Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 09-02-2010, 09:55 PM   #1
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Default DBW goodness!
Ah. Had the pleasure of having Ty tune my DWB values. Soooo much better, smoother and all around more enjoyable to drive.
Granted I have a 4eat, so its a little more difficult to get good numbers into it that the tranny will like, but Ty hit the nail on the head.
Tranny doesn't automaticly shift from 4th to 2nd when applying more throttle. Nice and easy transition from 4th to 3rd which never happened with stock dbw.
Thanks Ty for getting me all set up.
kewlboxer2 is offline   Reply With Quote
Old 09-03-2010, 12:09 AM   #2
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Ty, what did you do to prevent the strange shifting? Or is it just me who has sees this as a problem. hahaha
Well I guess I never shifted directly into 2nd, but for me it's shifts earlier and stays in 2nd longer. Which to many isn't a bad thing. But from a MPG perspective, Meh.
formula91 is offline   Reply With Quote
Old 09-03-2010, 12:11 AM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
So far, it's just you. I need someone local with a 4EAT to spend a bunch of time logging things for me to try to figure out what's going on with the way the tranny and DBW interact. It seems to work, so far, for everyone other than you but you know me, I always like to know exactly why things are happening.
Old 09-03-2010, 01:27 AM   #4
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
I can log for you if you want. i got tactrix 2.0 with sd logging working.
mind does tend to stay is 2nd a little longer, but its not too bad. when i tried the linear(10/10, 20/20, etc) it would hold 4k in ever gear before shift.
Old 09-03-2010, 01:29 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Nah, I want to be in the car to feel what's going on and to be able to make experiments up as a I go along.
Old 09-03-2010, 05:33 PM   #6
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Maybe I'm doing it wrong? Care to send me a bin file to read?
Old 09-03-2010, 05:38 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
What's your max stock value in the Pedal->RT table?
Old 09-03-2010, 06:42 PM   #8
808subaru
Member#: 62234
Chapter/Region: HIIC
09 fozzy
I have had similar tuning issues on 2009 FXT. The auto situation was fixed and seems to be driving better. I believe it is a factory mapping issue, and PDX tuning seems to have it figured out.
808subaru is offline   Reply With Quote
Old 09-03-2010, 06:55 PM   #9
msingell
Member#: 153097
2012 CRZ
PWP
! id love to spend more time with you ty! ill buy you dinner and rub your feet in order to help my 4eat woes.
msingell is offline   Reply With Quote
Old 09-04-2010, 02:38 AM   #10
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Is there anyone out there that has mapping for 2010?
djinn is offline   Reply With Quote
Old 09-04-2010, 02:40 AM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Me.
45
Old 09-04-2010, 07:45 PM   #12
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
My max RT Value I believe was exactly the same as in your writeup, but I tried switching RT Table numbers and the Throttle Plate Opening A numbers around to try and get the same effect, and hopefully leave the transmission shift points unchanged, but I got nothing.
Other thing is that all the cars so far that report good results whether it be subyroo or kewl, is that they are all 06+. There is a definite possibility that the TCU tables or the way it does things have changed from 05.
I reformatted my hard drive so I can't say for sure, but I'll pull a ROM out later and confirm it.
Old 09-04-2010, 07:48 PM   #13
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I just noticed the same thing you did about the relative years. The 05 ROM is entirely different than the 06+ ROM. It's likely the difference in your experience stems from that.
Old 09-05-2010, 01:51 AM   #14
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Considering that the RT Table and the Throttle Plate Opening table look so different from 05 and up, I wouldn't be surprised that the transmission feels better simply from the fact that the Accel Pedal % ->RT -> Throttle Plate opening is now consistent and no longer link that's dependent on RPMs.
If I remember correctly the 06 tables have more cells, but beyond that they were not a consistent link between accel pedal and throttle plate opening, but were dependent on RPM so even if the TCU was the same, the TCU would not feel as consistent just because of that alone.
Old 09-05-2010, 03:05 AM   #15
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
There's a huge difference in the number and kind of tables (overall, not just in the DBW system) between 05 and 06. That strongly suggests behind-the-scenes logic changes as well.
FS: DBW Gas Pedal Bracket Adapter for Swapping from Cable to DBW (made by ECS) TROLL Engine/Power/Exhaust 5 03-19-2011 03:40 AM
Is this a good deal?Locals only reply Manny735 Vancouver Impreza Club Forum -- VIC 20 09-03-2010 06:36 AM
FS: (AL) SOLD!!! 06 STI DBW throttle body - good shape stidoc Engine/Power/Exhaust 12 05-07-2010 05:17 PM
FS:KY DBW Throttle Body and DBW Pedal Cf Scoop 02KyRex Engine/Power/Exhaust 6 07-13-2009 05:15 PM
2006 STI intake manifold, DBW throttle body, wiring harness, DBW pedal Cstmboxermotorsports Engine/Power/Exhaust 0 12-11-2006 07:52 PM
