Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 09-02-2010, 02:28 PM   #1
blckout7
Member#: 189845
Default Question about the 4eat
I came across a thread explaining all about the 4eat...it stated that "3" can be used on backroads or highways(getting on and picking up speed) instead of "d" because it changes the power band through gears 1,2,3. my question how bad is it switching from "3" to drive as your accelerating on a normal use...I've never done it before but would assume it can't be to good...I think
blckout7 is offline   Reply With Quote
Old 09-02-2010, 02:49 PM   #2
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
This should be in the tranny section and it wont hurt anything if you downshift fron D to 3 when merging on the highway or climbing up a hill or whatever you need more torque for.
Gr3en is offline   Reply With Quote
Old 09-02-2010, 02:50 PM   #3
blckout7
Member#: 189845
Sorry about being in wrong section
Old 09-02-2010, 03:41 PM   #4
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Change to 3 whenever you want, the 4EAT will automatically shift down when the conditions are deemed acceptable.
For example it won't shift down to 3 if you're going 125 in 4th.
formula91 is offline   Reply With Quote
Old 09-02-2010, 04:06 PM   #5
IanB
Member#: 194081
2005 Legacy Ltd. Wag
Royal Blue Pearl
Being electronically controlled, there are failsafe's in place to prevent damage to the tranny. Shifting from "D" to "3" doesn't change the powerband in other gears, it just gets you into a gear better suited to accelerating than overdrive, and if it needs to downshift into "2" then it's one gear closer to start with, that's all.
IanB is offline   Reply With Quote
Old 09-02-2010, 04:11 PM   #6
blckout7
Member#: 189845
Ok thank you guys! My car modification is officially complete!!!
Old 09-02-2010, 05:43 PM   #7
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
This is only half true. It won't change the powerband, that's just dependent on the engine really.
However, having the gear selector in "3" loads different shifting tables. It will shift into 2 sooner and stay in 2 longer.
Old 09-02-2010, 07:45 PM   #8
flightwatch
Member#: 231058
2013 Genesis Coupe
I really wish those shifting tables were tunable...
flightwatch is offline   Reply With Quote
Old 09-02-2010, 08:38 PM   #9
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
OK so all this being said.....if I hit WOT on the highway while in D and say at 4500 rpm's I drop into '3' RPMS increase like 2-300 and the car pulls even harder..........wtf causes that?
Subyroo2.5 is offline   Reply With Quote
Old 09-02-2010, 11:11 PM   #10
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Because your peak torque and horsepower are around 5000-5500....
That's about when your car is producing the most power. So it would make sense. lol
Old 09-03-2010, 02:25 AM   #11
WoodsWagon
Member#: 180769
lots of junkers
That's the torque converter clutch unlocking. If you watch the tach carefully while climbing a long hill at steady state throttle, the tach will jump 200 rpms, then hold for a while, then downshift to the next gear. Unlocking the TC gets the engine further up in the powerband, and is the first step before commanding a downshift to really get it up in the powerband.
The TCU's on the pre-98 4eat's have been cracked and are tunable. People are doing paddleshifters, modifying the shift points, full manual, all with the stock TCU.
WoodsWagon is offline   Reply With Quote
Old 09-04-2010, 10:26 AM   #12
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
hahah who would have thought? Go read my post again.
Okay, but if im already at WOT and in the lowest gear possible, what makes a difference on my 4EAT when I shift to 3rd? My reasoning is that if im doing 110 and downshift to 1st nothing happens.....so why is it that I feel like im dropping a gear when I do this? Its almost like I feel 'vtec' kick in in a honda.
Old 09-04-2010, 11:07 AM   #13
IanB
Member#: 194081
Royal Blue Pearl
That may be true, my Suby is a Legacy and I've got "sport mode" if I want more aggressive TCU maps and manual mode if that's not good enough, I've never actually played around with 4 vs. 3 position for that reason. Sport mode is pretty decent though, I love how if you're hard on the gas and let off for a corner, it will hold the gear so you're still in the power when you hit the gas to exit the corner, pretty decent logic at play there really.
Some information I gathered about the 4EAT roloc31 Transmission (AT/MT) & Driveline 0 10-30-2007 11:44 PM
Autox question for the 4eat owners. occytron wrc Transmission (AT/MT) & Driveline 2 04-04-2004 08:31 PM
Few questions about the Perrin Turbo Inlet and about the Samco MAF arm???? BLUETURBOWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-21-2003 03:53 PM
Question for the 4EAT Owners Only. Rotorflyr Transmission (AT/MT) & Driveline 14 03-19-2003 04:10 PM
