Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 09-03-2010, 11:54 AM   #1
AWD P & A
Vendor Sales Rating: (2)
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Default Break it down. Stop, Prosport time!!
That's right guys and gals AWD P&A is going back to the 80's. What does that mean for you??
No your not going to see your parents with big hair. But you will wanna party like its 1989 when you see the prices on these Prosport guages.
52 mm Electrical Digital Air/Fuel Ratio &Volt Gauge
This digital gauge is like having two gauges in one. We started with a standard Air Fuel Gauge and instead of wasting the valuable real estate in the center of the gauge with our logo we utilized that space to display the A/F & Volts Digitally. It will display Air/Fuel ratio around the outside while digitally displaying both A/F or volts. When the red "volt" light comes on you know you are reading volts (displays for 50 seconds) and if the light is not on the digital display is Air Fuel Ratio. Using a switch on the back you can even turn off the volt feature and run AFR all the time.
$60
*NEW FEATURE*
This gauge can be set to read narrow band (0-1v) or wideband (0-5v) with the flick of a switch in the back of the gauge. That means that you can now use this gauge with your stock narrow band O2 sensor or use it with a control unit like innovate to display a 0-5v signal.
NOTE: This cannot be used as a stand along wideband AFR with a bosch wideband 5 wire heated O2 sensor unless you are using a controller!
Don't be left in the dust as Prosport continues to set the trend. This gauge also incorporates our opening ceremony/Self check each time the vehicle is started.
(Includes: Mounting Hardware, Hood, Decals and Instructions)
52mm Premium Electric Boost gauge
This ELECTRICAL Boost Gauge will perform a pointer sweep/self check on start-up & shut down!
If your vehicle is turbocharged then this gauge is simply a must have. For peak performance you need to know how much boost you are making at maximum RPM's.
***********-Set the warning function to alert you when you over boost!! (-30~30 PSI includes Mounting Cup, Tubing kit, T-Adaptor, Electric Sender, quick connect pigtail wiring, Visor, Decal and Instructions)
$74
52mm Premium Oil Pressure Gauge
$94.50
Don't trust your factory gauge for important monitoring of engine functions. By the time your factory idiot light comes on the damage is already done. Monitor you engine functions with one quick glance and notice any problems before it is catastrophic.
Save your engine, set your warning function to go off before you loose all your oil pressure! Thats right this gauges warns you once your oil pressure drops below your set limit.
(0-150 PSI includes Sender, mounting Cup, Visor/Hood, quick connect pigtail wiring, Decal and Instructions)
52mm Premium Oil Temperature Gauge
Powered by a rugged Stepper Movement and utilizing only top grade sending units these 270 full sweep electrical gauges are durable, reliable, safe & easy to install. Monitor your engine temperature with more precision. Keep hazardous fluids out of the passenger compartment.
Amber/White - Blacked out when off.
Fully Programmable with Peak recall!
(100-300F includes Premium 1/8" NPT Oil Temp. Sender, Mounting Cup, Quick connect pigtail wires, Visor, Instructions and Decal)
$64
PM for more great guages and prices!!
Don't see the Prosport gauge your looking for??..Just ask!!
All gauges are available in Amber/White, Blue/White, Green/White except the AFR gauge.
AWD P&A also carries gauge pods from Auto Meter:
Dash Pod- $52.41
Glove Box- $56.70
and also 2 and 3 pillar pods.
2 pod- $64.47
3 pod- $69.84
__________________
[SIGPIC][/SIGPIC]
[COLOR=Black]New Website:
[/COLOR][COLOR=Black]
Email:
[/COLOR][COLOR=Black]OR[/COLOR]
[COLOR=Black]Send a PM!![/COLOR]
AWD P & A is offline
Old 09-04-2010, 03:31 PM   #2
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Bump!! I've had quite a few people jump on these gauges..get yours before there gone
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-05-2010, 05:17 PM   #3
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
teh bumpsters!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-06-2010, 04:48 PM   #4
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Bump!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-07-2010, 10:23 PM   #5
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-08-2010, 06:58 PM   #6
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-09-2010, 07:26 PM   #7
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-10-2010, 02:57 PM   #8
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-11-2010, 05:14 PM   #9
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-12-2010, 03:51 PM   #10
chicago06sti
Member Sales Rating: (1)
Member#: 213154
2006 STi
Steel Grey Metallic
Can you do a prosport premium combo of boost egt and oil press. with a pillar pod in 60mm and in amber/white. Also with any neccisary adapters to 60175? pm me. Thanks!
chicago06sti is offline
Old 09-14-2010, 12:19 AM   #11
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
PM'd
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-14-2010, 06:47 PM   #12
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
up!!!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-16-2010, 11:42 AM   #13
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-19-2010, 06:24 PM   #14
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-20-2010, 05:39 PM   #15
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-21-2010, 06:10 PM   #16
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-23-2010, 01:01 PM   #17
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-24-2010, 06:07 PM   #18
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-28-2010, 04:13 PM   #19
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 09-28-2010, 10:29 PM   #20
UberSuber
Member#: 258884
2005 WRX
U got a PM dude! Going once...
Da'oh! got it! free bump then...
UberSuber is offline
Old 09-30-2010, 05:05 PM   #21
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Thanks...
bump!!!
Old 10-01-2010, 02:37 PM   #22
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Old 10-01-2010, 04:04 PM   #23
Kanans
Member#: 258479
2009 Wrx
Dark Grey Metallic
PM sent
Kanans is offline
Old 10-01-2010, 05:37 PM   #24
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Originally Posted by Kanans View Post
PM sent
PM replied
__________________
[SIGPIC][/SIGPIC]
Email:
Old 10-02-2010, 11:54 AM   #25
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
bump!!!
__________________
[SIGPIC][/SIGPIC]
Email:
Closed Thread
break it down for me... ACT 6puck vs carbonetics single vs Exedy twin vhalin Transmission (AT/MT) & Driveline 54 12-21-2008 11:19 PM
Can anyone break it down for me Barney Style..... pyromaniac_spike15 Engine Management & Tuning 5 02-10-2007 02:59 PM
Breaking It In, But Not Breaking It mangoman Newbies & FAQs 45 07-22-2005 10:05 AM
2am study time! BREAK IT DOWN!:) Keith Off-Topic 27 05-12-2005 11:55 AM
