Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-05-2010, 08:03 PM   #1
DrunkenDragon
Member#: 21471
Default 2.5/2.0 hybrid
I did a search and didnt find anything.
is there any benefit of runnin a 2.5D block and 2.0 wrx head?
Will it even bolt up? Compression bump + nice flowing heads?
DrunkenDragon is offline   Reply With Quote
Old 09-05-2010, 08:22 PM   #2
auslyle
Member#: 129737
04 Sweet Impreza
wrong section bro but usually its something people did when they blew the bottom ends in there 2.0 wrx's .5 more L of vol in= more throttle response over the 2.0L's
auslyle is offline   Reply With Quote
Old 09-05-2010, 08:34 PM   #3
DrunkenDragon
Member#: 21471
no i meant 2.5D block and 2.0WRX heads, and stayin NA.
No turbo.
Like the 2.5/2.2 high comp guys and still havin top end with these heads.
Old 09-05-2010, 10:16 PM   #4
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
I don't think there's any real advantage to the 2.0 heads, but I didn't check for the compression change. There's also the issue of making it work properly, since the intake manifold spacing isn't the same from the 2.5 to the 2.0 among other things. Short answer is, yes you can probably make it work, but I doubt it's the best or easiest solution for whatever you're trying to do.
BAN SUVS is offline   Reply With Quote
Old 09-05-2010, 10:27 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
They flow worse, not better than stock Ej25d heads...
Old 09-06-2010, 01:46 AM   #6
DrunkenDragon
Member#: 21471
yeah i was think the same.
the car is a 1997 ej22, a 1999 EJ25D should plug right up from what i researched correct?
PLug ang play.
FS: 04 wrx 2.5/2.0 hybrid 500 miles needawrx13 NESIC Private Classifieds 2 09-27-2009 05:28 PM
FS: 04 wrx 2.5/2.0 hybrid 500 miles needawrx13 NESIC Private Classifieds 18 04-22-2009 11:33 PM
FS: 04 wrx 2.5/2.0 hybrid with 500 miles needawrx13 Private Vehicle 'For Sale' Classifieds 0 04-17-2009 09:37 PM
2.5/2.0 hybrid hypoxvi Built Motor Discussion 3 05-04-2008 01:52 AM
wrong camshaft timing or?? 2.5/2.0 hybrid Gixxer1K Built Motor Discussion 19 02-05-2008 01:14 PM
