#1 |
Member#: 156456
Vehicle:2005 92x aero Blue |
I was told by someone at BC that before assemblying the motor, you have to grind down some the lower bore wall. He told me that because of the longer 83mm stroke, there will be some interfence with the bore walls.
Has anyone with the BC stroker kit done this? If so, where exactly does this need to be done and do you have pictures? I also contact BC, but I thought I would check here too -Dan
#2 |
Member#: 145145
Vehicle:2006 wrx STi |
You have to clearan e for the tod bolts.
#3 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
I think he was trying to say for the rod bolts...it's really simple to toss on a mill and do nicely or you can just grind it out.
Do it prior to machining and honing. |
#4 |
Member#: 156456
Where does the interfence happen? Have any pics?
#5 |
Member#: 145145
Sorry, damn phone makes it hard to type in an intelligible manner.
I dont' have a pic now. However the head of the rod bolt tends to want to make contact with the case. The easiest way to clearance is: Attach two rods and drop crank into block halve with main bearings installed, throw two pistons on without rings and check for interference and clearance as necessary, and then switch halves. If you are really paranoid you can bolt the case halves together and install rods/pistons without rings and turn the whole works over by hand. You want a minimum of .060" between any part of the case and any part of the rotating assy. |
#6 |
Member#: 156456
I will do that. Do you remember if you had to grind alot off? Pics would still be great if you could find some, but thanks for all the help
#7 |
Member#: 120641
NWIC
Vehicle:05 HTA3586,BB 2.5L CGM |
My case is apart right now I will see if I can get some pics for ya. I think we took about .060" off the sleeve side of the case and cleaned up some for the throws in the ribing..
#8 |
Member#: 156456
Thanks pics would be great
#9 |
Member#: 156456
bump... i still havent done this.... I have put the block together to see where the interfence is, and found out there is a lot. Looks like im going to have to grind off some of the bottom of the wall. Is this what everyone else did? I'm just nervous to do this.
#10 |
Member#: 33782
Yes, you have to clearance the block. I haven't done an 83mm setup since 06 or 07 so I don't recall where exactly they hit. I'm trying to recall if the webbing clearance was needed for the aluminum rod fitment or for the 83mm crank.
#11 |
Member#: 60836
SCIC
Vehicle:2006 Mod Class STI TIMEATTACK!! |
Too bad we tossed out our junk block - I would have been able to take pictures of everything. If you can find a local machine shop who's done a couple of strokers they should be able to do it quickly and easily.
#12 |
Member#: 145145
I have the remnants of my 2.7 laying around. I will grab some pics for you.
#13 |
Member#: 156456
thanks martinSTi05!!!
#14 |
Member#: 156456
did everyone just use a grinding stone?
#15 |
Member#: 145145
Di grinder/carbide burr/flap wheel. Or a Bridgeport.
BTW still working on picks. |
#16 |
Member#: 33782
#17 |
Member#: 263724
Vehicle:07 Subaru WRX STi |
Im also doing a BC stroker and would like to see how a knoched block looks cause Im having a shop do it and its there first time doing a stroker. Like to see some pics.
#18 |
Member#: 33782
you're taking it to a machine shop that's never clearanced a block and they can't figure out the simply step by themselves?
...go somewhere else. |
#19 | |
Member#: 263724
No what I meant by that is my builder never assembeled a stroker yet and I just want to see a pic of how a knoched block looks so when I go there I have some kind of clue. Im being really paranoid about this build and want to make sure that everything is done right. I also ask alot of questions so that I know what his every step is when putting back together my long block and that I know every little detail about my build. I cant wait to get in my ride ![]() |
#20 |
Member#: 33782
well I don't have any pics of the clearance work done.
So I assume if you are seeing the block halves apart, you're doing the assembly? |
#21 |
Member#: 145145
Tommorrow I will have them. Sorry for the delay gents.
#22 |
Member#: 246644
Vehicle:2008 Forester XT STI CGM-360HP/365TQ |
The piston skirts hit the main web at BDC... Manley has a complete rotating kit that clears, 83mm with the correct skirt design to clear.
RPG |
#23 |
Member#: 156456
bump for some pics
#24 |
Member#: 145145
here are your pics. It appears to me that no clearance work was done to accommodate the rod bolts. However ther may have been some work done to accommodate the throws of the crank. You can see the area I am talking about in the third pic directly in between the cylinders.
#25 |
Member#: 33782
you can see it a little in the first pics too. Just to clearance the cap.
| Thread Tools | |
| Display Modes | |
| Bc Stroker Kit | lucastyle23 | Engine/Power/Exhaust | 14 | 03-25-2010 11:54 PM |
| FS: Used Stock Parts, STI DP, STI UP, 08+WRX DP /BC Stroker kit | Draco Performance | Engine/Power/Exhaust | 15 | 03-10-2010 02:37 PM |
| FS: BC Stroker Kit-$2500 / Used Stock Parts, STi DP's, WRX DP's, | Draco Performance | Vendor 'General Sale' Forum | 11 | 02-01-2010 05:23 PM |
| BC Stroker kit or stay 2.5l | 06njsti | Built Motor Discussion | 32 | 08-08-2008 08:05 PM |
