Old 09-04-2010, 09:38 PM   #1
johnathon.sprague
Member#: 235264
2002 WRX Wagon
Default need help getting an easy-out out!
Camshaft cap bolt broke off when I was torquing to 2002 wrx shop manual specs of 20N-m. I think its a typo because 2004 shop manual says 10N-m. Anyway, I used my smallest easy-out on it and it broke off. Should of used the next size up. I've gone through about 8 drill bits including sharpening several times and can't drill through the hardened steel of the easy-out. I'm agrivated and stopped my engine build for the night. Any advice would be great.
johnathon.sprague is offline   Reply With Quote
Old 09-04-2010, 09:46 PM   #2
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Can you take a pic?
2gnt2wrx is offline   Reply With Quote
Old 09-04-2010, 10:11 PM   #3
johnathon.sprague
Member#: 235264
2002 WRX Wagon
coming up in just a min.
Old 09-04-2010, 10:40 PM   #4
johnathon.sprague
Member#: 235264
2002 WRX Wagon
Here are some pics of my mistake and my rallispec hybrid build.
http://i937.photobucket.com/albums/ad213/standrd250ridr/IMAG0017.jpghttp://i937.photobucket.com/albums/ad213/standrd250ridr/IMAG0016.jpghttp://i937.photobucket.com/albums/ad213/standrd250ridr/IMAG0014.jpghttp://i937.photobucket.com/albums/ad213/standrd250ridr/IMAG0019.jpg
Old 09-04-2010, 10:44 PM   #5
theonlygreat
Member#: 65916
1996 Impreza WRX
Broken cam cap bolts before myself, usually they are just finger tight once the head breaks off. I have removed them with just a small flat head screw driver and just a little slot punched in them.
theonlygreat is offline   Reply With Quote
Old 09-04-2010, 10:48 PM   #6
johnathon.sprague
Member#: 235264
2002 WRX Wagon
I might try something like that but I think I tightened it considerably by wedging the easy-out in it.
Old 09-04-2010, 11:59 PM   #7
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Try finding a norseman's drill around that size. It's a reverse drill bit. It cuts while rotating left versus a standard drill that cuts rotating right. This will help extract the bolt. The FSM manual is wrong on that spec. The front cap is 10 N.m. and the two rear caps is 20 N.m.
PSolbergfan is offline   Reply With Quote
Old 09-05-2010, 12:43 AM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
That is one mistake many often do.
The OUTER most cam cap, or say the one right behind the cam gears are 7ft lbs. The Cam CAPs inside the valve covers are 14ft lbs.
If you looked at the bolts, you may have picked it out. But it's ok, you didn't do a WHOLE buch in damage at all.
FuJi K is offline   Reply With Quote
Old 09-05-2010, 02:03 AM   #9
johnathon.sprague
Member#: 235264
2002 WRX Wagon
Yes, the 2004 specs with 10 n.m. make more since, but the ken-gilbert website with the 2002 wrx shop manual says 20N.M. so I thought since I had 2.0 heads those were the specs to use. I realized when I was torquing that it seemed like a little too much for the bolts about the time one of them broke. I guess I will buy some left handed drill bits, or carbide bits and see if I can slowly drill through the EZ-out. I'm thinking I will end up mauling out the threads. I will have to figure out something though because these are DPR stage IV ported and deshrouded heads.
Old 09-05-2010, 10:19 AM   #10
col5555
Member#: 142017
spark erosion if all else fails
col5555 is offline   Reply With Quote
Old 09-05-2010, 01:55 PM   #11
shaggy-with scoobi
Member#: 207631
2002 XPT Stage 2 WRX
Fat Chicks love that ride
1 carbide #30 pilot (in drill press)
2 stair step upper portion of hole with a#21 bit (carbide)
|#21|
| |<#30
3 easy-out the easy-out + PB blaster
shaggy-with scoobi is offline   Reply With Quote
Old 09-05-2010, 02:32 PM   #12
DSM_Outback
Member#: 56345
93 Swapped L
Green
EDM FTW.
DSM_Outback is offline   Reply With Quote
Old 09-05-2010, 02:39 PM   #13
johnathon.sprague
Member#: 235264
2002 WRX Wagon
I bought a bunch of carbide drill bits today and still cant drill through the broken off EZ-out. I'm a little frustrated.
Old 09-05-2010, 02:40 PM   #14
johnathon.sprague
Member#: 235264
2002 WRX Wagon
Its going to suck if I have to hual my motor to a machine shop for EDM.
Old 09-05-2010, 02:46 PM   #15
MartinSTi05
Member#: 145145
2006 wrx STi
Originally Posted by DSM_Outback View Post
EDM FTW.
Not the same, you can't EDM a Blind Hole.
MartinSTi05 is offline   Reply With Quote
Old 09-05-2010, 02:59 PM   #16
johnathon.sprague
Member#: 235264
2002 WRX Wagon
Im thinking about tapping the top unthreaded portion of the hole and using a helicoil and washers on the bolt. Anyone think this is a bad idea? I only need to get 7ft-lbs of torque on it.
Old 09-06-2010, 06:04 AM   #17
col5555
Member#: 142017
I know nothing about the ins and outs of spark erosion but I am sure I saw on a cylinder head sight they use it for this very purpose. The EDM in this application uses a flushing cylce.
Please correct me if I am wrong just trying to help out.
Old 09-06-2010, 09:38 AM   #18
MartinSTi05
Member#: 145145
2006 wrx STi
Exclamation
Spark erosion differs a bit. EDM uses a wire that is immersed in fluid and is secured from both sides. Spark erosion could work as it is not required that a wire pass through the part.
Old 09-06-2010, 10:41 AM   #19
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
I'd drill the whole threaded portion out and helicoil it. Helicoils are pretty long. At least longer than you'd need for that size bolt. Still, the amount of thread engagement that the OEM bolt has shouold be retained. Use a stock bolt with no washers.
Old 09-06-2010, 08:04 PM   #20
DSM_Outback
Member#: 56345
93 Swapped L
Green
Pampers are diapers and Kleenex are tissue and tomatoes are tomatoes...
Split some hairs here....MDM FTW: Metal disintegration machining.
MDM/Spark Erosion like that which is used to remove broken taps etc would be a form of EDM.
Old 09-06-2010, 08:46 PM   #21
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
^^ + 1
sense of nature is offline   Reply With Quote
Old 09-06-2010, 11:05 PM   #22
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
I did the EXACT same thing...I took it off and brought it to a machine shop. I also had to buy a new HG.
CKxx is offline   Reply With Quote
Old 09-06-2010, 11:08 PM   #23
johnathon.sprague
Member#: 235264
2002 WRX Wagon
I am going to call a machine shop about EDM in the next day or so. I am half tempted to drill from the backside of the hole and try to drill out the bolt.
Old 09-06-2010, 11:29 PM   #24
WRXDK
Member#: 187983
2005 WRX
you should try a left hand bit.
WRXDK is offline   Reply With Quote
Old 09-10-2010, 11:48 AM   #25
charliew
Member#: 125304
Is the ezout flush with the surface? If it is you can weld a nut to it through the center of the nut and use the nut to turn it out. This works on cast iron really well. I've never tried it on aluminum. The heat will expand the aluminum and the bolt will expand less and get loose. Try to get a handle on the torque specs of the different diameter bolts it will dave a lot of agrivation in the future.
charliew is offline   Reply With Quote
I need to get an Xbox game, help me choose JGard Off-Topic 27 05-07-2009 01:30 AM
Need help getting the center console out of a 05 RS/WRX bobby d Interior & Exterior Modification 4 03-25-2005 12:17 AM
I found an Impreza for sale in NC need help getting it though Homemade WRX South East Region Forum 7 03-31-2003 07:00 PM
Need advice for an easy mod that will boost turbo but I can hide from the dealership. dijay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 09-03-2002 07:11 PM
Need help getting an Defi Oil Pressure Sensor mega_stream General Community 0 02-28-2002 07:25 AM
