Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-03-2010, 02:30 PM   #1
RaineMan
Member#: 256727
2007 2.5I Wagon
Default Gasoline for the 2.5?
Hey all.
What grade of gasoline is generally recommended for the naturally aspirated 2.5?
Here in UT we have 3 grades available... 85, 87 and 91. I have generally been one to put the highest grade available in high compression or boosted engines. But is the 2.5 happy on 85 or 87?
Back in NC (where I'm from) we had 87, 89 and 93. So I am really wary about putting 85 in anything.
RaineMan is offline   Reply With Quote
Old 09-03-2010, 02:58 PM   #2
IanB
Member#: 194081
2005 Legacy Ltd. Wag
Royal Blue Pearl
I run 87 octane in mine at this point, many claimed they knock on 87, and my datalogging confirmed this, but I still run 87.
IanB is offline   Reply With Quote
Old 09-03-2010, 03:27 PM   #3
vrusso
Member#: 207074
2015 STI
You know you're jealous
Whats your elevation? That might explane the 85. 85 at around 5000ft will behave the same as 87 or so around see level because of the air density. Just be aware that if you are running 85 and make a trip down to lower elevation you will have some issues with nock. I would just stick with the 87 to be safe.
vrusso is offline   Reply With Quote
Old 09-03-2010, 03:32 PM   #4
RaineMan
Member#: 256727
2007 2.5I Wagon
The altitude in Salt Lake is pretty high. I believe it averages somewhere around 4300ft.
If someone has datalogs showing knock on 87 I'll go back to Premium (91). That was my primary concern. I don't mind paying a few bucks extra when I fill up.
Old 09-03-2010, 03:32 PM   #5
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
For the extra few cents a tank, I would run 87 or 91.
My motor knocks on 87 so I run 93 octane. (91 is not available here)
Y_I_K_E_S is offline   Reply With Quote
Old 09-03-2010, 03:39 PM   #6
Bio248
Member#: 223032
2006 Impreza 2.5i
CGM
i run whatever premium is available. im not sure that i have a lot of reason to, but its extra insurance for me the way i see it.
Bio248 is offline   Reply With Quote
Old 09-03-2010, 03:45 PM   #7
Pohenegamook
Member#: 134262
cyka blyat
http://forums.nasioc.com/forums/show...ghlight=octane
I believe this is now a zombie horse...as in it was kicked to death, kicked while dead and has now come back again for some more kicking
Theoretically 87 is OK, anecdotally higher is better.
And don't use 85 - per the manual "The 2.5-liter non-turbo engine is designed
to operate using unleaded gasoline with an octane rating of 87 AKI or higher."
Pohenegamook is offline   Reply With Quote
Old 09-03-2010, 03:48 PM   #8
RaineMan
Member#: 256727
2007 2.5I Wagon
Thank you. I figured this had to have been posted somewhere on here before. I'll switch back to premium next time I fill up.
Car didn't come with an owners manual... was a repo so I got the car, one key, one fob, and that's pretty much it.
Old 09-03-2010, 11:20 PM   #9
cmiovino
Member#: 134005
2004 WRX Premium
Mine also knocks or pings on 87. I've moved to 89 since it's only 10 cents more and no more pinging. 93 is 40 cents more... that's too much, IMO.
Old 09-04-2010, 12:15 AM   #10
suex
Member#: 243393
o6 impreza rs
Mine runs fine on 87, no knock, nothing, it will knock when I use a low-grade oil.... Maybe it has more to do with that than we think... I use castrol or mobil-1 20/50, when I can't find that, it will knock on base grade fuel..... I've been using 20/50 since I drove a Porsche, all of my cars have ran better with that oil. Obviously I switch to 5/30 in the winter... No knock at mid grade.....and yes it's all synthetic.
suex is offline   Reply With Quote
Old 09-04-2010, 01:37 AM   #11
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
I personally use 89. I might fill up with 93 once a month just to clean out the engine.
From what I was told by a truck driver that delivers the gas, he said that on the higher grades there is extra additives that clean out the engine. Not sure if its true or not but I still do it once a month.
djinn is offline   Reply With Quote
Old 09-04-2010, 07:05 AM   #12
bilzer07
Member#: 249241
2007 Impreza 2.5
Gray
Has anyone noticed a difference in gas mileage with the different gas grades?
bilzer07 is offline   Reply With Quote
Old 09-04-2010, 08:21 AM   #13
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Gasoline for the 2.5? short answer, YES!
watchunglava is offline   Reply With Quote
Old 09-04-2010, 09:31 AM   #14
S10Crazzy
Member#: 255507
2009 Impreza
So Dirty I dont Know
What software do you use for datalogging?
S10Crazzy is offline   Reply With Quote
Old 09-04-2010, 10:18 AM   #15
dgsblb2
Member#: 197278
1999 Lifted OBS
Your EJ22 OBS pings when you put 87 in it? WTF is wrong with the gas in your town?
dgsblb2 is offline   Reply With Quote
Old 09-04-2010, 10:37 AM   #16
archdude
Member#: 205968
I used 87 for the first 1.5years of owning my impreza and thought there wouldn't be a difference. I listened to what some said and moved over to 93 and noticed it being a bit smoother. now I have a 93 tune so i'll be using it from here out but 87 definitely isn't a huge difference. I just wouldn't go any lower (even with the elevation difference) like a few people stated above.
archdude is offline   Reply With Quote
Old 09-04-2010, 11:03 AM   #17
IanB
Member#: 194081
Royal Blue Pearl
ROMRAIDER software with a VAGCOM cable.
Have you datalogged your engine? I wouldn't have guessed I was pinging either, and was a staunch supporter of the "your engine calls for 87, that's all you need" club, but upon datalogging the proof was right there in front of me. Hard to argue with that.
Old 09-04-2010, 04:02 PM   #18
cmiovino
Member#: 134005
2004 WRX Premium
Yes, I've hit my highest MPGs with 89 and lowest with 87. $500 worth of gas tested. Yes, there is a difference, IMHO.
Old 09-10-2010, 07:17 PM   #19
S10Crazzy
Member#: 255507
2009 Impreza
[quote=IanB;31795162]ROMRAIDER software with a VAGCOM cable.
VAG-COM cable is for a VW/Audi This cable also works with Subaru
Old 09-10-2010, 08:01 PM   #20
IanB
Member#: 194081
Royal Blue Pearl
[quote=S10Crazzy;31853645]
It does with some of them!
http://forums.nasioc.com/forums/show....php?t=1914025
Old 09-12-2010, 09:58 PM   #21
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
fwiw, my observations with a stock 07 2.5i was that I saw about a 10-15% increase in mileage when I switched from 87 to 91. The car ran smoother and more responsive with 91.
I observed the mileage from new running on 87, calculating random tanks every now and then, then leading up to the switch, for a few weeks to verify the random sample was accurate... then switched... I followed mileage on 91 for about 6 months. Driving habits regarding route and mileage was a standard routine throughout the entire test on both fuel ratings, so there is a marked change.
Where I am, 91 is only 9-12% more expensive than 87, so you do end up saving money
Sir-Knight is offline   Reply With Quote
Old 09-13-2010, 05:42 PM   #22
VIsubi
Member#: 187834
06 2.5i impreza
Red
93 oct. on the 2006 2.5i but then again I'm supercharged so I sure don't want to blow my motor....100 oct would be amazing more boost less worries..but you N/A's can run 88 and thats as low as I would go...at least I did when I was N/A lol
VIsubi is offline   Reply With Quote
Old 09-13-2010, 05:58 PM   #23
RaineMan
Member#: 256727
2007 2.5I Wagon
If you want more octane... go E85.
Old 09-13-2010, 07:09 PM   #24
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
You're finally supercharged eh? When did it finally go in? Are you running your own stuff or is it the raptor?
formula91 is offline   Reply With Quote
Old 09-20-2010, 07:54 PM   #25
cmiovino
Member#: 134005
2004 WRX Premium
+1
I did generally the same test. Multiple trips in different temps. When I was using 89, I got better gas mileage than 87. The pinging/knocking went away for the most part too. There is still minor chatter with a cold engine, but once warmed up, it's completely inaudiable.
The price you'd pay for 89 will pay itself back in better gas mileage, therefore you aren't loosing any money by using it. Seems like a win win to me.
Will intakes for the 2.5 fit the 2.2? Husker05 Normally Aspirated Powertrain 3 11-11-2005 09:46 AM
How is the Borla exhaust for the 2.5 rs? Polishguy701 Normally Aspirated Powertrain 5 03-12-2004 03:54 PM
What's the best color and MY for the 2.5 RS? -=C=- Off-Topic 34 03-19-2003 07:11 PM
What is the oil capacity for the 2.5 RS? Robmat Service & Maintenance 2 07-05-2002 12:35 PM
