Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 09-05-2010, 01:44 PM   #1
crswjr
Member#: 185359
2003 WRX Spec R1
Yellow
Default OEM Piston Ring Gap?
Found out that some of my OEM pistons are broken.
Replacing them again with new pistons, and new piston rings.
What is the OEM Piston Ring Gap and Positions?
Any help would be greatly appreciated.
Thank you.
Edit: More info given.
2004 STI 2.5L
60,000 KMs. Not miles.
Cylinder walls still look like they came out of the machine shop. (Very visible cross hatchings. Looks fresh)
Found the tolerances and gaps for rings.
OEM ones from the dealership are good the way they are. They don't need to be filed.
Last edited by crswjr; 03-01-2011 at 03:14 PM. Reason: Answered. More details given.
crswjr is offline   Reply With Quote
Old 09-10-2010, 12:28 PM   #2
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
If you found em then post em. Be opensource for the community.
sackytar is offline   Reply With Quote
Old 09-10-2010, 11:10 PM   #3
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Y go w oem pistons if you already broke em?.. Just saying they are likely to break again no?
sense of nature is offline   Reply With Quote
Old 11-08-2010, 11:12 AM   #4
crswjr
Member#: 185359
2003 WRX Spec R1
Yellow
The Piston Rings are pre-gapped from the dealership. They didn't to be gapped.
As for the rings breaking-- it wasn't me who broke it. I bought a bad motor. I was burning lots of oil. Turns out it was 3 cracked pistons.
Had the pistons replaced, and the rings replaced.
Old 11-08-2010, 11:13 AM   #5
arghx7
Member#: 232940
how about you tell us what engine this is
arghx7 is offline   Reply With Quote
Old 11-08-2010, 11:22 AM   #6
arghx7
Member#: 232940
'05 STi
ring gap
Top ring: .0079" - .0098" limit .039"
middle: .015" - .020" limit .039"
oil ring: .0079" - .0197" limit .059"
ring-to-groove
top ring: .0016" - .0031" limit .0059"
second ring: .0012" - .0028" limit .0059"
Old 11-08-2010, 09:55 PM   #7
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
You did have the block looked at by a machinist didn't you? If there are grooves and ruts in your cylinder walls, it's still going to burn oil like it is now.
~Josh~
Old 03-01-2011, 03:12 PM   #8
crswjr
Member#: 185359
2003 WRX Spec R1
Yellow
'04 STI.
60,000 KMs. Not Miles.
The numbers that user: arghx7 provided is what's used.
Old 03-01-2011, 06:27 PM   #9
Ryan314
Member#: 82989
Hybrid EJ257
You NEED to get the block looked at by a machine shop. No exceptions.
Ryan314 is offline   Reply With Quote
Old 03-01-2011, 08:45 PM   #10
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
This^^^^
I don't care if that engine has 370 mi or 37000 mi. The rings wont seal if you don't get a light hone, and you will STILL be consuming oil. Just because you can see the factory hone doesnt mean you can just throw pistons and rings in and be good. Theres MUCH more to it than that....
2Fast4U1DAY is offline   Reply With Quote
Old 03-01-2011, 09:09 PM   #11
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
and for god sakes don't use the stock pistons, you will be back here in no time.
BlackFighter is offline   Reply With Quote
Old 03-02-2011, 02:51 PM   #12
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
People dont use the most valuable tool in their arsenal nowadays. If they used their brain a little it would make sense to go forged but nothing changes if nothing changes....
Old 04-04-2011, 01:37 PM   #13
crswjr
Member#: 185359
2003 WRX Spec R1
Yellow
Update: 10,000 Miles and counting. No oil burns. Car runs very well.
Thanks for everyone's concern, but I'm confident in the rebuild.
As stated before, it wasn't me who broke the cylinders in the first place. It's a daily driver, and I'm not an agressive driver.
Thanks again for the concern, and the help. Maybe in the future, I will do a full forged/big-turbo setup. For now, I'm very happy with what I have.
FS : 2010 EJ257 OEM Pistons/Rings/Pins/Clips retrac Engine/Power/Exhaust 0 07-21-2010 03:17 PM
FS VA: **NEW**2010 STi OEM pistons, rings, pins, and clips**$120 Shipped** moorebl Engine/Power/Exhaust 17 07-01-2010 09:01 AM
JE 2618 Pistons Ring gap & valve notches... xbcaraudio Built Motor Discussion 4 04-17-2008 10:23 PM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 5 07-30-2006 11:24 PM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 1 07-26-2006 09:33 AM
