Old 09-05-2010, 11:50 PM   #1
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Default Crank recommendations: 8000+rpm/700+whp
Alright so I wanted to see what everyone thinks is a good crank to run for a car that will be running higher rpms and high horsepower. Probably 8500-9000rpm wet sump system and 2.5L
The most important thing is strength and oiling.
Price is a factor as well.
If you think the stock one is good, list any modification you would do for making it reliable for the above.
Thanks!
project_skyline is offline   Reply With Quote
Old 09-06-2010, 12:02 AM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
either stock with a modded oil pump and bigger pan or a manley billet with the same mods.Either crank will do the job --stock crank=350.00 manley billet 1200.00 you choose.
john 1badSTI is offline   Reply With Quote
Old 09-06-2010, 11:25 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
so you're aiming for 700+ on a 2.5L and price is a factor?...ok
in that case, get a billet or don't plan to spin much past 8k on the stock crank. You will want to make sure you have the clearances on the main and rod bearings just right.
Old 09-06-2010, 01:21 PM   #4
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Lol its a factor but that doesn't mean its an issue!
What billet crank would you suggest?
Old 09-06-2010, 02:11 PM   #5
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
Arrow and Cosworth are the 2 best IMO.. The Manely one is a nice piece as well. I will be running the Manely in my spare short block along with all the other parts they offer. PM me if you want more info on it.
Jr
Junior2JZ is offline   Reply With Quote
Old 09-06-2010, 02:18 PM   #6
mtcs
Member#: 180640
2000 FF Drag Impreza
6765,PPG,brakeman,Chute
I will be running an OEM crankshaft in my build with a P&L modified oil pump. Looking at 8500RPM to a maximum of 9000RPM. Looking I've been reading that the OEM crank can take a lot of punishment before you have any issues. Capable of prob about 700hp.
When I was looking for parts for my build, I was told by AMS that they offer three options for cranks: OEM, Manley and K1. Manley and K1 both make a solid product that are both roughly $1500. I can't really justify buying a cosworth crank and spending that kind of money when you could get something as good for half the price.
Manley: http://www.maperformance.com/manley-...ke-190040.html
K1: http://www.bigvalleyperformance.com/...20%7B47%7DEJ25
mtcs is offline   Reply With Quote
Old 09-06-2010, 10:28 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
Arrow would be my first vote because of how they route the oil through the crank.
All the rest are pretty much the same layout 'direct shot', 'straight shot', yada yada
...never really handled or looked into a cossie crank.
Old 09-06-2010, 10:36 PM   #8
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Arrow and Cosworth look exactly the same.. I mean identical!
Old 09-07-2010, 09:21 AM   #9
stroker_
Member#: 229861
Could Arrow be the manufacturer of Cossie Cranks?? I have one though..
stroker_ is offline   Reply With Quote
Old 09-07-2010, 10:47 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
they were for Cobb's billet cranks, so it wouldn't surprise me.
Old 09-07-2010, 04:37 PM   #11
Texy32
Member#: 124252
0506 STI/Tribeca
OBP/SGM
Yes arrow makes cosworths cranks. It has the same
oiling set up as the arrow design. Very nice piece but for the
money I want the new 83mm Manley crank for $1200.
Texy32 is online now   Reply With Quote
Old 09-09-2010, 10:10 PM   #12
RacePartsGuy
Member#: 246644
2008 Forester XT STI
CGM-360HP/365TQ
Manley's crank has the same cross drilled oiling system as the Cosworth/Arrow for about 1/3 the cost. They are by far the best crank available for the money.
RacePartsGuy is offline   Reply With Quote
Old 09-09-2010, 10:44 PM   #13
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
RacePartsGuy speaks the truth. I spoke with my Manley man today.. he confirmed it.
Old 09-09-2010, 11:34 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
proof is needed!! are you sure it isn't just a straight shot like the BC setups?
Old 09-09-2010, 11:39 PM   #15
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Mr. Homemade, I can arrange to have both cranks side by side.. Any particular shots you want?
Old 09-10-2010, 01:02 AM   #16
DSM_Outback
Member#: 56345
93 Swapped L
Green
Teh Money Shot.
DSM_Outback is offline   Reply With Quote
Old 09-10-2010, 11:03 AM   #17
charliew
Member#: 125304
I think he wants the pictures that show the oil galleries exactly the same in both cranks at the same view.
charliew is offline   Reply With Quote
Old 09-10-2010, 02:26 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
I'm just stoked that they are doing it the right way at an 'affordable' cost.
The original arrow design doesn't send the oil across the main journals and actually runs them parallel to the crank. Requires loctiting and plugging set screws in the ends of the oil journals.
Searching for a machine drawing of it on here...I know I have it saved on one of my computers as well.
Old 09-10-2010, 11:17 PM   #19
sense of nature
Member#: 112759
02 Srp STi...
R ur Boltz to long????
Originally Posted by DSM_Outback View Post
Teh Money Shot.
sense of nature is offline   Reply With Quote
Old 09-11-2010, 02:19 AM   #20
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
I will get you some comparison pics this week. I will Pm you for specifics.
Old 09-11-2010, 08:50 AM   #21
bertune
Member#: 107290
bertune is offline   Reply With Quote
Old 09-11-2010, 01:59 PM   #22
Homemade WRX
Member#: 33782
96 bastard child
Awesome, I'm stoked but no rush. If you could, can you please stick straws (or something) in the oil passages? makes it easy to see where they go.
Old 09-11-2010, 02:00 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by bertune View Post
I've already founder better than that but none give enough detail to show what i'm looking for.
Old 09-11-2010, 07:34 PM   #24
norexyet
Member#: 39149
11 elantra
yea i said elantra
Jr. let me know if you want some pics of the manley crank we have one at the shop not sure if you have one handy.
-Justin
PT
norexyet is online now   Reply With Quote
Old 09-13-2010, 12:58 AM   #25
arisking
Member#: 245282
04 JBP STi
So if I want to do a 500WHP maximum build I could just use a 12200AA400 stock crank?
arisking is offline   Reply With Quote
700+WHP BUILDUP-I have an EJ22 and I want to stroke it with an EJ25 crank WRXINTX Built Motor Discussion 13 12-03-2008 09:15 AM
Why does the USDM STi have a 7000 RPM redline and not an 8000 RPM redline? Corn-Picker Factory 2.5L Turbo Powertrain 51 10-08-2006 01:24 PM
Ok, I just didn't shift gear until 8000 RPM, what should I do now? IMPEXRALLY Transmission (AT/MT) & Driveline 17 01-05-2003 03:36 PM
8000 rpm redline Botyea Factory 2.0L Turbo Powertrain 1 03-31-2002 01:10 AM
('93-'01) Who says you cant hit 8000+ rpms? YahDude Impreza Forum 21 08-21-2001 02:33 AM
Message Board Statistics All times are GMT -4. The time now is 01:04 AM.
