Old 09-05-2010, 08:57 PM   #1
xieyun006
Member#: 192956
98 obs
black
Default help please! lights won't turn off
so i TRIED to install a grounding kit, i ended up disconnecting my power and when i put everything together everything turned on fine, except my dash light keeps on going dim then bright, and all my turn signals keep flashing, but my turn indicators stay off. even when i turn off my car now the lights still flash, so now its just sitting in the drive way with batteries disconnected. please help me.
xieyun006 is offline   Reply With Quote
Old 09-05-2010, 09:29 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
sounds like your alarm went into panic mode
http://www.cars101.com/subaru/keyless.html#code alarm
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter “UNLOCK” button once OR turn the ignition switch to the “ON” position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
UkNuck is offline   Reply With Quote
Old 09-06-2010, 12:01 AM   #3
xieyun006
Member#: 192956
98 obs
black
thank you kind sir, you've made my night. deffinitely fixed it lol
Please Help! My STi Lights won't turn off!!! volkl23 Electrical & Lighting 11 01-30-2007 05:16 PM
HELP! Parking lights won't turn off. Deludedteg Electrical & Lighting 1 10-23-2005 11:03 PM
HELP!! My lights won't turn off aakrusen Electrical & Lighting 1 04-08-2005 06:41 PM
Need quick Help! Parking lights won't turn off Conduit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-13-2001 11:31 AM
