Old 09-06-2010, 06:52 PM   #1
RS-MAD
Member#: 78004
Default Mahle Piston Problem
Hi all ,
Im instaling Mahle EJ25 pistons to my engine and I notice that oil ring is much lower than standart piston.
When I look in piston bolt hole I clear see the oil ring .
Different design , or my block or rods are not what must be ?
Is that normal ? Or there is some mistake with my pistons ?
Thanks !!
RS-MAD is offline   Reply With Quote
Old 09-07-2010, 05:21 AM   #2
masterx81
Member#: 217747
1998 Impreza WWW v4
Blue!
If the oil rings are tabbed (so that while rotating an end can't go on the access hole, destroying all), it's ok.
The greater space between the first ring and the crown of the piston is a good thing. Less heat to the rings.
masterx81 is offline   Reply With Quote
Old 09-07-2010, 05:22 AM   #3
masterx81
Member#: 217747
1998 Impreza WWW v4
Blue!
Old 09-07-2010, 07:16 AM   #4
EMS
Member#: 14116
The oil rings aren't tabbed anymore with the latest batch! But no problems there, even if the oil ring turns into the "worst" position. (I checked it really well) I do a chamfer to the piston pin holes, to avoid trouble.
EMS is offline   Reply With Quote
Has anyone performed a miracle and fitted Mahle pistons?? quadesl57 Built Motor Discussion 37 02-11-2011 12:26 PM
mahle pistons and CR question kurion Built Motor Discussion 15 06-29-2006 01:47 PM
Mahle pistons stu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-02-2006 11:00 PM
HELP!! mahle piston circlips, what tool to hold the bloody things? quadesl57 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-13-2006 04:15 AM
mahle pistons and oliver rods... 13secwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 08-12-2005 07:28 PM
