Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Old 01-09-2011, 04:48 PM   #76
ScoobieNoob
Member#: 267079
2011 WRX HB
you should post some photos/videos from inside the cabin with the final product installed. i would like to see the blockage of the stock gauges and whatnot from the drivers angle. no big deal if you have to lean a little to the side to make out the stock gauges but i'd just like to see the angles. thanks in advance
ScoobieNoob is offline   Reply With Quote
Old 01-09-2011, 05:03 PM   #77
SMY
Vendor Sales Rating: (4)
Member#: 256505
2013 STI Sedan
Satin White Pearl
I have them. check my website. Installed with MACRO shots. to show how the texture matches so nicely.
www.smyclustermaker.com
as for the blockage.
ALMOST nothing i am talking about 5% that about tops to almost 0% depending on how you sit.
site has all the pictures even straight on showing you my exact view.
SMY is offline   Reply With Quote
Old 01-09-2011, 05:15 PM   #78
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
Old 01-09-2011, 05:16 PM   #79
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
Old 01-14-2011, 04:02 PM   #80
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
Every order has shipped out. Visit sites updates page for more information.
Please everyone when you get your order please take your time opening it. It is packaged very well. Please do not use a knife to cut the tape. And if you get a chance take some pictures post a review on the Interior Section of this forum for others to see.
Thank You SOOO SOOO Much.
Yanev
SMY-ClusterMaker
Old 01-14-2011, 04:17 PM   #81
BlueSubaru22
Member#: 179474
08 STi Stg 2
WRB Pearl
How hard is this going to be to install?
BlueSubaru22 is offline   Reply With Quote
Old 01-14-2011, 04:20 PM   #82
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
Super Easy... Actually the easiest thing you can install.
Super easy READY!!!
Step 1 - Grab upper right inside corner with left hand.
Step 2 - Grab upper right outside corner with right hand.
Step 3 - Hold TIGHT...
Step 4 - Pull with a JERKING motion. (towards driver seat) not side to side
Step 5 - The Clip should have poped out of pocket.
Step 6 - Now grab upper left inside corner with your right hand.
Step 7 - Grab upper left outside corner with left hand.
Step 8 - Repeat steps 3,4,5
Step 9 - Now do the same around the cluster.
Follow that and you can't break anything. Clips are really strong BTW. and there are no screws only male female clips.
Old 01-14-2011, 04:42 PM   #83
Matt_H
Member Sales Rating: (29)
Member#: 107000
2015 BMW X1
Ordered
Matt_H is offline   Reply With Quote
Old 01-14-2011, 04:51 PM   #84
BlueSubaru22
Member#: 179474
08 STi Stg 2
WRB Pearl
I like that no tools required.
Old 01-15-2011, 10:53 PM   #85
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
This is for everyone so please READ....
The pods on my Dual Gauge Pod were designed to be 2mm larger then the gauge. This is so because of the following. Gauges in an enclosed space such as a pod have no ventilation. So a solution to this problem is a slightly larger pod. So to fit gauges in my pod all you need is the following
A small strip of double sided tape, can be found in any hardware store, CVS, Duane Reade, etc...
Put this strip of double sided tape around the gauge ONLY ONCE. Then put the gauge in the pod. PROBLEM SOLVED.
Any problems please let me know
Yanev
[email protected]
Old 01-17-2011, 09:56 PM   #86
eduSti
Member Sales Rating: (9)
Member#: 136503
08 STI
Installed the cluster and Im soooo excited of how everything came out. heres two pics from my sitting perspective (6' tall with pretty long legs), NOTHING, and I mean NOTHING is blocked......
The following two pics are with the seat ALL the way back, if your frekeashly large......i mean like 7' tall and have to put the seat all the way back, a small portion of the engtemp gets blocked but you can lean a bit and look around it
Taking the stock suround is easy in words but MAN you gotta pull hard on that sucker, installing the new one is a breeze........SUPER EASY.......fitment is excellent, the only thing that took some time was finding a way to put the gauges in the cups, I had some 1.14mm double sided tape which I used once around the back and it was still a little loose, two times around was to thick.......what I ended up doing was once around and then three small peices evenly spaced all the way around. Hope this helps.......also if you guys want to see more pics let me know and Ill take some.......
There is a rectangular hole underneath the stock cluster in the left hand side, I routed the wires for oil press gauge through there and made a similar hole on the right side for the boost gauge. You could bring all wires in from the left and then rout them underneath the bezel but I felt that with a hole on each side the install would be easier....I used a hot blade to make it.
On another note if your gonna install the maddad gauges and dont want to have a birds nest in your fuse box let me know and Ill tell you what wires to tap into.
THANKS SO MUCH YANEV!!!
eduSti is offline   Reply With Quote
Old 01-22-2011, 09:31 PM   #87
phoenix14
Member Sales Rating: (10)
Member#: 263656
2008 WRX Sedan
Hey Yanev, I am having issue getting my AutoMeter Boost Gauge to set back and flush in the back of the cup. It is the mechanical style so where the vacuum hose goes into the gauge is too long preventing me from further putting the gauge in the cup...what would you suggest to remedy this outside of purchasing new electronic gauges...
If you look at your post #79 in the picture with out the gauges installed it is hitting the tab behind the cluster...could I maybe cut those tabs out to make it work?
phoenix14 is offline   Reply With Quote
Old 01-22-2011, 09:51 PM   #88
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
you can cut those tabs in the back. its for the stock cluster. you really don't need those. email me if you have a problem. maybe i can talk you through it.
Old 01-23-2011, 02:00 PM   #89
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
Bump to top
__________________
Yanev
SMY Performance
Old 01-25-2011, 12:25 PM   #90
moreno20
Member Sales Rating: (13)
Member#: 228965
2012 STI Sedan
Plasma Blue
My girlfriend just ordered mine a couple of days ago for our anniversary...but she thinks I don't know...thank you Internet Browsing History...lol...Can't wait to get it.
moreno20 is offline   Reply With Quote
Old 01-26-2011, 01:48 PM   #91
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
15 CLUSTERS REMAIN from the 1st Batch of Clusters.Another Batch of Clusters are in the process of being made. Expected date for next batch delivery is Febuary 2nd.Due to the INCREASE in manufacturing, packaging, fuel and labor costs the price of each Cluster has increased to $150.00 USD for each CLUSTER.
I WILL CONTINUE TO SELL THE REMAINING 15 CLUSTERS AT THE ORIGINAL PRICE OF $125, UNTIL THEY SELL OUT.
I will keep updating the website with how many clusters are left.
Old 01-27-2011, 12:21 PM   #92
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
8 left at current pricing. Next batch arriving soon
Old 01-28-2011, 07:27 PM   #93
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
SHIPPING PRICES REDUCED ABOUT $8.
For some reason FedEx is giving me a discount. DAMN NICE.
I decided to PASS IT ALONG TO ALL BUYERS...
ALSO
included with every order are special rubber bands to hold your gauges in pod nice and tight. and a small roll of double sided tape.
Old 01-29-2011, 03:24 AM   #94
WRBear
Member Sales Rating: (5)
Member#: 207171
2009 WRX
Nice looking cluster!
May have to pick one up if I acquire a 52mm wideband.
Have the SPT boost, but I think my need goes past the limit :x
WRBear is offline   Reply With Quote
Old 01-31-2011, 08:50 AM   #95
moreno20
Member#: 228965
2012 STI Sedan
Plasma Blue
What can I say? This gauge pod is Bananas
Fits 200%. Feels stronger than the stock one. Yes...AEM gauges felt loose at first...1 full turn of 3m Double sided tape and they fit perfectly. Wise decision on making a little wider for easier removal of the gauges in the future if necessary.
If u use double sided tape, do not remove the exposed stick on part. If you do...u may have a really hard time taking the gauges off if u ever need to, since the tape will now be glued to the inside wall of the pod.
Sorry for the night shots and cell phone pictures. Will post better ones later.
Thank you again Yanev.
Old 02-01-2011, 05:38 PM   #96
xluben
Member Sales Rating: (17)
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here is how I originally did the install. About 2 feet of thin, double sided tape, with one side of backing left on. I would suggest doing it this way and simply friction fitting, instead of using the sticky side of the tape to hold it in. Any tape should work for this. Electrical tape would probably be perfect.
And here is a picture of the bands that are now included with the gauge pod. They are just normal rubber bands like you'd get on your vegetables at the grocery store. They fit very tightly around the gauge and I needed 2 on each side to hold them in place. Rubber, so there is a lot of friction, so they hold the gauges in well. Good simple solution and very nice of Yanev to include them!
xluben is offline   Reply With Quote
Old 02-02-2011, 12:47 PM   #97
kh15
Member Sales Rating: (25)
Member#: 132400
PLEASE make a cluster pod for the 02-07 guys, the autometer ones suck!
kh15 is offline   Reply With Quote
Old 02-02-2011, 12:51 PM   #98
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
I would like to but do not want to reach into someone else's cookie jar. If you know what I mean.
__________________
Yanev
SMY Performance
Old 02-02-2011, 01:35 PM   #99
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
2nd batch is in. Back in business.
SMY-ClusterMaker
__________________
Yanev
SMY Performance
Old 02-03-2011, 02:35 PM   #100
SMY
Member#: 256505
2013 STI Sedan
Satin White Pearl
new store design on website, new pictures etc... check them out.
also click on the picasa link to see more pictures
__________________
Yanev
SMY Performance
08 STi and 09 Forester Release Party! AT Frederick Subaru 2/13/08 FrederickSubaru Mid Atlantic Impreza Club -- MAIC 12 02-14-2008 10:35 AM
02 WRX V7 STi & 02 WRX stock suspension (struts, coils, & tophats fully assembled) deadeye Suspension/Brakes/Handling 2 01-29-2008 12:25 AM
2008 Subaru WRX and STI , what numbers would .. CALI07TR General Community 1 03-31-2007 08:02 AM
FS/FA: AZ WRX & STI & 2.5 RS Praxis Adjustable Suspension 1LapGTi Private 'For Sale' Classifieds 2 10-19-2004 11:32 AM
02' WRX 5MT drivetrain (complete) & EJ20 & STi & misc. downshift1 Private 'For Sale' Classifieds 34 11-17-2003 10:58 PM
