Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 09-05-2010, 12:40 PM   #1
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
Default Early EJ20 JDM to USDM WRX internal parts interchangeability
I'm looking into doing a swap with a early (94 to 96) EJ20 JDM WRX,
does anyone know how interchangeable internal parts are with a USDM WRX?
I'm curious if there's alternatives to the expensive and limited dealer lists, and resorting to euro parts sources. Can major internals like cranks, rods and pistons/rings fit between the two?
drumzzzzz is offline   Reply With Quote
Old 09-05-2010, 11:45 PM   #2
quikcobra
Member#: 175246
Yes thei will interchange buy why? You will not benefit what so ever. There are very cheap rotating assemblies for these cars now. So its better to just take the dive for the good stuff.
quikcobra is offline   Reply With Quote
Old 09-06-2010, 01:08 AM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
No, not true. Cranks are not the same #3 vs. #5 thrust. Rods are the same. Pistons are not the same. The crown is different shaped, compresson ratio is different, deck height is different. Bearings are the same.
Old 09-06-2010, 09:59 AM   #4
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
thanks, that's what I need to know, aside from rods there isn't any interchangeability.
Old 09-06-2010, 10:37 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If you ever need a crank, any Ej18 or Ej22 phase I crank is identical to your Ej20G crank.
Old 09-06-2010, 11:43 AM   #6
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
wasn't the phase 1 rods a 48mm journal??
Cbgrandtheftauto is offline   Reply With Quote
Old 09-06-2010, 12:00 PM   #7
RallyColtTurbo
Member#: 16819
Only the phase 1 EJ25s.
RallyColtTurbo is offline   Reply With Quote
Old 09-06-2010, 02:15 PM   #8
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
Ah - if the 18 and 22 cranks fit, then the bearings sets must be identical.
I thought I read somewhere that the 1998 2.5 rs gasket kits are very close to
the ej20's as well, has any one used one of these for a rebuild?
it's beginning to seem the JDM's might not be to hard to source parts for
Old 09-06-2010, 02:52 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
All subaru EJ engines except the phase 1 EJ25D take the same bearings. For EJ20G gaskets, most of the gaskets for a 96 EJ25D will work except the head gaskets, you need EJ20G head gaskets. I think you can actually order the EJ20G head gaskets at US dealers now, the number is in the system. It's not really hard to get parts for an EJ20G.
Old 09-06-2010, 06:49 PM   #10
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
Does a 96 EJ25D full gasket kit does it even fit the valve covers and lower end gaskets/seals too?
This should definitely helps things, could pretty much order everything as a kit then.
Old 09-06-2010, 08:13 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
Scroll down the page a bit and find the Ej20G/Ej20K parts compatibility thread. It's worth reading the whole thing. Pretty much everything you could ever need for your engine is available from another model, with few exceptions.
Old 09-06-2010, 08:50 PM   #12
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
Checked out the parts lists, very handy; had just a couple of concerns with a few missing parts. Knowing that 96 gasket kits mostly fit makes it easier too. Learning just how interchangeable these engines are; Legos inside and out
Old 09-07-2010, 01:43 AM   #13
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes, Lego. But only cross match parts or gaskets with correct model years! The 1996 USDM EJ25D valve cover gaskets only fit EJ20G engines 1992-1996; for 1997-1998 you need the 1997-1998 USDM EJ25D gaskets. Really easy once you know, really easy to make mistakes if you don't know.
Marnix is offline   Reply With Quote
Old 09-07-2010, 09:55 AM   #14
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Marnix:
I am somewhat in the same boat having just bought a 93 jdm wrx wagon in need of a new waterpump
I bought it for $3500CAD and all it needs is a waterpump. I believe the previous owner couldnt find a shop willing to replace it for less than what he sold me the car for.
As the saying goes as long as I'm replacing the waterpump I might was well do the timing belt. I found some lovely but useless kits on ebay that I wisely chose not to buy.
After using the search button quite a bit I discovered to replicate the parts in the ebay USDM timing/waterpump kits I need :
Timing Belt and Timing gear from 93-96 legacy 2.5l ?
Tensioner from 93-96 legacy 2.5l
Water Pump from 02 WRX
Cam Seal from 93-96 legacy 2.5l
I though I would doublecheck my information is this all correct?
Also I need to know what USDM year and model I should be getting the
Front seal ?
Idlers ?
Little help would be appreciated. Much thanks in advance.
TommyAtomic is offline   Reply With Quote
Old 09-08-2010, 06:24 AM   #15
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Yes.... Front seal and idlers also contemporary USDM EJ25D.
Old 09-08-2010, 09:09 AM   #16
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Thanks. It seems surprising that there isnt an EJ20G faq with a parts list but I suppose once you jump through the hoops the first couple of times its probably a no brainer.
Old 09-21-2010, 01:24 PM   #17
aps_sti1
Member#: 208837
WOw this thread saved the day. I was just sitting here wondering If Ej20G and 205 bearing were the same I need some ACLs for my 94 WRX bottem end. Will the JDM bottem end run with my 205 heads and a UTEC stage 4 map w/ a vf3x of course? And Let me try n get this correct before I **** up, Ej20g's have 52mm rod jornal size?
aps_sti1 is offline   Reply With Quote
Old 09-21-2010, 02:08 PM   #18
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Each and every EJ20 left the factory with 52mm rod bearings. The change in main bearings from thrust bearing #3 to #5 was done mid 1998.
Old 09-21-2010, 02:09 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
There is a thread that serves as a FAQ but since this is pretty much an unmoderated forum it's never been stickied like it should be.
Old 10-05-2010, 07:57 PM   #20
WMP
Member#: 30625
Would you mind linking us Matt? Thanks so much. Also, would you happen to know off-hand if it's possible to use EJ205 cams/springs/retainers in an EJ20K head? We want to get some Brian Crower stuff for our race car. Thanks so much!
WMP is offline   Reply With Quote
Old 10-06-2010, 03:48 AM   #21
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Yes you can use EJ25D springs, valves/cams/retainers in an EJ20K head, casting is (almost) the same.
Old 10-06-2010, 10:19 AM   #22
WMP
Member#: 30625
Hi Marnix, many thanks for the reply. How about EJ205 valvetrain components? Suberdave says no. Cheers!
http://forums.nasioc.com/forums/show...2&postcount=30
Originally Posted by suberdave View Post
NO
phase II cams are different that Phase I cams...
-=Suberdave=-
Old 10-17-2010, 08:56 PM   #23
drumzzzzz
Member#: 157994
2003 WRX
Sedona Red
Default ARCO piston rings - cheap alternative to OEM?
anyone have experience with ARCO piston rings for EJ's?
I Found them here:
http://cgi.ebay.co.uk/Subaru-Impreza...item3f03315b59
Appears this is the manufacturer: http://www.arcomotor.com/profile/index.php
Might be an alternative to expensive OEM parts dealers, curious if this might be the actual OEM manufacturer?
*Update*
I got the manufacturers catalog, and it "appears" the piston and rings are identical after measuring the old ones.
I'm going to order a set next week and will report back when they get here.
for anyone who would like the catalog it is upped here: http://www.mediafire.com/?ee5w00d9s2lmjj2
There are several pages of Subaru piston/ring sets,
this may be a viable alternative to expensive OEM's!
Old 10-20-2010, 01:55 PM   #24
wagonryan
Member#: 163756
1996 R/RA
this thread should be sticky'd
wagonryan is offline   Reply With Quote
Old 10-23-2010, 12:58 PM   #25
aps_sti1
Member#: 208837
Got on Japanparts.com and surprisingly they have damn cheap EJ20G parts. Pistons and all kind of goodies for next to nothing. Im wondering if anyone knows of a site for the actual Measurements of these engines? Wik doesnt have ****. I need to know the deck heights some1 told me to check them before I put my 205 heads on the 20G block. Just trying to double check. Also what can I do with this Elbow on the JDM turbo to run it on my 02 WRX. I was thinkin Of Just leavin the inlet open and setting in my Airbox even tho it wont b ran to the turbo. It should still help pull lower colder air? I have the JDM Head Sheild I plan to use but I want to use this turbo.
early 90's jdm legacy/liberty/RS turbo parts? <Taiwan/Asian Pacific> brodie.gordon International Forum 0 05-14-2010 12:04 AM
JDM v7 Passenger Seat swap on to USDM wrx driver base dan avoN7 Interior & Exterior Modification 7 09-02-2006 08:08 PM
JDM STI V7 Comparsion to USDM WRX PumpsGOTAWD Electrical & Lighting 1 03-07-2004 01:51 PM
will axelback for JDM STi bolt up to USDM WRX? silverF4turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-04-2003 01:42 AM
VERY IMPORTANT! What EJ20 Series in USDM WRX? BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-21-2001 07:40 PM
