Old 08-19-2010, 03:50 AM   #1
Su||y
Member#: 169794
2007 WRX Wagon
Stage Catless
Default My EJ255 popped tonight
Well here's the scoop, I was making a spirited canyon run on the connector from decker to mulholland. Anyways, I stomped on it on the apex of sharp right hander and instantly felt studdering/ a massive power loss. All the lights when off on the dash and the car started stumbling. I knew it was fudged the second I let off the pedal and my heart sank. Pulled over soon after and the car still idled, but it was idling rough and the car was shaking pretty good. The motor doesn't squeak or make any banging noises, but rather sounds like it's running on 3 cylinders. No oil leaking underneath or under the hood. Does anyone have any ideas? Cracked piston?
BTW - Car is running a VF39 on 20 pounds with a spearco tmic if that makes any difference...
Su||y is offline   Reply With Quote
Old 08-19-2010, 03:53 AM   #2
stibowen
Member#: 234174
2006 STi
Front mount? Check your intercooler couplings. Blowing one of the couplings will do pretty much everything you just said.
stibowen is offline   Reply With Quote
Old 08-19-2010, 10:58 AM   #3
Su||y
Member#: 169794
2007 WRX Wagon
Stage Catless
Spearco tmic, I checked all the couplings and I know it's not a boost leak. Something is seriously wrong with the motor. I'm going to take a video of it idling..
Old 08-19-2010, 11:11 AM   #4
DSM_Outback
Member#: 56345
93 Swapped L
Green
Compression and leakdown test.
DSM_Outback is offline   Reply With Quote
Old 08-19-2010, 12:29 PM   #5
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
By your description, you have a pretty serious electrical problem. I would focus my attention there. You wouldn't temporarily lose your dash lights, even on a catastrophic engine failure.
Zackbo is offline   Reply With Quote
Old 08-19-2010, 12:31 PM   #6
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
I think he means all the lights "went off" aka limp mode.
RicersWetDream is offline   Reply With Quote
Old 08-19-2010, 12:43 PM   #7
DJTWRX
Member#: 182985
2006 Monster WRX
Raining Blood
Your description is similar to what I experienced when I lost a piston in my 2006 WRX. The fact that you have an 07 WRX makes this a more likely cause.
You'll need a compression test and a leak down test to confirm.
DJTWRX is offline   Reply With Quote
Old 08-19-2010, 12:56 PM   #8
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Is this a built motor?'
If not you should post in the appropriate section ,you might get more help.
sense of nature is offline   Reply With Quote
Old 08-19-2010, 01:22 PM   #9
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
Check all the connectors i.e. coil packs, cams/crank/avcs etc. Could be something came loose.
AQ Motorsports is offline   Reply With Quote
Old 08-19-2010, 06:14 PM   #10
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
use this sad opportunity to do head work and at least drop in pistons lol.
domestic_abuser is offline   Reply With Quote
Old 09-03-2010, 10:00 AM   #11
STiGuy23
Member#: 215108
02 rex sti and jdm
flat black stealth mode
this ^^^^^
this will tell you the jist of it if nothing is noticably undone, leaking, or broke under the hood.
STiGuy23 is offline   Reply With Quote
Old 09-04-2010, 01:04 AM   #12
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Check the ODB2 codes first, it'll cost you nothing and might point to something simple, if you're lucky.
Old 09-06-2010, 08:47 PM   #13
maloz129
Member#: 242227
04 impreza wrx
san ramo red
same exact thing happend to my car a while ago, i was thinking the same thing that i blew my motor..turns out that my cylinder 4 coilpack wire came lose..fixed it and everything went back to normal..id look at the coils
maloz129 is offline   Reply With Quote
Old 09-07-2010, 05:54 AM   #14
Hey_its_Cole
Member#: 55305
Same thing happened to my car and it was just loose coil pack. Your description sounds exactly like how mine was when it came loose.
Hey_its_Cole is offline   Reply With Quote
My ej255 wrx Swapped GC salvator_rizzo Member's Car Gallery 11 08-25-2008 04:38 PM
Probably blew my ej255 STi*guy.kiev Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 08-23-2006 09:27 AM
Probably blew my ej255 STi*guy.kiev Built Motor Discussion 1 08-23-2006 05:57 AM
So my DOG popped my barnd new Kumho ECSTA ASX TUSWM Off-Topic 54 11-17-2004 03:07 PM
Why do my speakers pop/distort after amp install? help! ezatnova Car Audio, Video & Security 3 10-22-2001 05:18 PM
