Notices
Old 08-18-2010, 02:19 AM   #1
Saintsp
Member#: 249258
Default low oil pressure
engine is a build 2.7 with bc kit.Having this problem of low oil pressure.When i rev the oil pressure on stays at 4 bar.What could be the cause of low pressure?
Saintsp is offline   Reply With Quote
Old 08-18-2010, 02:37 AM   #2
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Fluctuating oil pressure? Or just low in general?
mtcs is offline   Reply With Quote
Old 08-18-2010, 02:45 AM   #3
Saintsp
Member#: 249258
Will not go over 4 bar.Bearing issue?oil pump is new 12mm.
Old 08-18-2010, 02:45 AM   #4
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
So it stays at 58psi even when your driving it at higher rpm and in boost?
Old 08-18-2010, 02:48 AM   #5
Saintsp
Member#: 249258
yes.What could cause this?i just want to find out what could be the cause
Old 08-18-2010, 06:49 AM   #6
Saintsp
Member#: 249258
anyone to share?
Old 08-19-2010, 12:27 AM   #7
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
What oil are you using? What are the bearing clearances?
soobaviator is offline   Reply With Quote
Old 08-19-2010, 03:14 AM   #8
Saintsp
Member#: 249258
Whats the difference between loose or tighter bearing clearance in term of oil pressure?
Old 08-19-2010, 08:44 AM   #9
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
The bigger the oil clearances, the lower the pressure, the thinner the oil the lower the pressure...
If clearances are not known and the engine is otherwise mechanically sound the thickness of oil can be looked at first. Built motors with larger clearances are going to need thicker oils. Also if the motor has had some oil relieving work it may need thicker oil to get proper pressure at operating temps.
So again, what are your clearances and what oil are you using?
Old 08-19-2010, 10:48 AM   #10
blackacres
Member#: 134821
2006 STI
^ Right on!
When running a stock motor with stock clearances, as we know 5W30 will work fine.
I have a sleeved, O ringed motor, with a BC billet crank with coated ACL bearings.
The motor was built by AR Fab.
During my discussions with Howard at AR on break in oil, operating oil, etc., I was told that I should use 10W40 oil to begin with, this was due to the greater bearing clearances my motor was put together with.
He said when I track the car, I need to monitor my oil pressure, but more importantly my oil temperatures.
He said that if I notice oil temps rise and pressure begins to drop off, say on a hot day, or pushing the car hard, I may need to go to an even heavier oil, or perhaps blend two different weight oils to maintain my oil pressures.
As the larger than stock bearing clearances are used on this type of motor, it is very important to maintain high oil pressures as the oil acts as a cushion. A thin oil, or low oil pressure will not provide this cushion between oil fed surfaces.
FYI, when I start my car on a cool morning my oil pressure runs around 95-100 psi at idle, once the motor warms up, my oil pressure at idle is around 50-60 psi and at 2000 rpm, up to red line, it runs 85-95 psi depending on the ambient temps.
As mentioned above, you should first go to a heavier oil, if you still don't see higher oil pressures, I'd be talking to the guy that built your motor real soon!
Good luck.
blackacres is offline   Reply With Quote
Old 08-19-2010, 01:21 PM   #11
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Good luck.
Where on the engine do you measure your oil pressure from?
jigga is offline   Reply With Quote
Old 08-19-2010, 01:26 PM   #12
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Check you oil pump relief too.
Old 08-19-2010, 01:33 PM   #13
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
You have a few options. You can get a gallery plug adapter and mount the sender and electrical gauge of your choice. There are two spots on the top of the block for oil gallery plugs.
You could also buy a sandwich adapter and use it to plug in multiple sensors like temp and pressure gauges. You should have both actually.
I use the gallery plug adapters and a very good mechanical gauge to test oil pressure on engines. This is not the most convenient method (the gauge has to be mounted outside the car for testing) but I get accurate pressure measurements for reference and diagnosis.
I was lucky enough to pick up a couple of Omori 45 mm gauges a few years ago as they fit the OEM 3 gauge pods I have in my GDA WRX's. I would not go cheap on gauges.
Old 08-19-2010, 02:18 PM   #14
MartinSTi05
Member#: 145145
2006 wrx STi
I would look at the relief setting. If oiL pressure hits 58 psi and stays constant throughout the rev range it sounds like a relief valve adjustment/ setting issue.
MartinSTi05 is offline   Reply With Quote
Old 08-20-2010, 12:11 AM   #15
Saintsp
Member#: 249258
well we removed the oil cooler and oil press went up.Tried to isolate the problem so we bypass the core with the sandwich plate in and oil press drop again.How could a sandwich plate cause this?just don understand
Old 08-29-2010, 11:09 PM   #16
Saintsp
Member#: 249258
Now er put back te oil cooler system,change the line and the oil press drop to 4 bar again,it somehow lose 2bar from just oil cooler?
Old 09-04-2010, 11:29 PM   #17
Saintsp
Member#: 249258
Final try we changed an oil cooler,change a new 12mm oil pump with 2 added shims and it still does the same thing.cold the oil pressure can go up to 7 bar but when hot,oil temp bout 80 plus the oil pressure dropped to 4 bar and it just stayed there even when on boost.Motor was tuned to 9k rpm and without the oil cooler everything was fine.ANy help here?WHat could be causing it?Crack pick up?seems like the oil pump wasn't strong enough.
Old 09-05-2010, 12:38 AM   #18
stibowen
Member#: 234174
2006 STi
Where do you have the oil cooler mounted?
stibowen is offline   Reply With Quote
Old 09-05-2010, 01:21 AM   #19
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
What size lines are you running to and from the oil cooler? How large is the cooler? How long are the lines from the engine to the cooler and back?
wrx_driver_2002 is offline   Reply With Quote
Old 09-05-2010, 02:06 AM   #20
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
What oil is being used???
Old 09-05-2010, 09:09 AM   #21
ScoobyAficionado
Member#: 36575
'04 STi
Fittings should be at least AN10, and you should have a good Mocal or Setrab cooler made for those size fittings. Buying a tranny fluid cooler designed for AN-6 lines is not going to help you here.
ScoobyAficionado is offline   Reply With Quote
Old 09-05-2010, 08:26 PM   #22
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You tried a different oil filter?
Old 09-06-2010, 02:26 AM   #23
Saintsp
Member#: 249258
Ya tried a different oil filer,changed to the mocal oil cooler with -10 line.exactly the same thing.where is the oil pump relif?oil used is 5w50
Old 09-06-2010, 07:13 AM   #24
Saintsp
Member#: 249258
How do we actually adjust the relif valve?Its a 12mm new oil pump
Old 09-06-2010, 09:10 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There is one built-into the pump. The spring is under the cap screw that comes in from the side. There is another built-into the filter too.
I don't think the pump bypass has a problem since your pressure is low at startup, bit checking it wouldn't hurt.
Drop in oil pressure / low oil pressure magicstop Newbies & FAQs 3 07-24-2015 11:13 PM
Low oil pressure? iareben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-18-2005 02:50 PM
Low oil pressure Twisted STi General Community 5 12-28-2004 12:41 PM
Oil Coolers cause low oil pressure upon startup? kaos200 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-21-2004 02:22 AM
Low Oil Pressure MisterX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 12-06-2002 11:18 AM
