Old 09-03-2010, 11:07 PM   #1
eclone
Member#: 31567
Default I'm a tard - did I fry my EGT gauge?
It was dark, it was pouring and I was just finishing up installing my defi's. Everything hooked up, powered up. Didn't have time to tap my EGT gauge so I left the sender/sensor unplugged.
Turned it on , everything worked and EGT needle would bounce off the high end as if there was no reading, no sensor plugged in (as it should). Didn't think anything of it and took it for a test run. Came back, popped the hood and realized the EGT wire (metal braid coated) was touching the positive side of the battery...
Wire where it touched melted....****. It's only 2 wire for the sender so I cut the bad section off and reconnected. Plugged in sensor cable (should now read 0 since it's not tapped) Still bouncing ****
What do I do, how do I go about troubleshooting this?
eclone is offline   Reply With Quote
Old 09-05-2010, 12:59 PM   #2
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
I would check the wires for shorts, if they are not shorted I would test the gauge by plugging in the sensor then heat the probe w/ a propane torch and see if its is functioning. if the wires are shorted you will need to fix that. Also what defis are theses?
181stLeader is offline   Reply With Quote
did i fry my turbo? Just installed EWG... felixk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-19-2009 12:30 PM
did i fry my coil pack? rswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-31-2007 11:59 PM
Boost problem...did i fry my stock boost controller brazymstrp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-30-2004 02:14 PM
Did I fry my pads? driggity Brakes, Steering & Suspension 12 11-20-2003 07:49 AM
How do I tune the AFC using my egt gauge? Keith Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-13-2001 10:59 AM
