Old 09-02-2010, 01:46 PM   #1
nitro1956
Member#: 230682
Default Check Engine Light On / Cruise Light On
I have a 2007 Outback.....2.5, non turbo, AT. The check engine light is on ( steady ) and the cruise light is on ( blinking ).
I've read about the cruise ilght being on along with the check engine light on........but I can't remember the significance of this combination.
Help please, thanks.
nitro1956 is offline   Reply With Quote
Old 09-02-2010, 01:53 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I think they do the cruise control thing so you can't use it until you get the code checked out.
chazly413 is offline   Reply With Quote
Old 09-02-2010, 04:48 PM   #3
09suby
Member#: 222590
2009 Impreza 2.5i
Spark Silver Metallic
I believe it means that you are either running rich or lean. When mine came on it was just like that, and when I plugged my scanner into it, it said I was running lean.
09suby is offline   Reply With Quote
Old 09-02-2010, 05:03 PM   #4
TRDRacer
Member#: 212793
2003 Built 2.5L 35R
World Rally Blue
Easy, go to pepboys, Napa, Orelly's etc and see if they have a OBD2 scanner. See what codes pop up and write them down and post them on here or just search them. It is free to get the scanner from Orelly's, they just ask for your drivers license and give it back to ya when your done!
TRDRacer is offline   Reply With Quote
Old 09-02-2010, 05:49 PM   #5
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Edit your profile to show your region, or even your location. You never know who lives nearby who has an OBD2 reader. If you were anywhere around here, I'd have ya drop by and use mine.
LetItSnow is offline   Reply With Quote
Old 09-02-2010, 06:07 PM   #6
xXSTi-lynXx
Member#: 131762
2005 STi-"casper"
white on white !
if Its just the check engine light its usually a failed O2 sensor/or going catless without reflash, when It disables cruise control , It means there is more than one code being thrown, it wont allow you to run cruise control cause it could interfere with self protection modes/ fail safe/ limp home modes - what ever you want call it. that the ECU does to prevent damages to the motor
xXSTi-lynXx is offline   Reply With Quote
Old 09-02-2010, 06:48 PM   #7
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
I thought blinking CEL meant misfires detected?
Subyroo2.5 is offline   Reply With Quote
Old 09-02-2010, 07:36 PM   #8
chazly413
Member#: 151079
2005 2.5RS RBP
It does. I don't think I read anything about a blinking CEL in this thread?
Old 09-02-2010, 07:44 PM   #9
xXSTi-lynXx
Member#: 131762
2005 STi-"casper"
white on white !
blinking CEL means something other than emission controls is malfunctioning- READ:
CEL staying on- make appointment with dealer
blinking CEL-immediate service required -driving the car at all isnt recommended until it has been serviced/ checked out
Old 09-02-2010, 08:26 PM   #10
nitro1956
Member#: 230682
...OK...but what is the significance of the blinking Cruise Control light ( with the Check Engine light is on steady, not blinking ) ?
Old 09-02-2010, 08:30 PM   #11
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
aha that would be true.....was on my blackberry at the time and mis-read.
Correct. A blinking CEL means immediate damage to emissions system and/or misfires detected.
CC light blinks whenever you have a check engine light on. Say you are running cruise control at 60 mph and your check engine light comes on. Your ECU disables your cruise control to let you know that your check engine light came on.......it continues to blink as a reminder.
Check Engine Light and Cruise Light Blinking finger123 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 02-17-2014 07:09 AM
Check engine and blinking cruise light..O2 sensor Shot? LUKEWMC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 07-12-2008 12:22 AM
HELP!!!!!Check engine light and cruise light on joe198219 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 01-17-2006 07:07 PM
Check engine light and cruise light, but no codes found in the Cobb Accessport riggs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-12-2005 04:25 PM
Engine check light & Cruise light on Plasteredcat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-19-2004 11:55 AM
