Old 06-22-2002, 07:41 PM   #1
BIGSKYWRX
Member#: 7958
09 GH B+
Default autox alignment vs track alignment
I've seen many autox alignment reccomendations w/ front camber in the neighborhood of -1.5 and the rear near 0 to help promote oversteer. I'm thinking this may not be too great a setup for the track. I've also seen several autox alignments w/ toe out settings (some front, some rear, some both)- what effect would toe out have at track speeds?
I'd like to find a alignment that is autox friendly, but will perform well at speed, conceding this is a compromise.
My current specs are: front camber -1.5, rear -1.2 toe 0 front/rear.
Thanks
Big Sky
Old 06-22-2002, 10:19 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
You're running much the same as I ran for the past year or so for combined open track and auto-x work. Yeah, it may not have been optimum for auto-xing, but I still kicked everyone's ass so it didn't really matter. And I just felt safer on track with 0 toe all around.
Toe out in the rear helps rotate the car for auto-xing, but I found on the track that having toe out in the rear makes the car want to step sideways under heavy braking. It felt purty cool to have to dial in a little bit of steering at the end of the straights, but probably not the smartest way to set the car up.
Toe out up front will help turn in, but again will tend to make the car feel darty during high speed braking. I think as you compress the front suspension under braking you add toe out anyway (someone correct me if I'm wrong). So, starting with some static toe out up front will just make that effect worse.
I guess my input is to stay with what ya got - looks pretty good to me.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-23-2002, 07:27 PM   #3
BIGSKYWRX
Member#: 7958
09 GH B+
Thanks Pat. I definitely can't complain w/ this alignment- it is effective in autox and at speed, no problems w/ tire wear either. There's probably more advantageous autox alignments (track as well) but this seems to be a good compromise between the two.
Big Sky
Alignment settings. Track vs Autox Lutfy Motorsports 6 07-29-2008 06:54 PM
Alignment Vs. Performance Alignment? chopaholix Brakes, Steering & Suspension 6 06-02-2004 03:18 PM
Alignment help. track and street: stock STi skuttledude Motorsports 4 03-30-2004 06:33 PM
Track Alignment? Ru fan Motorsports 4 06-22-2002 10:08 PM
autox vs track tire questions WRXhauls Brakes, Steering & Suspension 7 02-26-2002 09:21 AM
