Old 07-23-2010, 09:48 PM   #1
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Default Congratulations Tino !! Nasioc's Top Scoob 019 !!
This has been a work in progress over the last five years, I bought the car brand new in 2004 after trading in my mildy modified WRC blue MY99. I was determined to keep it standard but this didnt last long at all and i found myslef slowly morphing into many guises from when it left the showroom floor. It first started with simple engine bolt on modifications like exhaust, turbo and intercooler to gain more power over standard, but then improvements were always one step away to aim for higher power levels and better handling.
The last two years has seen the most modifications completed on the car. This included the biggest step of upgrading from a stock 2.0ltr STI engine to a purpose built and engineered 2.5 ltr STI engine, with large rotated turbo setup and aftermarket Motec engine management system. The reason for the length of time is primarily due to the fact that alot of research both over the internet and discussion with people and workshops has taken place. Nearly every single nut and bolt in the engine and ancillaries has been either changed to better off the shelf items or complete custom fabrication which has been engineered such as the custom billet aluminum intake manifold, Aluminium V-mount setup to custom aluminum resivoir tanks.
The car has been built primarily for drag and large track combinations. The engine has a relatively large garret turbo which has two different sized rear housings the bigger one for drag applications and smaller rear housing for track setup. Headwork that includes camshafts, valves, springs and retainers have also been changed so that the engine can be revved out to 8500 rpm to allow for a larger useable power band for track applications.
Interchangeable suspension and diff settings also allow the car to utilize both drag and track combinations.
This car was never built to be a show car, but one that would see apart from the occasional drag run, alot of track work and targa events. Apart from improvements in suspension and power, there have also been custom cooling enhancements, such as more efficient raditator and V-mount intercooler setup to installation of power steering and oil coolers to ensure that oil levels stay at normal operating levels.
The engine bay appearance was not setout on purpose to turn out into a show piece. But once the engine was out i decided to get the engine bay shaved by Beyond Custom removing the wiring loom from the firewall and re-routing the loom out of sight. It is very hard to make pretty a subaru engine bay due to the messy layout, but i think using alot of custom parts has enabled wiring and non-functional parts to be hidden and removed from sight. Then there was the extended time and headache to find and deliver the very rare 1/600 made subaru STI s203 Carbon backed Recaros which came from an actual subaru s203with build number 462.
In the end the car has turned out to be multi-taskable, with the addition of complete interior retrim in alcantra material with carbon fibre trim and S203 limited edition carbon fibre racing seats and turned into a daily driver, show car, drag racer and circuit racer.
it seems though the build may never end as there are still many improvements that i want to do before i can be completely satisified..
Here is a link to my NASIOC threads:
http://forums.nasioc.com/forums/show....php?t=1470621
http://forums.nasioc.com/forums/show....php?t=1989479
Photos taken by Rick McDowel, heres a link to his blog:
http://www.facebook.com/#!/photo.php...15277915153388
ENGINE
2.5ltr STI semi-closed deck block.
Complete CNC close Deck of Subaru block.
Machined to suit darton Ductile Iron Flange Sleeves.
ARP case bolts.
PBMS 14mm high tensile head studs.
STI 2.5ltr crank. Machined and balanced. Cross drilled for better oiling of bearings.
Custom 99.5 mm CP pistons.
Pauter rods.
HEADS
2.0Ltr AVCS Big port heads.
CNC grind to custom head ported map and finish hand polished to suit 2.5ltr bore.
Cosworth Billet 278/274 AVCS Camshafts.
Cosworth inconnenl 1mm oversize exhaust and inlet valves.
PBMS exhaust cam wheels.
ASSOCIATED ENGINE BAY PARTS
Custom fabricated and mounted aluminium radiator tank.
Custom fabricated and mounted power steering tank.
Custom fabricated and mountedwindow washer.
Custom fabricated and mounted coolant overflow.
Custom fabricated and mounted brake assembly.
Custom fabricated and mounted clutch reservoir.
Custom Mocal Power steering and engine oil cooler.
TURBO SETUP
Polished Garrett GT40R twin scroll turbo 1.06 rear housing HP ceramic coated.
Custom low mount turbo manifold IDA 44mm which sits underneath the engine in a twin scroll configuration. True twin scroll turbo manifold which merge as twin pulses at collector.
Dual tial 44 mm V-band external waste gates.
Custom 3.5" v-banded stainless steel dump pipe.
Custom 4" v-banded exhaust with SBM 4" muffler.
INTAKE
Billet 70mm single throttle body with custom aluminium reverse throttle linkage.
Custom billet aluminium reversed mount intake manifold.
Custom V-mount intercooler/radiator setup.
Custom reversed carbon fibre intake intercooler piping.
FUEL SYSTEM
Custom carbon fibre in boot fuel system.
2 x Walbro in tank 265l/ph fuel pumps feeding a 5ltr stainless steel surge tank by -8an teflon braided lines to bosch x2 044 fuel pumps.
Dual custom billet fuel rails with 8X WRX decap top feed injectors.
Custom billet aluminum fuel distribution block running 8X Injectors with Twin SARD Fuel Pressure regulators.
IGNITION
MOTEC M800 plug and play ECU.
Re-wired ecu engine harness.
DCCDpro DCCD diff controller.
DRIVETRAIN
Subaru 05 STI 6-speed DCCD.
Custom modified Tilton twin plate 215 mm carbonetic clutch.
Cusco front plated and RZ rear plated diff.
Ohlins competition PCV coilovers height/damper/angle adjustments.
STI Brembo 6 pot brakes.
STI RA-R braided brake lines.
Brembo STI RA-R slotted rotors front and DBA4000 rear.
Brembo STI RA-R front and DS2500 brake pads rear.
5x114.3 complete hub conversion swap.
MSI adjustable lateral links.
MSI rear subframe.
MSI PSR kit and castor links.
MSI rear 23-25mm adjustable swaybar.
Whiteline front NA 22mm adjustable swaybar.
Cobb heavy duty swaybar mounts.
Cobb front and rear spherical links.
EXTERIOR
White 18x8.5 +30 Enkei RCT4 rims.
Genuine STI centre caps.
Dunlop Direzza R compound r specs 245X40.
Genuine STI titanium strut tower bar.
Genunine STI front lip.
Genuine S202 carbon fibre rear spoiler .
Genuine STI RA roof vent.
WRC carbon fibre mirrors.
Custom mounted WRC bonnent vent.
Custom carbon fibre bonnent vent shroud for custom WRC V-mount.
Custom shaved engine bay and engine loom tuck.
Custom mounted Braille lightweight battery in the front gaurds.
Custom mounted ABS unit in the front gaurds.
INTERIOR
Genuine subaru STI S203 limited (Number 462/600) front seats and rear seats.
Custom alacantra wrapped dash.
Custom alcantra wrapped interior panels and headliner.
Custom carbon fibre interior dash and interior pieces.
Motec ADL sports Data logger dash and Motec Shift lights with custom carbon fibre housing.
Pioneer DVD/Navigation touch screen display.
Performance:
535 WHP@1.8 bar on 93 pump
604 WHP@1.8 bar on VP109
11.3@134 mph on old setup
tino is offline   Reply With Quote
Old 09-02-2010, 11:35 AM   #2
Ferg
"Tekeli-li! Tekeli-li!"
Member#: 14145
'02 WRX
Cars? Stupid!
welcome to the front page sir!
Ferg is offline   Reply With Quote
Old 09-02-2010, 11:38 AM   #3
anthony_delprete84
Member#: 88254
very nice
anthony_delprete84 is offline   Reply With Quote
Old 09-02-2010, 11:43 AM   #4
wrath1517
Member#: 193723
2002 RS STI HYBRID
Sick!
wrath1517 is offline   Reply With Quote
Old 09-02-2010, 11:44 AM   #5
MSI
NASIOC Manufacturer
Member#: 95419
Sweet
-mark
MSI is offline   Reply With Quote
Old 09-02-2010, 11:46 AM   #6
KinkiKowBoi
Member#: 245358
well very done sir!
KinkiKowBoi is offline   Reply With Quote
Old 09-02-2010, 11:47 AM   #7
JBravo920
Member#: 73420
2002 Toyota Tacoma
& 10' Kawasaki Vulcan 900
Gorgeous and usable in every aspect! Very well done!
JBravo920 is offline   Reply With Quote
Old 09-02-2010, 11:49 AM   #8
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Just WOW. You did a lot of the mods I want. Can I ask for some more pics of interior. Curious to see seats(front and rear) and headliner.Also like the door cards. Want to see how everything matches up.
talvai is offline   Reply With Quote
Old 09-02-2010, 11:54 AM   #9
changd123
Member#: 233794
'09 Stage I, WRX
Lightning Red
wow!
congrats! and great work
changd123 is offline   Reply With Quote
Old 09-02-2010, 11:54 AM   #10
mayoke
Member#: 243848
2004 Imprezza WRX
Just beautiful!
mayoke is offline   Reply With Quote
Old 09-02-2010, 11:57 AM   #11
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
That's by far the nicest Subaru I've ever seen. You can tell the owner knows what parts are the best and wants perfection. This is Subaru perfection!
RealStreet is offline   Reply With Quote
Old 09-02-2010, 11:58 AM   #12
Novtec1
Member#: 13641
08 Audi RS4
03 SY WRX (DAILY)
damn that is SICK..... mad props on that build man.. excellent job
Novtec1 is offline   Reply With Quote
Old 09-02-2010, 12:00 PM   #13
Btortorelli
Member#: 196913
04 STI
That thing is so clean!!!
Btortorelli is offline   Reply With Quote
Old 09-02-2010, 12:02 PM   #14
kookaburrabomb
Member#: 145297
07 2.5i
Keeping it real back home!
kookaburrabomb is offline   Reply With Quote
Old 09-02-2010, 12:04 PM   #15
allsubaru83
Member#: 60122
2008 M5
Space Grey
Hot DAMN!!! That car is gorgeous.. Congratulations.
allsubaru83 is offline   Reply With Quote
Old 09-02-2010, 12:08 PM   #16
frozie
Member#: 215927
05 JDM Swapped
V8 Spec C EJ207
Congratulations to a excellent put together car in every aspect!
frozie is offline   Reply With Quote
Old 09-02-2010, 12:10 PM   #17
digitaljigga
Member#: 132451
03 WRX
Default Simply Beautiful
Very Impressive Sir.
Congratulations on a very well thought out build. I admire all of the custom fabricated components.
Any chance you will be willing to share specifications of the intake, and turbo manifold?
Again BEAUTIFUL and very worthy of the front page!
Job well done!
digitaljigga is offline   Reply With Quote
Old 09-02-2010, 12:10 PM   #18
coolblue05
Member#: 39169
2005 STi, s2000
Tuned Perfection
Congrats! Well Deserved!
coolblue05 is offline   Reply With Quote
Old 09-02-2010, 12:19 PM   #19
GrimmSpeed
Member#: 136396
2012 wrx
white
That is quite possibly the most beautiful STi I have ever seen.....
Will
GrimmSpeed is offline   Reply With Quote
Old 09-02-2010, 12:24 PM   #20
BlackJavaPearl04
Member#: 198522
98 LGT Limited
10 Forester
haha he totally deserves this. Nice work man. You have inspired many people.
BlackJavaPearl04 is offline   Reply With Quote
Old 09-02-2010, 12:24 PM   #21
EA82TRally
Member#: 73270
2002 WRX Wagon
Midnight Black Pearl
Will
I second that Will! I bet he has to hand out neck braces to all of the people when he passes by. Congratulations on a very sweet car Tino!!!
-Patrick
EA82TRally is offline   Reply With Quote
Old 09-02-2010, 12:26 PM   #22
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
nicley done, congrats on getting top scoob.
David Glasscock is offline   Reply With Quote
Old 09-02-2010, 12:26 PM   #23
JDM_OBP
Member#: 105409
'05 HTA68'd WRX
327/310
congrats tino. your car is sick as hell man. that front undercarriage shot is sick and so is the engine bay.
JDM_OBP is offline   Reply With Quote
Old 09-02-2010, 12:31 PM   #24
quick93fox
Member#: 248156
2005 STi
I'm going to need a couple changes of clothes....
quick93fox is offline   Reply With Quote
Old 09-02-2010, 12:32 PM   #25
thumpetto007
Member#: 156358
1995 Impreza 2.6RS-L
RED
That entire car is TITS!!
thumpetto007 is offline   Reply With Quote
FS : Precision 120 lbs/hr (1250cc) top feed injectors (bnib) fastblueufo Engine/Power/Exhaust 52 10-31-2010 10:17 PM
WTB : STi Top Mount ISELLSUBIES Private 'Wanted' Classifieds 2 09-04-2010 01:35 PM
Message Board Statistics All times are GMT -4. The time now is 04:49 PM.
