Old 09-03-2010, 12:04 PM   #1
xVern
Member#: 241860
2008 LGT
Default Heater/AC blower motor problem. (semi-noob)
So a few weeks ago, my ac decided to stop blowing on a hot day. I figured the motor just went out. Just got the new one in, and swapped it, and still... No blowing!
Nothing else seems to be wrong. Is there a fuse dedicated to that and something else i wouldn't notice?
I did a search, but i didn't find anything. If you know of a post, just point me in the right direction.
p.s. It's in a 1993 impreza L with 303k.
xVern is offline   Reply With Quote
Old 09-04-2010, 02:24 PM   #2
xVern
Member#: 241860
2008 LGT
This is what else I've gathered, doesn't work on highest setting, meaning its not the resistor. So maybe the relay?
Old 09-04-2010, 02:26 PM   #3
Jspike
Member#: 149575
94? GD
have you pulled the relay and checket it with a volt meter?
Jspike is offline   Reply With Quote
Old 09-04-2010, 06:58 PM   #4
xVern
Member#: 241860
2008 LGT
I haven't yet, as i haven't had time. Im not even sure where it's at too pull it!
Old 09-06-2010, 06:59 AM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check the fuses first for the trouble. If they are ok then it would be good to check the relay. As you found out you shouldn't assume to know what the trouble is until you have done proper testing to prove out the trouble spot. Guessing usually wastes time and money.
Cougar4 is online now   Reply With Quote
Old 09-07-2010, 12:04 AM   #6
xVern
Member#: 241860
2008 LGT
No fuses are blown. When i turn the fan on, my idle changes, and i can hear a click. Making me assume its not the switch. Not the motor, not the fuse, not the switch, must be the relay?
Old 09-07-2010, 12:29 PM   #7
SpankySuby
Member#: 122305
2002 wrx half breed
sounds like your pump is comming on and its ur relay... dont know where yours is but def check that out... for me it was on the fuse box in the cabin... and the great thing for me was the relay clicked but the contacts to transfer the power broke.
SpankySuby is offline   Reply With Quote
DFW: AC Blower motor and resistor (BNIB) Texas25RS TXIC Private Classifieds 0 11-29-2009 04:07 PM
auto climate control heater core, blower motor and controls fourage20 Interior/Dressup/Audio & Security 3 06-02-2009 10:40 AM
WTB: 2005 STi ac blower [motor] szeny Private 'Wanted' Classifieds 5 06-23-2008 06:30 PM
Air Filter for Heater / AC blower 2000RS Technical Forum Archive 6 09-11-2000 12:12 AM
