Old 06-22-2002, 10:11 PM   #1
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
Exclamation Attn: Shiv! I need a base map. Could you hook me up?
Shiv,
I have the motor in and the sensors are nearly finished getting installed. So, I will be ready for a base map for the RS TEC 3. I need to get it running to a point so I can break in the motor. Can you email it to me? Also, are we still on for you taking my car for a coulple of days to mess with it on the dyno? Please email me and let me know. Once the motor is broken in you can have it. Thanks...
Paul...
hayscoob is offline   Reply With Quote
Old 06-23-2002, 09:05 AM   #2
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Paul,
I sent you Shiv's base RS Tec3 Maps to your webpage email.
If you don't get them send me an email and I will send them again.
If you need help give me a call.
-Dave
david2z4 is offline   Reply With Quote
Old 06-23-2002, 12:06 PM   #3
hayscoob
Member#: 4544
Bone Stock for now
Dave,
I got the base map and the others you sent. Thanks. By the way, how much boost were you running with the base map Shiv sent you? Is your CR the same as stock? Should the base map you sent work on a 8.5:1 CR motor? Is the base map or the altered base map you made good enough to run for 1000 mile motor break-in? I can't realy tune the car to full potential till I break in the motor. So, I will need to run low boost till then. I hope they work. Again thanks.
Paul...
Old 06-23-2002, 01:47 PM   #4
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
My motor is the stock CR and I am only running 7psi boost. His map was set for 1 bar of boost.
I would say if you run conservitive. I will send you the email he sent me on what to watch for.
Old 06-23-2002, 01:54 PM   #5
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
I would say that your lower compression is going to make you have biger chamber volume when the piston is up. This will allow you to run more advance to burn the fuel before the exhaust stroke. Read the tuning instructions about this in the tec book.
Old 06-24-2002, 11:20 PM   #6
hayscoob
Member#: 4544
Bone Stock for now
Dave,
Thanks for the help. I think the base maps you sent will allow for the car to run. I will let you know if it doesn't work.
Paul...
can anyone hook me up with a stage4 91 octane map Smoke Show Canada Region Forum 1 12-12-2005 01:47 PM
So can anyone hook me up with a map 02SilverRex Engine Management & Tuning 1 06-04-2005 12:36 PM
Blank US Map. Could you enter all the state name.s. smp291 Off-Topic 29 01-15-2004 01:47 PM
Need parts urgently! Hook me up! Strider Tri-State Area Forum 8 01-16-2003 07:13 PM
LINK Plus -Need a base map for N/A 2.5rs Marcin Engine Management & Tuning 7 11-12-2002 11:49 PM
