Old 08-20-2008, 02:16 PM   #1
sonic03dz
Member#: 144056
03 wrx
sonic yellow stage 2
Angry HID low beam kit works but Fog Lights DO NOT?
Just installed a hid kit on a 03 wrx: single beam 6k and turned off the daytime running lights.
Nosw when I turn on the fog lights the high beam indicator goes on which shouldnt happen bc i got no high beams..plus when the high beam went on on the stock lighting the fogs would atomatically turn off...and the fog light button indicator lights up very dim....
also i turn of the fogs and try to turn them on they wont always turn back on..UNLESS i turn the lights off totally and turn them back on...
i think i need a restitor wire or something bc the computor thinks the high beams are on when I actually on have single beam HID KIT?
HELP PLEASE????????????
sonic03dz is offline   Reply With Quote
Old 08-20-2008, 02:41 PM   #2
subaru3169
Member#: 55252
* pullup bar *
on the stock wiring, the fogs will be off when you hit the high beams.. there may be something funky in the wiring of your hids.. what kind of headlights are you running btw??
subaru3169 is offline   Reply With Quote
Old 08-21-2008, 06:11 PM   #3
sonic03dz
Member#: 144056
03 wrx
Default lights
i kno the fogs turn of wit the high beams...BUT i got no high beams bc of the HID Kit....headlights are stock
Old 08-22-2008, 07:39 PM   #4
timeattack
Member#: 97046
2002 Wrx
World Rally Blue
When I had a 9007 "plug and play" hid system my fogs would do the same thing. What worked for me was to push the fog light button slowly....very slowly and they would always turn on. The high beam indicator would still light up, but thats just the way it was. Now that I have a Hella D2S Hid system with my Uk300 lights, it doesn't do that anymore. Rick
timeattack is offline   Reply With Quote
Old 08-22-2008, 08:55 PM   #5
subaru3169
Member#: 55252
* pullup bar *
i think maybe those hid kits just bork the lighting system since it goes from dual to single.. i dunno=/
Old 08-24-2008, 04:45 PM   #6
Handsdown
Member#: 29355
den yuz getz yo sum edamacaton and put the 9007 halogen's back in.
the fogs are wired to only come on with the lows and turn off with the highs. you don't have anything on the highs so it's confusing that relay.
Handsdown is offline   Reply With Quote
Old 09-24-2008, 07:39 PM   #7
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
Any other info on this topic?
I have sort of the same problem. I bought a 9007 Bi-Xenon kit from ebay; plug-n-play. Everything went according to plan; a very painless and easy install, maybe 30 mins tops? Anyways, when I got in the car, everything worked liked it should. The low-beams would come on when supposed to, and when I turned on the high-beams using the stalk, all was well.
However.
When I was on the low-beam setting and pushed in the foglight buttom, the high-beams would come on along with the fog lights and the high-beam indicator on the cluster would dimly illuminate. Everything would reverse and go back to normal when I would turn the fogs back off.
It's absolutely driving me crazy. I love the fog's on Subarus and I would hate to not have them work like how they're supposed to. I have disabled BOTH DRL locations (under the hood and behind glovebox). The car is an 2002 WRX.
STI_KLR is offline   Reply With Quote
Old 09-24-2008, 08:01 PM   #8
Handsdown
Member#: 29355
if you have a proper relay harness, it won't happen.
take it out before this happens:
http://www.hidplanet.com/forums/viewtopic.php?t=43834
Old 09-24-2008, 08:37 PM   #9
STI_KLR
Member#: 189660
'02 WRX
How do I know if it is proper or not?
Old 09-24-2008, 10:14 PM   #10
Handsdown
Member#: 29355
that won't happen
does it have relays? you'll need two.
Old 09-24-2008, 11:13 PM   #11
STI_KLR
Member#: 189660
'02 WRX
Originally Posted by Handsdown View Post
that won't happen
lol, how comforting.
Now by relays you mean...
Sorry, I'm a real n00b when it comes to wiring/electrical.
Old 09-25-2008, 12:37 AM   #12
Handsdown
Member#: 29355
Honestly, this is serious.
HIDs pull a ton of volts and current on startup, so everytime you light up the wiring gets strained, and bad. it can start fires and it can permanently damage the very expensive stock harness beyond repair.
take out the kit, put in halogens, and talk to someone who knows how to make a relay harness.
in fact, read the whole HID faq. the bugeye lights don't respond well to hids at all, even with a relay. get a retrofit or stick to halogen!
Old 09-26-2008, 12:30 PM   #13
carrman
Member#: 69137
2007 2.5i Outback
1966 Chrysler 300
When I installed my Morettes with halogen bulbs I fabbed my own wiring harness with relays to run them. I had the same problems with my fogs you described. I had to perform the fog light mod that allows the fogs to be turned on with only the parklights being used, and allows them to stay on when in high beam.
carrman is offline   Reply With Quote
Old 09-19-2010, 05:29 PM   #14
Charlie Tango
Member#: 230646
2007 Legacy spec.B
stg2, DGM
Can you tell me the way to wire it to make that happen?
Charlie Tango is offline   Reply With Quote
Old 09-19-2010, 07:11 PM   #15
Speedster329
Member#: 214652
2004 STI !
JBP !
Imhaving the same problem on my bugeye as well....I have just the single beam hid kit and when I turn on the fog lights they don't turn on and the high beam indicator turns on the dash...would like to have the fogs on as well and if there's a way to have this work that would be great
Speedster329 is offline   Reply With Quote
both HID low beams stopped working EGY5 Electrical & Lighting 11 09-18-2013 11:54 PM
04 Sti - (hid) left light low beam won't work lowridnwrx Electrical & Lighting 4 03-17-2010 07:26 AM
low beams dont work, but high beams do HighRevimpreza Electrical & Lighting 4 03-10-2006 06:43 PM
High beams dont work w/ Fog light mod nc_psx Interior & Exterior Modification 6 10-15-2004 04:43 AM
My low beams don't work, but my Highs do Bobalouy Service & Maintenance 2 01-20-2002 10:47 AM
