Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 09-01-2010, 12:21 PM   #1
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
Default Rear wiper issue on 97 OBS
hey guys, my rear wiper wont turn on. the fluid will squirt but the arm won't move.
bad motor?
any thoughts?
taylorjonesphoto is offline   Reply With Quote
Old 09-01-2010, 05:14 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If the fuses are ok then there may be a broken wire in the top of the hatch door.
Cougar4 is online now   Reply With Quote
Old 10-26-2010, 04:58 PM   #3
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
when i turn the switch on i can hear a click from back there, i think it's getting power. i just assume the motor is shot or has seized.
Old 10-27-2010, 12:04 AM   #4
avk
Member#: 17252
'06 WX8
59E
What you are hearing could be the relay, located below the right taillight. So the wire running into the door could still be broken.
It's easy to remove the trim panel and do some testing with a meter.
avk is offline   Reply With Quote
Old 10-27-2010, 08:13 PM   #5
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
Just tested the connection to the motor and its getting adequate power. So I'm guessing I need to just swap out the motor?
Old 10-28-2010, 03:42 PM   #6
avk
Member#: 17252
'06 WX8
59E
If I remember, there should be 12 V at two wires. One is used for "parking" the wiper arm. Also make sure the ground wire isn't broken, I believe it also runs through the sleeve by the hinge on the right side. If everything checks out,
the motor has to be bad.
Old 10-28-2010, 08:58 PM   #7
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
any chance the motor is running but the connection to the wiper arm is loose / stripped? Happened to me once on a front wiper...
TRH_legacy2k is offline   Reply With Quote
Old 10-29-2010, 12:04 PM   #8
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
there is a possibility of that however i cant hear anything audible coming from the motor. i would suspect if it were stripped/jammed i would hear some sort of noise.
Old 10-30-2010, 01:53 PM   #9
Cougar4
Member#: 53443
Winestone
Since you say that power is getting to the motor then there may be an open connection in the motor somewhere so replacing it should get it going again.
Old 11-01-2010, 03:17 PM   #10
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
the lead tech at my local subaru specialty shop thinks the problem is more than likely the wiring running from the body to the hatch. he says replace the wiring in that spot and then see if it works.
Old 11-01-2010, 04:50 PM   #11
Cougar4
Member#: 53443
Winestone
Before replacing the wire I suggest you first check to see if voltage is getting to the motor by either using a test light probe or voltmeter. If that test shows that no voltage is getting to the motor then the next thing to check is the wiring. It very well could be broken where it flexes at the joint.
Squeak in right front on 97 OBS... Axle? nperkins Transmission (AT/MT) & Driveline 9 06-18-2010 08:27 AM
WTB: Rear disc conversion for 97 OBS ncskier96 MAIC Private Classifieds 0 09-03-2006 06:39 PM
04?05?06? STi struts on 97 OBS?? fourstrokephysics Subaru Conversions 3 06-16-2006 01:11 PM
where can i get rear spoliers for a 97 OBS? christoph1371 Interior & Exterior Modification 3 06-13-2002 02:16 PM
