Old 09-05-2010, 03:45 PM   #1
nac91
Member#: 252502
2004 STI
brickyard 350z
Default Low Compression in 2nd Cylinder
so i just discovered my sti has about a compression of 90 in the 2nd cylinder but the other 3 cylinders are fine...i am running the dom 3.0r made 440whp with meth ...how long could i drive the car until it blows but i check the oil constantly and etc...i was planning to do cp pistons and stock rods or should i do rods ex eagle rods?...need some advice here on what pistons and rods i should go with and how much power are people making with the dom 3.0r???...help thanks
nac91 is offline   Reply With Quote
Old 09-08-2010, 12:49 AM   #2
nac91
Member#: 252502
2004 STI
brickyard 350z
anyone????
Old 09-08-2010, 11:04 AM   #3
rodknock02
Member#: 150484
2000 RShybrid35rPPG
SRP
I vote cracked piston common problem if its a ej257
rodknock02 is offline   Reply With Quote
Old 09-08-2010, 11:17 AM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
2nd on the vote if its any 2.5L motor :P
sidewayz is offline   Reply With Quote
Old 09-08-2010, 02:12 PM   #5
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
The answer we are supposed to give you is fix it right away. But it really depends on what you damaged. if you cracked the sleeve then your going to need a new sleeve anyways so if you dont mind spending a ton of money on oil have at it. But like the other 2 votes if it is a piston issue you are going to scuff up the cylinder even more then it already is and thin down the change that slap in pistons will seal on that cylinder. That and the blowby might eventually make a depression in the cylinder wall.. Its your motor though I run wiseco/Eagle for my setups. Unless someone specifically says i want CP or JE.
Bamofo is offline   Reply With Quote
Old 09-08-2010, 07:58 PM   #6
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
What were the other cylinders compression?
I'd pull it and fix it before you have something blow a hole in your block and require more money to fix.
I'm guessing rings, if you blew the ring lands it would damage the cylinder walls and if it was cylinder wall you'd push coolant really bad and it wouldn't run worth a ****. Cracked piston is a possibility. Either way fix it now and save yourself the headache of it being worse.
project_skyline is offline   Reply With Quote
Old 09-08-2010, 08:37 PM   #7
nac91
Member#: 252502
2004 STI
brickyard 350z
its a ring...
i have been babying the car rarely hitting boost..my oil level is staying pretty steady and normal...
other 3 cylinders read 130
gunna build as soon as i get the funds just cant decide on a brand of pistons
Low compression in 2 cylinder on the same side 4cams4life Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-22-2008 12:23 AM
seriously low compression in cylinder #2 bWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 02-21-2008 12:40 PM
How do you get low compression in a single cylinder... metoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 12-13-2006 12:55 PM
low compression in cylinder #1 #3 mwrxmax Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-30-2003 09:53 AM
Help low compression on #2 cylinder ChAi North West Impreza Club Forum -- NWIC 0 06-16-2001 02:34 AM
