Old 09-04-2010, 12:46 PM   #1
Esupra773
Member#: 243448
04 WRX PSM
Neva Narc'd on Nobody
Default Sequential Taillights?
Has anyone every thought about how sequential taillights would look on an 04/05 WRX? IMO it would look badass. Does anyone know if they make a kit for it? Or if theres a way to custom make one?
Esupra773 is offline   Reply With Quote
Old 09-04-2010, 09:28 PM   #2
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
sqeuentials only look right when there are multiple-segments to illuminate.
Just becuase there are 2-3 bulbs in a housing... it will just look weird since there is no delineation or separation/partition between bulb housings...
it will just look like a funky flashing light show... with rhythm.... lol
Rob
TXwrxWagon is offline   Reply With Quote
Old 09-04-2010, 10:07 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Yup, nothing like going flasher- brake light - reverse - 3rd stop light with a cop behind you
Old 09-06-2010, 10:39 PM   #4
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
You have a 2004. If you have the stock taillamps then you have three bulb sockets in a row at the bottom. The middle socket has a third wire coming out of it that is not wired to anything. This is the highside (bright) filament and can be hooked up. Then you can have all three set to have the highside ready to illuminate and using a sequential flasher module.
You should search some Mustang forums and/or take a look at, for example, Steeda Autosports and Saleen Autosports. There is an electronic sequential flasher module for those cars so that they can effectively mimic a similar (mechanical) set-up that was found on earlier Cougars and Shelbys.
EDIT: I'm in a great mood this evening. Here's a link: http://www.webelectricproducts.com/products.htm
Scroll down and you'll see a listing for a kit that you can splice into an existing harness. It's two modules, one for each side. You could convert your lower bulb positions to park, turn and brake and then convert the upper outer to your back-up lamps and the inner uppers to a set of rearward foglamps.
Good luck on your quest.
WTB or WTT: GC8 JDM Taillights for 98-01 OEM Taillights popnGEAR Vancouver Impreza Club Forum -- VIC 0 10-21-2004 10:57 PM
WTT: 03 Taillights for 04 Taillights Imprezanator Private 'For Sale' Classifieds 9 02-21-2004 02:21 PM
Does Anybody know of any Sequential or Sequential style shifting Trannies for the GC8 sherifx Transmission (AT/MT) & Driveline 4 09-04-2002 09:48 PM
APC Taillights for GC8..and no.. not Euro taillights. Whiplash Interior & Exterior Modification 4 09-02-2002 03:57 PM
1 set BD JDM taillights and 1 set BH JDM taillights for sale monovich Legacy Forum 48 07-19-2002 03:00 AM
Message Board Statistics All times are GMT -4. The time now is 08:58 AM.
