Old 10-20-2010, 08:47 AM   #26
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by gkstar View Post
I have a GP-Moto, looks exactly like the QTP and in MAIC area if you would like to borrow for measurement purposes. Hit me up on PM.
I'm game. Shooting a PM to you.
Old 10-20-2010, 02:46 PM   #27
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
This thread looks familiar for some reason. hmmmm
1. Killer B MOtorsport
2. Holy Header 4-1
3. V-Band. There is no substitute!
4. We don't need no stinking gasket (see 3.)
5. 1.5" matches exhaust ports
6. 1.75" matches all OEM location turbo inlets
7. Equal Length
8. See Below
9. Fits OEM oil pan and Killer B Motorsport Oil Pan for certain
10. 321 Stainless Steel .065" thick
11. Install is about the same for any header/up-pipe install. See Dyno charts below. Lifetime Warranty
12. Cost
Testing done at EFI Logics.
+27hp
+8ft/lbs
Testing done at Epic Motorsports
OTS Stage II with OEM Header vs OTS Stage II with Killer B Motorsport Header
Stage II mods: Cobb AP, Megan Catt-Back, Invidia Catted DP, K&N Typhoon Intake, and Killer B Motorsport Header/up-pipe
+25hp
+18ft/lbs
KillerBMotorsport is online now   Reply With Quote
Old 10-20-2010, 06:30 PM   #28
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Looks nice Killer, are those available yet?
illmatic is offline   Reply With Quote
Old 10-20-2010, 07:23 PM   #29
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Originally Posted by Boost! View Post
1. brand: Covert Performance
2. model:Good question. Custom?
3. flange or v-band design connecting to up pipe, if flanged how many bolts: 3 bolt flange.
4. type of gasket if flanged: OEM at the 3 bolt to up pipe, Remflex in between the 3 bolt flange and the heads.
5. inner diameter of primaries: BIG
6. inner diameter going to the up pipe: BIG
7. equal/unequal lenght or other configurations: Equal Length
8. pics of the said headers: See below.
9. clearance with aftermarket oil pan if info is available: Not sure, still use the OEM pan, but there is plenty of clearance and don't see why it wouldn't clear after-market pans.
10. tube material and thickness if available:SCH40
11. short review about installation, performance and durability if available: Installation was a pain in the ass. Performance is TOP NOTCH. Gained a lot of hp/tq in the mid range area. Durability is also extremely good!
12. design flaw/weakness in your opinion: Heavy as hell! A little complicated taking on and off. 1 piece design provides no flex point, which is not good.
What does that cost and who do I call about getting one?
CKxx is offline   Reply With Quote
Old 10-20-2010, 08:30 PM   #30
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes, but the first batch is almost all gone.
Old 10-20-2010, 10:10 PM   #31
Ds baruuuuu
Member#: 4724
01 01RS
brp
2. Holy Header 4-1
7. Equal Length
8. See Below
12. Cost
ej20 pan too, or just 255 and 257?
Ds baruuuuu is offline   Reply With Quote
Old 10-20-2010, 10:46 PM   #32
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Any EJ25 pan... but that's the pan you should have anyway
Old 10-20-2010, 11:30 PM   #33
reid-o
Member#: 103631
2004 STI
2. Holy Header 4-1
7. Equal Length
8. See Below
12. Cost
+27hp
+8ft/lbs
+25hp
+18ft/lbs
Any plans on coming out with your own rotated kit?
I would think the vband would make it rough for people who want to use this with a rotated kit.
reid-o is offline   Reply With Quote
Old 10-21-2010, 01:25 AM   #34
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
My TurboTrix Racing TwinScroll t4 header
Junior2JZ is offline   Reply With Quote
Old 10-21-2010, 01:47 AM   #35
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
1. my brand: BM ENGINEering
2. first model ever
3. 2.25" vibrant v-band
5. 1.6" I.D. for primaries
6. 2.1" I.D. uppipe
7. ~equal length
10. 1.5" Sch10 stainless
11. fits damn well, port matched to p&p heads
12. no flaws as of yet, we'll see as time goes on.
AdamBOMB_STi is offline   Reply With Quote
Old 10-21-2010, 09:13 AM   #36
Homemade WRX
Member#: 33782
96 bastard child
stop advertising that your port matched your ehxaust side!! THAT IS NOT DESIRABLE. A slight step is unless you have a stepped primary which NONE of these have...
Just show's that who ever ported the heads didn't have all the info (having the manifold in hand) or their newbieness is showing.
In theory matching is bad and on any dyno test (NA, supercharged and Turbo) a stepped head/manifold, with exhaust flow trade off(slightly lower on the bench), has prevailed...reversion is a bitch and velocity out of the cylinder is good
Old 10-21-2010, 10:15 AM   #37
AdamBOMB_STi
Member#: 103419
04.7 STi
You're absolutely right! I am a newbie when it comes to building headers and porting. That is why I didn't boast that my header will work or not. I did this recent setup based on theory and some key DATA that I used from my old unequal rotated kit and stock port cylinder heads. I reached a plateau on power due to the stock port heads and decided to do something a bit different. I'm not gonna sit here and bench race with you on what is gonna work and what isn't. How about I just show you what my car does on the dyno and track, good or bad!?
Old 10-21-2010, 10:55 AM   #38
Homemade WRX
Member#: 33782
96 bastard child
Wow, simmer down and fair enough but I'd consider that a design compromise, assuming you found out that the exhaust port itself was the choke point (not flow through the valve or previous exhaust manifold) I'm not knocking you and the manifold does look quite nice! I've just seen that posted TOO many times and I'm starting to think people think it's the right thing to do.
I'm not bench racing, just trying to inform any readers.
Heck, even the engines we pump out here at work have some step to their manifold...then again they run 40+ psi out of the box and at times some some pretty steep manifold pressure ratios.
Old 10-21-2010, 10:56 AM   #39
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
1. brand: Lachute Performance
2. model: Twin Scroll manifold
3. flange or v-band design connecting to up pipe, if flanged how many bolts: 3 bolt OEM style Flange
4. type of gasket of flanged: OEM manifold gasket
5. inner diameter of primaries: unknown
6. inner diameter going to the up pipe: twin scroll
7. equal/unequal lenght or other configurations.: equal
8. pics of the said headers: below
9. clearance with aftermarket oil pan if info is available: unknown
10. tube material and thickness if available: un known
11. short review about installation, performance and durability if available: Install is no major task standard as with any manifold.
12. design flaw/weakness in your opinion: none seen the manifold has been flawless for 2 years of track days and daily beatings.
jnorth85 is offline   Reply With Quote
Old 10-21-2010, 07:06 PM   #40
stav05sti
Member#: 222771
2005 Impreza WRX STi
Wow the Lachute header is posting some ridiculous numbers on stock turbo.
+32HP +40TQ?! I have not seen better numbers before this header! Spool is not too impressive yet again I have not seen any other header to a better job with that when comparing stock to stock with just a header upgrade.
May I ask where you got them from because Lachute does not offer them on their site.
Thanks for your time.
stav05sti is offline   Reply With Quote
Old 10-21-2010, 09:04 PM   #41
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ You have to be careful how you look at "posted" numbers. From what I've learned most manufacturers post thier gains based on the maximum before/after where the differences are largest, rather than peak before/after. Maybe we should do the same instead of peak vs. peak to make the numbers look bigger, lol. I know most already know this, but area under the curve is what you're looking for.
Old 10-22-2010, 12:31 AM   #42
AdamBOMB_STi
Member#: 103419
04.7 STi
With all due respect, you came at me rather hostile and pessimistic. I simply posted up my header specs and pics, next post is a guy busting my chops about my header being port matched and the lack of velocity blah blah blah it won't create. Come to the think of it, the header isn't fully port matched, it prolly has an 1/8" step. LOL
Old 10-22-2010, 09:19 AM   #43
Homemade WRX
Member#: 33782
96 bastard child
Yeah, I can see how that is taken...not the intentions.
So your exhaust ports are still an 1/8" smaller than the ID of the exhaust manifold? If so, sweet!
Old 10-22-2010, 12:10 PM   #44
jnorth85
Member#: 76785
SRP
I ordered the manifold direct from Lachute, ive had it for about 2 years now.
FWIW:
Here is my Dyno plot, this is a stage 2+ on 91oct. most stage 2 cars with the same mods make around 280whp..
My car is now on a DOM3 XTR
Old 10-22-2010, 12:20 PM   #45
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ I'm curious, what are your mods?
Old 10-22-2010, 01:57 PM   #46
jnorth85
Member#: 76785
SRP
APS Turbo back
Lachute Manifold
TGV Deletes
DW 850CC injectors
APS Fuel rails
APS 65mm CAI
Grimm speed BCS
Cobb AP V2
Thats it!
Old 10-22-2010, 02:48 PM   #47
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That's interesting. Does anyone know the difference (typically) in 91 vs 93 power levels, and conversion factor beween Mustang & Dynojet readings? Too many variables to comapre? Maybe I'm getting too off topic here.
This car only has K&N Intake, Helix catted DP, Megan Cat-Back, Walbro and of course the Killer B Header. Which is a lot less than your stage II-PLUS but shows a lot more torque and not much less HP.
Old 10-22-2010, 02:59 PM   #48
jnorth85
Member#: 76785
SRP
the differance between 91 and 93 octane is HUGE ive seen as much as 20-30whp/tq variables.
you also have to take tunign styles into consideration.. Jorge generall tunes cars pretty "flat" and does not shoot for any spikes in torque.. here is my 91 oct tune on the DOM3
it is fairly low in the power dept due to the turbo being under its optimum boost level..
the 91 oct really limits the power delevery.
Over the winter I plan on running a set of ID2200 injectors and converting to E85 Between the 91 oct and E85 I should pick up nearly 100whp
Old 10-22-2010, 06:00 PM   #49
stav05sti
Member#: 222771
Originally Posted by jnorth85 View Post
Look at that graph!! So you are at full boost by 3k and holding strong till about 5.5k on the HP curve with the TQ curve giving you a max at about 5.5k and holding till about 7k? Or do I have the TQ and HP graphs mixed up?
If I'm right then you can def. get an earlier boost on TQ by using 93 octane or methanol.
That graph tells me that your car is extremely fun to drive and daily driveable.
Idk what happened with the second graph you posted besides the boost level but it is nowhere near as good as this one.
Old 10-22-2010, 06:11 PM   #50
stav05sti
Member#: 222771
Please help me understand this graph. So which run is with your header? Am I looking at the solid red (HP) and solid blue curves (TQ)?
Header Design Physics: Discuss. SaabTuner Built Motor Discussion 67 12-20-2008 07:40 PM
header design question Zefy Normally Aspirated Powertrain 9 11-25-2008 12:30 PM
Ideas on top end with this header design ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-06-2005 08:29 AM
New STI header design for 2.5L engines? Albert Normally Aspirated Powertrain 9 11-21-2002 03:09 PM
Header design Keiho Normally Aspirated Powertrain 7 01-17-2002 10:32 AM
