Old 09-04-2010, 09:52 PM   #1
The G.O.A.T.
Member#: 149724
1999 leggy gt 5speed
Blood red
Default Clutch adjustment on a 2007 2.5i
I am wondering if there is a way to do a Clutch peddle adjustment on a 2007 2.5i.
It has 105,000 km and is slightly modified (Hcai, headers straight pipe mid, Flowmaster 40, 93oct tune and Rallitek Accessport)
I don't drive it to hard, it has been launched maybe 10 times in its life (8 of those on either gravel or snow) and I had it at 1 auto-x.
It sees about 60% city and 40% highway use.
All fluid including the clutch fluid was changed earlier this year (dot#3 If I remember correctly, might have been dot#4)
I was thinking of taking it out to the strip last weekend to see what it would run but I didn't get the chance although I did try 1 practice launch and it did slip in first after releasing the peddle completely.
The peddle has always been high in my opinion but I couldn't tell you if it has gotten any higher as of late.
What I am wondering is if I should be looking for a new clutch or try adjusting it, also how long do they last on average.
Thanks for your input.
The G.O.A.T. is offline   Reply With Quote
Old 09-04-2010, 10:12 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
There are 2 adjustments. The pedal height is set by moving the clutch switch up or down, it's above the pedal. The freepay is adjusted by the rod. You'll find that above the gas pedal. When the freeplay is properly adjusted, you can easily slide the linkage pin for the rod in and out.
Clutch life depends on driver, conditions and mileage.
Old 09-05-2010, 02:23 PM   #3
The G.O.A.T.
Member#: 149724
Blood red
Maybe there should be a pole?
Question on my 2007 2.5i Intake Install LD VADER Normally Aspirated Powertrain 8 11-08-2008 02:16 AM
2007 2.5i Headlight Adjustment MConte05 Interior & Exterior Modification 8 10-26-2007 09:59 PM
2006 STI suspension on 2007 2.5i wagon Reforminded Brakes, Steering & Suspension 8 09-10-2007 11:34 AM
2006-2007 2.5i wagon on STi pinks new2.5i Brakes, Steering & Suspension 5 08-19-2007 02:57 PM
2007 2.5i SE Wagon - headlight adjustment EDS Newbies & FAQs 4 03-19-2007 04:54 PM
