Default Illumination is gone and the light fluctates..
Hey how's it going, I am having an issue regarding some electrical stuff on my WRX. The cluster for one works fine but the numbers & stuff won't light up when the headlight is on, the fuse was blown and I replaced it with another 10A. That was a no go, I'll probably check the clock/cluster area to see if any loose wires. That's really no biggie to me, but what is bugging me is that when the car is on the light dims on and off like it's fluctating. It gets bright..then dim..then bright again and it's just a cycle. Any clue to what could cause this? Everything looks grounded too..
choleaoum is offline   Reply With Quote
Old 10-29-2010, 02:26 PM   #2
choleaoum
Member#: 255484
2010 EVO
bump, i'm going to check my doors because i think the illumination is also linked up to that.
Old 11-10-2010, 07:58 PM   #3
yc07
Member#: 228695
did you solve the problem with the cluster. i have the same thing happen to me?
yc07 is offline   Reply With Quote
Old 11-11-2010, 04:19 AM   #4
choleaoum
Member#: 255484
2010 EVO
nope i have not yet.. it might be my battery or alternator, i'm going to try to install a grounding kit.
Old 11-11-2010, 11:10 AM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The dash light trouble may be due to a faulty illumination control module, especially since the fuse was blown.
The pulsing lights are most likely due to bad diodes in the alternator. When some of the diodes go bad the charging voltage has a higher ripple voltage due to the missing phases. The ripple voltage makes the lights pulse.
Old 11-12-2010, 01:37 PM   #6
choleaoum
Member#: 255484
2010 EVO
Would a bad alternator cause stumbling idle? The idle remains constant but the engine feels rough still. Where is the illumination control module? Everytime I replace the fuse, it pops and I can't find any shorts!
n/a "limp mode" is gone....now the engine is stalling out... ThaPuertoRican15 Normally Aspirated Powertrain 15 09-01-2010 05:22 PM
Everyone is gone for the weekend and general has invaded. Drink Off-Topic 42 05-04-2009 08:55 AM
Bush is gone, and the Daily Show is still t3h Funnay SQ3.0dotJP Off-Topic 20 04-17-2009 11:41 AM
The WRX is gone and my Story gotsol South East Region Forum 28 06-04-2008 01:53 AM
The Playmate Thread is gone, and crowbar's in TO... rogue Off-Topic 21 12-09-2003 11:33 AM
