Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 09-01-2010, 04:18 PM   #1
kyledupreez
Member#: 248479
2000 sti'ish outback
and something german
Default What PSI do you run?
So I was putting air in my tires today, and thought maybe I'm putting too much in? So I thought I'll see what everyone else runs. So I'll start with mine
Max: 50psi (says on tires)
I run: 42-45psi.
Should you use run different psi in winter then summer? Or does it not make that much difference?
Thanks,
Kyle
kyledupreez is offline   Reply With Quote
Old 09-01-2010, 04:47 PM   #2
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Every tire is different and recomends different tire pressure, that being said I usually run 5-10 less than max for dd and a little less than that for a grippier feel
06HAWKMAN is offline   Reply With Quote
Old 09-01-2010, 05:03 PM   #3
kyledupreez
Member#: 248479
^ that's what I do. I just wondered if maybe I was doing it wrong. Ha like my dad told me that when I got my first car and I never questioned it.
Old 09-01-2010, 05:44 PM   #4
WillieBill
Member#: 14994
wow, that seems awfully high. Look at the sticker in the door frame of your car. For example, on the wrx it recommends something like 32F/29R with 16" wheels, and 33F/32R on 17". I generally run what the car company recommends.
As for summer vs winter, just check and fill them because they lose pressure as the temp goes down.
WillieBill is offline   Reply With Quote
Old 09-01-2010, 05:52 PM   #5
kyledupreez
Member#: 248479
Well my tires say max is 50psi and I put it at 42psi this morning. I've had them at 45psi but the pump I was using was taking too long and I got impatient. On my jeep I run the recommended psi I was 36psi and I went through a set in 10,000 miles (supposed to last 30,000) and since then I run 5-8 under the max psi and wear seems to better. May not be as grippy. But for a dd I don't really want sticky. The harsher ride is the down side.
Old 09-01-2010, 06:02 PM   #6
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
look in your door jam, that's what I run
medamullet is offline   Reply With Quote
Old 09-01-2010, 06:03 PM   #7
kyledupreez
Member#: 248479
^Even on your race tires?
Old 09-01-2010, 06:03 PM   #8
WillieBill
Member#: 14994
the question isn't really what is the max possible pressure in the tire, the question is what does the car manufacturer recommend for their vehicle. If you overinflate tires, they will wear faster in the middle as they balloon out. The anecdotal evidence on the jeep probably has more to do with the brand and age of tires, awd/4wd system, driving habits and the like than specific pressure.
I believe that the STi is supposed to have 36F/30R, so I would stick closer to that, maybe 38F/32R if you want to bump it up a bit.
Old 09-01-2010, 06:06 PM   #9
WillieBill
Member#: 14994
Here is some info from tirerack on under/overinflation.
Old 09-01-2010, 06:09 PM   #10
fourmicah
Member#: 128760
2015 STI
On my STI and WRX I always ran 35-36 PSI. The reason being, at 32 PSI the tires felt soft and washy when I went around corners. You could feel the tire roll on the sidewall because the tire pressure is lower. I've never run the tire pressure as high as 42 PSI, just because I never seemed to see a benefit of doing so. At an event or track I could see the benefit, but not on the street. For me there was a noticable difference between 32 and 36 PSI in terms of feel. I decided to leave it there and the wear was still on par with the warranty and they didn't wear any quicker.
fourmicah is offline   Reply With Quote
Old 09-01-2010, 06:10 PM   #11
kyledupreez
Member#: 248479
^ I'll read that tonight. Busy doing "homework" seems everyone says run recommended I was wrong! haha =( possibly...
Old 09-01-2010, 06:13 PM   #12
WillieBill
Member#: 14994
that's why you ask on a car forum!
Old 09-01-2010, 06:33 PM   #13
Euclid
Member#: 41846
both 05 LGT, 08 STI
black and white
I usually run 2 psi up from what the door placard says. So on my Legacy I run 36f/34r, and 35f/34r on the sti.
Euclid is offline   Reply With Quote
Old 09-01-2010, 06:42 PM   #14
kyledupreez
Member#: 248479
so my next question is why less on the rears? i know the fronts do the steering, but its awd car, and if you wanted equal wear wouldnt you run the same? or is the way i understand tire wear skewd?
Old 09-01-2010, 06:46 PM   #15
soundsofsnow
Member#: 230039
94 Miata
come at me bruh
I run 45 psi. Stretched. Low profile. And stiff suspension. Otherwise I'd ruin a rim.
soundsofsnow is offline   Reply With Quote
Old 09-01-2010, 07:12 PM   #16
WillieBill
Member#: 14994
I believe it is because of the weight of the engine in the front.
Old 09-01-2010, 07:59 PM   #17
08WhiteRex
Member#: 187453
2012 Mulletmobile
On Slicks you go out on track, cold, at around 24 psi.
08WhiteRex is offline   Reply With Quote
Old 09-01-2010, 09:25 PM   #18
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
38psi on the street for me.
on race tires i run about 22psi
bhhamblin is offline   Reply With Quote
Old 09-01-2010, 10:47 PM   #19
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
32/32 driving on the roads, as are recommended by the factory, and I get the best response from the tires for street driving. I stagger them to 36F/38R at autox. Cold measurements BTW.
Anub1s is offline   Reply With Quote
Old 09-01-2010, 11:28 PM   #20
kyledupreez
Member#: 248479
^ id assume that would be a given. althought when you assume... exactly. haha wow really low 20s for slicks? what do they get up to once you have heat in them?
Old 09-02-2010, 12:10 AM   #21
08WhiteRex
Member#: 187453
2012 Mulletmobile
Adjust it to 32 optimally.
Old 09-02-2010, 12:15 AM   #22
ashergrey
Member#: 174533
0694 WRXLtd/LegWagon
WRB/Pure White
This has been my experience as well. Sweet spot for street on my WRX has been right around 35.
ashergrey is offline   Reply With Quote
Old 09-02-2010, 09:37 AM   #23
kyrosnick
Member#: 169915
2007 Legacy
Grey
+1
Make sure you got an accurate gauge. My brother killed a set of tires. His gauge was +5psi off. So he wanted 35psi and was running 40psi. The centers went bald quick.
My honda and vette both say 30psi cold front and rear so that is what they get.
kyrosnick is offline   Reply With Quote
Old 09-02-2010, 11:49 AM   #24
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Depending on the tire, but my street NT-05's i run 36 front 34 rear and when i run them on track i run 28 front, 26 rear. My snow tires i run usual about 35 all around and when i had track tires i would run 24 all around. Different tire manufacturers and sizes seem to make a big difference. Usually when I stay close the Subaru's recommended pressure they will wear good.
aclver1 is offline   Reply With Quote
Whats psi are you running on stock turbo killichnakropf Newbies & FAQs 7 05-27-2010 01:13 PM
What psi do you run in your tires? gtbensley General Community 61 06-01-2008 07:35 PM
what psi are you running on stage 2 wrx the real suby dude AccessPort 14 05-21-2007 02:59 PM
What psi are you running in your RE92s? Enkidu Tire & Wheel 21 11-12-2003 05:59 AM
Minnam Turbo Owners - What psi are you running? Sean McElderry General Forum Archive 7 06-16-2000 05:01 AM
