Old 09-04-2010, 01:46 AM   #1
oldschoolsubi
Member#: 197405
1987 Gl wagons 2.2
1 red, 1 white
Default wrx heads on a sti block, dome work?????
Has anyone out there done work to their wrx heads in the piston dome area? To match the piston dome in a sti head. If so please help with info and numbers so I can have my heads machined. Thanks
oldschoolsubi is offline   Reply With Quote
Old 09-04-2010, 03:43 AM   #2
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
I had mine done by hand.
Here is a co. that will CNC them for you (and a thread about it).
http://forums.nasioc.com/forums/show....php?t=1942615
CKxx is offline   Reply With Quote
Old 09-04-2010, 05:14 PM   #3
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Ed did my heads too. In fact they're the ones pictured in the post! It took a long time(1 month) but I'm okay with that. Good work takes time.
PSolbergfan is offline   Reply With Quote
Old 09-04-2010, 05:21 PM   #4
EJ20cosworth
Member#: 253551
2009 Sti
why dont you just leave them alone and use the extra compression for power?
EJ20cosworth is offline   Reply With Quote
Old 09-04-2010, 08:20 PM   #5
Ryan314
Member#: 82989
Hybrid EJ257
This is certainly not the correct way to raise your CR. You are much much better off having the heads machined then choosing pistons and head gaskets to match the desired CR.
Ryan314 is offline   Reply With Quote
Old 09-06-2010, 01:23 AM   #6
oldschoolsubi
Member#: 197405
1987 Gl wagons 2.2
1 red, 1 white
Default heads
Thank you very much for the replies! To Ed will you pm me your infomation on where to send my heads. Thanks Robert in Portland Or
Old 09-06-2010, 02:19 AM   #7
CKxx
Member#: 33458
93 RX7+09 Forester
The thread I posted talks about why that isn't a good plan.
06 STi Heads on 04 STI block?? gotawd Subaru Conversions 2 05-17-2009 11:32 PM
02 wrx heads on v4 sti block? supernick77 Pre-2002 Factory Turbo Powertrain 0 05-09-2009 07:46 PM
wrx heads on 04 sti block? kingstarlet Subaru Conversions 2 01-20-2008 03:18 AM
wrx head on V7 sti block? turbo2 Subaru Conversions 7 03-25-2005 01:13 AM
JDM STI VER8 heads on USDM STi block drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-21-2004 02:07 AM
