Old 09-07-2010, 02:12 PM   #1
D-NaSty
Member#: 156456
2005 92x aero
Default Aftermarket Timing Belt Guide - Worth it or not?
Hey guys,
Get ready to reassembly my motor, already getting a Gates Racing Timing belt. Don't kno if I should get an aftermarker belt guide though? What do you guys think? I have only seen a few ones, which ones are most commonly used?
-Dan
D-NaSty is offline   Reply With Quote
Old 09-07-2010, 02:20 PM   #2
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
I went through a few belt guides when I was doing my build. They just aren't too strong and tend to bend with higher RPM. I was going through timing belts left and right. The old guide would bend and cut into the belt. Not too much fun. Especially when you are going through a timing belt every 2 weeks.
I replaced mine with a cosworth belt guide. Haven't had an issue since.
http://cosworthusa.com/store/pc/view...2&idproduct=39
mtcs is offline   Reply With Quote
Old 09-07-2010, 02:29 PM   #3
Baay
Member#: 139645
07 WRX
UGM
I have a cossy one too, but it seems to be a tad tight up against the belt, id go with the Tomei its a little cheaper, wraps around more, but im not sure if it fits any better.
Baay is offline   Reply With Quote
Old 09-07-2010, 03:14 PM   #4
D-NaSty
Member#: 156456
2005 92x aero
Thanks for the input
Old 09-09-2010, 09:28 AM   #5
D-NaSty
Member#: 156456
2005 92x aero
Old 09-09-2010, 09:37 AM   #6
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Originally Posted by D-NaSty View Post
I am. seams to be as well built as the cosworth piece i had before. Timing cover is coming off soon after 1000 miles, will see how it is working.
cnstman is offline   Reply With Quote
Old 09-09-2010, 09:38 AM   #7
cnstman
Member#: 9548
2004 WRX STi
My mechanic uses a business card folded over to check clearance. Is it tighter than that?
Old 09-09-2010, 11:39 AM   #8
Baay
Member#: 139645
07 WRX
UGM
Yeah it was a little tighter using a Gates belt (used the same method) i havent had the motor out since it was built so i cant see if its worn but im sure it probably is.
The one Import Image has looks like the Tomei one, so its probably just as good as the cossy or similar.
Perrin Pulley - Worth it or not? Alan l. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 08-27-2005 08:50 PM
Worth it? or Not SPOOLN Motorsports 16 07-12-2005 05:10 PM
Cat Backs....worth it or not? semabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 11-22-2003 03:13 PM
anybody install whiteline steering rack bushings?..worth it or not worth it wrxxtc Brakes, Steering & Suspension 2 07-26-2002 01:02 PM
