Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 09-04-2010, 12:21 AM   #1
Member#: 124035
99 LOB and RS
Default Replacing Starter in 99 Legacy DOHC engine?
My starter started to fail, and I bought a new one for replacement. It looked like two bolts attached the starter to the engine. The top one is an easy in/out. The bottom one looked like not-so-easy to take it out because the heater cores and some other tubes (may be a/c or another heater core).
What type of tools that I can use to take the bottom bolt out? What other items that I need to be careful to take it out?
My car engine is the 2.5 EJ22D (Dohc).
SubbyOBS is offline   Reply With Quote
Old 09-04-2010, 11:50 AM   #2
Member#: 254661
12mm box end wrench?
The_PDE is offline   Reply With Quote
Old 09-11-2010, 05:21 PM   #3
Member#: 215057
assuming it's the same as my forester, it's a 14mm. It helps if you take of the intake stuff to have more access. a lot of the hoses can be unbolted from their ties, and you can use wire or what ever you have around to tie them out of the way. spray it with some penetrating oil, give it 15 min, and hit it with a 6 point socket, with a "cheater bar" slipped over the ratchet to give you a little leverage. you should have enough room for about a 1/8 turn with the cheater bar to break it loose. It is a nut, so you may have to use a deep socket. hope this helps...
wiresix17 is offline   Reply With Quote
Old 09-12-2010, 01:01 AM   #4
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
yes it's a 14mm bolt and it's quite simple to take out, it's a 10 min operation.
it's best to use a ratchet breaker bar, or a ratchet with a long handle to give you more torque, as well as more grip. you'll also need an extension.
oh and those screws w/ phillip are not needed to take out so don't bother wasting 30mins on it.
kirbykirb is offline   Reply With Quote
JDM Momo Airbag in 99 Legacy gt help needed snowjob Subaru Conversions 10 12-09-2011 06:01 PM
NJ Jdm 95-99 Legacy / Forester Engine ( Twin Cam ) linnboi Drivetrain 3 11-09-2009 04:43 PM
96-99 EJ25 DOHC engine 69subaru360 Legacy Specific Parts 9 10-27-2009 06:24 PM
96-99 EJ25 dohc engine 69subaru360 Engine/Power/Exhaust 0 10-25-2009 06:45 PM
Replacing Tweeters in 99 RS? Prylex3 Car Audio, Video & Security 0 09-16-2004 02:52 AM
