Old 09-02-2010, 12:57 AM   #1
alejo
Member#: 170081
2004 2.5RS
blue
Default radio and clock working funny
I have a 99 OBS. yesterday, my radio turned off, and my clock reseted, as well as my odo. My last radio was working fien and then it blew out. I`m worried that the same can happen to the new one. any ideas? ah, for the time being, I took off the radio fuse. thanx
alejo is offline   Reply With Quote
Old 09-10-2010, 12:28 AM   #2
alejo
Member#: 170081
2004 2.5RS
blue
I also noticed it detects a door open and the dome light doesn`t work. the clock resets to 1:00 everytime I stop the car. It has been raining lately, does that have something to do?
Old 09-10-2010, 09:57 AM   #3
littlewhitewagon
Member#: 103068
11 STI sedan
Check the fuse box.
littlewhitewagon is offline   Reply With Quote
Old 09-10-2010, 11:28 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There could be a bad connection to the memory power circuit located in the fuse panel under the hood. Also you might try cleaning the battery to chassis grounds along with the battery connections. You don't have a danger of damaging the radio unless the alternator is putting out excessive voltage but it sounds like the regulator inside it is ok. For the dome light check the switch position on it and make sure it isn't in the OFF position.
Old 09-10-2010, 11:42 AM   #5
alejo
Member#: 170081
2004 2.5RS
blue
Originally Posted by littlewhitewagon View Post
Check the fuse box.
which one? or both? jaja what do I have to check?
Where exactly is the memory power circuit? The dome light doesn`t work in any of the 2 on positions.
Old 09-10-2010, 02:45 PM   #6
littlewhitewagon
Member#: 103068
11 STI sedan
Always check both, but based on your symptoms, I think the one in the engine bay is blown. Why wouldn't you check anyways?
Old 09-11-2010, 12:05 AM   #7
alejo
Member#: 170081
2004 2.5RS
blue
I removed all the fuses and they are fine. but now it i working! this is really odd...
Old 09-11-2010, 06:03 PM   #8
Cougar4
Member#: 53443
Winestone
There is either a bad connection somewhere, possibly near the fuse panel, or you may have mixed the fuses up if you removed more than one at a time and one of the fuses is really bad. If something else now fails to work then you have a bad fuse. They can be easily mistaken for good ones.
Old 09-11-2010, 09:01 PM   #9
alejo
Member#: 170081
2004 2.5RS
blue
I`d go with the bad connection. I took them one at a time. Today it has worked real fine,I`ll keep you informed if it fails. Thanx
Old 02-15-2011, 01:00 PM   #10
alejo
Member#: 170081
2004 2.5RS
blue
it happened again!! what could it be?
Old 02-15-2011, 01:18 PM   #11
littlewhitewagon
Member#: 103068
11 STI sedan
Check and clean the connectors at the fuse box and replace the fuse with one of the same value.
Old 02-15-2011, 01:24 PM   #12
alejo
Member#: 170081
2004 2.5RS
blue
What fuse exactly should I check?
Old 02-15-2011, 02:19 PM   #13
99SUS SFD
Member#: 190424
2007 Impreza 2.5i SE
Urban Grey Metallic
Whatever fuse is allocated to the problematic areas. ie. the fuse for the clock or stereo. It should be outlined on the fuse box cover.
99SUS SFD is offline   Reply With Quote
Old 02-15-2011, 05:03 PM   #14
alejo
Member#: 170081
2004 2.5RS
blue
It worked! it was only a burned fuse. thanx a lot!
key ring light, radio and clock are not working moose00015 Newbies & FAQs 5 03-23-2010 11:29 AM
fs: oem radio and clock out of my 05 sti rathead Interior/Dressup/Audio & Security 2 10-12-2009 06:45 PM
Radio and clock stopped working. Help!!! 02turbosuby Electrical & Lighting 3 11-30-2006 01:13 PM
radio and clock BOXER28 Electrical & Lighting 1 04-07-2006 07:47 PM
Radio and clock not working after cluster install jdm_wrx Electrical & Lighting 1 12-12-2005 03:56 AM
