Old 09-06-2010, 05:59 PM   #1
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Default ECU Cover Removal?
There seems to be some sort of round cones instead of nuts holding the ecu cover plate down on my 2010 sti. How do you get these off?
And what are the green plugs for that are dangling and unplugged from each other just above the ecu?
dsmtowrx is offline   Reply With Quote
Old 09-06-2010, 11:06 PM   #2
dsmtowrx
Member#: 48879
Grey Stocker
Never mind. Figured it out. Still curious about the green connectors though!
Old 09-07-2010, 02:02 AM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
they are the test connectors, some cars have two sets. I don't remember if they must both be plugged in to put the car in test mode or whatever. Plug them in and turn the key, if the fans and fuel pump cycle and various dash lights start flashing turn key off and unplug. if they don't leave them plugged together. That way if you ever flash your car with an accessport or tactrix cable you only need to plug the ones under the drivers side... unless I'm being an ass again and forgot things like you only have one set and its on the passenger side.
ProdriveDreams is offline   Reply With Quote
Old 09-07-2010, 12:32 PM   #4
SpankySuby
Member#: 122305
2002 wrx half breed
i know in mine there is one behind the fuse box in the cabin dont know if there is one on the pass side
SpankySuby is offline   Reply With Quote
Old 09-07-2010, 06:14 PM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
One set of plugs is for testing and the other set is for diagnostics. Never leave them tied together if you are not doing those things.
Help! I need ecu codes removed!!! Drunkinchef Mid Atlantic Impreza Club -- MAIC 7 08-03-2009 08:26 AM
ECU Pin Removal gotawd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-22-2006 11:54 AM
('93-'01) Hood scoop cover removal ImprezaRS2000 Impreza Forum 10 07-09-2001 03:56 PM
A-Pillar cover removal.... SilverSubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-25-2001 10:32 AM
Easy Vent Cover Removal and Attachment. Pinochle Technical Forum Archive 7 08-11-2000 11:14 AM
