Old 09-04-2010, 09:11 AM   #1
wtyree
Member#: 29879
2002 WRX Wagon
Default What will happen if.....?
It's not specifically a built motor question, but I didn't know where else to post it and I thought I would get better answers in this group. I have a 2002 wrx wagon with cobb stage 2 mods (tmic). Would removing the weather stripping that runs along near the firewall that seals to the hood increase air flow through the engine bay at highway speeds?
wtyree is offline   Reply With Quote
Old 09-04-2010, 09:31 AM   #2
silvertoungerex
Member#: 124645
2002 WRX "STi" PSM
07 Silverado DD
No. Air goes into the engine bay and then goes under the car. I don't want to be that guy who beats you down with a question like this but where did you get the idea?
That just happened.
silvertoungerex is offline   Reply With Quote
Old 09-04-2010, 01:09 PM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
Actually that is a good idea and has been employed by some of the top road racing subarus around.
MartinSTi05 is offline   Reply With Quote
Old 09-04-2010, 01:29 PM   #4
wtyree
Member#: 29879
2002 WRX Wagon
Thanks for the replies. The original thought behind the question was how to inexpensively get more airflow through the engine bay to help with cooling air through the radiator and to lower the air pressure under the hood to help with the front end getting light at highway speeds. I have tracked the car a couple of times and autocross frequently. What I wasn't sure of was, whether or not it would actually suck air in at the base of the windshield or exhaust air from the engine bay.
Old 09-04-2010, 08:22 PM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
reverse hood scoop works better than removing the weather strip.
but that would require a fmic or awic.
Old 09-04-2010, 10:19 PM   #6
wtyree
Member#: 29879
2002 WRX Wagon
I might try taping yarn to the hood and base of windshield and see what it looks like with and without the weather strip.
Old 09-05-2010, 12:31 AM   #7
Baay
Member#: 139645
07 WRX
UGM
a better idea is get some water soluble paint, put a few puddles and do a run or two, then see how the paint is pushed around by the air. Easy enough to wash off after that, and you dont have to keep looking at how its working while driving.
puddles is a bad term, maybe think of it like blobs, you want enough that it will move, but not enough to spray all over the place
Baay is offline   Reply With Quote
Old 09-13-2010, 11:47 AM   #8
wtyree
Member#: 29879
2002 WRX Wagon
Well, I was lazy and didn't do the yarn or the paint. I pm'd mick_the_ginge because I saw on one of his pictures that he had removed his. I think it helps with air flow because the water temp stayed just above 160 degrees while I was on highway and oil temp was around 180. Usually the water is above 170 and oil is above 180. Not hot, but I'm just experimenting right now.
Old 09-13-2010, 02:22 PM   #9
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
i was told that removing the weather stripping is one part the other part would be to add a washer to your hood (where it attaches on either side) and let it sit a quarter of an inch higher allowing more air to escape
blowbyu24 is offline   Reply With Quote
Old 09-13-2010, 03:00 PM   #10
wtyree
Member#: 29879
2002 WRX Wagon
I'll look at that also. I did notice that the hood does wiggle more now. I'll have to look at adjusting the stops and the latch to see if that helps the movement.
What will happen if shifter pivot bolts are overly loose? Suberman Transmission (AT/MT) & Driveline 2 05-16-2007 12:11 PM
what will happen if maxing out MAF?? skyline31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-06-2005 06:53 AM
StreetTuner: What will happen if I dont unmarry? ranger5oh Engine Management & Tuning 4 03-14-2005 06:29 PM
What will happen if you plug the other nipple on a Greddy Type s bov? LqSilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-19-2004 12:45 PM
What will happen if I put in STI injectors on the stock turbo? Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 11:39 PM
