Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 06-23-2002, 02:20 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Default Anyone tried this airplane computer on their car?
I have got a ton of good EJ22T info off of this page (search around on it and at the bottom of the link!) and am wondering if anyone has used their system on a subaru for the road rather than the air. This may be old but I don;t recall ever seeing anything on it. I think it is called SDSEFI.
http://www.sdsefi.com/aircraft.html
Eric
Eric SS is offline   Reply With Quote
Old 06-23-2002, 01:36 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Interesting, but it requires a crank sensor replacement. Seems interesting that they have actual Subaru injector specs on there (granted they're rated at different pressures, but still).
BTW, not sure if anyone is using an SDS EFI setup, but I've heard they're pretty decent. In the past it was believed that it was one of the most cost-effective setups, but I've found several units for less then that around.
Old 06-23-2002, 03:55 PM   #3
Aphex
Member#: 146
'05 Genesis Sedan
those guys do some pretty amazing fab work on those engines as well, good reads on the engine buildups that they have.
Aphex is offline   Reply With Quote
Old 06-23-2002, 10:11 PM   #4
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
Check out the intake manifold the guy made for his EJ22. WOW!
I need to call that guy to make one for me.
tcs007 is offline   Reply With Quote
Old 06-24-2002, 12:01 AM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
This is all I have tried www.ImprezaRS.com/sdsefi.htm and I haven't heard any bad things about their ECU.
I am still using this extra injector controller with good results
Also, they said,
07/12/00 Subaru EJ Series Injectors
We recently flowed 3 different EJ injectors. They flowed the following at 38 psi:
Atmo EJ22- 260cc/min.- good for 190hp. Grey tops.
Turbo EJ22- 360cc/min.- good for 262hp. Pink tops.
Turbo EJ20- 425cc/min.- good for 309hp. Light brown tops.
That means with 4 stock 280cc and 2 additional 480cc I have enough fuel for 378HP, but other calcs I made said 416hp...
ImprezaRS dot com is offline   Reply With Quote
does anyone have spec C takeoffs on their car that I could get a ride in? maaw Bay Area Impreza Club Forum -- BAIC 0 07-25-2004 10:26 PM
Anyone have a front LSD on their car? Keiho Transmission (AT/MT) & Driveline 33 04-05-2002 08:44 AM
Anyone have a Link EMS on their car??? wrx_in_efx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-18-2002 01:13 PM
Anyone tried the scoopless look on their non-turbo GC8s? edkwon Interior & Exterior Modification 11 12-13-2001 04:55 AM
Is anyone running 225/45/17s on their car?...or just a 225> CP Brakes, Steering & Suspension 0 03-14-2001 12:01 AM
