Old 09-05-2010, 11:09 AM   #1
iluvdrt
Member#: 46248
82 Brat
Tan
Default EJ22T rods and EJ257 rods
Are the rods between the 2 engines the same legnth? I thought both the EJ22T and EJ257 used a 5.137" (130.5mm) rod and only the strokes were different. So you could change out 22T rods with the 257 Rods and it would be a direct bolt in w/out changing piston block height. Thanks.
iluvdrt is offline   Reply With Quote
Old 09-05-2010, 11:30 AM   #2
jaybirde978
Member#: 207868
95 Impreza STI
Sedona Red
Default .
Quite right...!
jaybirde978 is offline   Reply With Quote
Old 09-05-2010, 11:51 AM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
Cool, thanks. That's what I thought.
I just lined them against each other as well. The 257 rod is a lot thicker then the 22T rod, and it has a much wider base. Everything else appears to be the same. It also fits on the crank just fine (40mm journals) so I think they will be perfect and good for about 100 hp more then the stock rod.
FS: EJ255 Crank + rods and EJ207 Rods Drakar VIC Private Classifieds 5 05-14-2009 02:07 PM
WTB/WTT (CO), EJ22t block and STI rods graphtricks Private 'Wanted' Classifieds 0 10-05-2008 11:07 AM
MD FS: Tanabe GF210 Springs and EJ257 Rods LeeC MAIC Private Classifieds 26 08-14-2008 07:40 PM
EJ20G rods vs EJ257 rods STIspain Built Motor Discussion 15 03-29-2007 06:16 PM
is there any aftermarket inner tie rods and tie rod ends for subaru? Track Assassin Brakes, Steering & Suspension 2 01-28-2004 01:39 PM
