Old 09-03-2010, 05:40 AM   #1
Rice Devil
Member#: 51164
Jap Jp mag 09
Ti mag 09 (cover)
Exclamation Hawkeye headlights to a bugeye loom?
Leaving the bugeye love for the hawkeye love as i'm going wideboy!!
The problem I think i'll be facing is the wiring of the headlights. Has anybody got some info this swap?
Read all the conversion threads I can find, but no detailed wiring info.
Thanks
Ricey
Rice Devil is offline   Reply With Quote
Old 09-03-2010, 09:32 AM   #2
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
You are obviously going from a split two-plug harness system to a single plug harness system when converting from 2002 to 2006.
Can you source male and female harness connectors? Meaning, can you get a plug connector for a 9004/9007 bulb? Can you get the end for the plug into the 2006 headlamp module assembly?
You could make a "jumper cable" of sorts to go from 2002 to 2006 without cutting your existing OEM harness.
Old 09-03-2010, 02:11 PM   #3
Lboogie
Member#: 171611
2014 FiST
Blk
No need to actually cut any wires, the wires/terminals can be remove from the connectors with some jewelers screwdrivers.
If you have the skills/patience you can document which wire is which on the bugeye harness (+ & - high/low beams, turns, parking lights) & take them out of the bugeye plug.
Then do the same for the male ended plug on the hawkeye headlamp assemblies, and affix the 'old' and 'new' wires together (solder, heatshrink, & tape).
Lboogie is offline   Reply With Quote
Old 09-06-2010, 07:26 AM   #4
Rice Devil
Member#: 51164
Jap Jp mag 09
Ti mag 09 (cover)
Thanks for the info guys, shouldnt be a problem getting the connectors, i'll give that a go first!
Thanks
Ricey
easiest way to take apart the hawkeye headlight?? scooby1320 Interior & Exterior Modification 17 03-03-2012 03:36 PM
rear Hawkeye STi bumper onto bugeye.. Rice Devil Interior & Exterior Modification 3 02-22-2010 01:34 PM
Hawkeye headlight question Jonnywrx Newbies & FAQs 4 11-17-2009 02:27 AM
Hawkeye Headlights Daza555 Interior & Exterior Modification 5 10-02-2009 05:18 PM
CT hawkeye headlights $250 monsterkyle NESIC Private Classifieds 2 11-15-2008 06:57 PM
