Old 09-07-2010, 06:41 PM   #1
trendyincdotbiz
Member#: 200687
1997 Impreza
Default Gave it a tune up and now it wont stay running
Car - 99 Impreza Outback Sport 2.2L SOHC MT
Car had P0170 fault code for fuel trim malfunction so I gave it a tune up.
New air filter , plugs , PCV , fuel filter , oil change .
Car started up in fast idle then dropped and died .
try and start it back up and it starts hard then dies right off.
If I give it gas it bogs down instantly and dies.
If I feather the throttle up to 3k rpms itll stay up there until I let off .
Smells uber rich so I cleaned the MAF.
Same result.
Unplugged the MAF and it ran and idled OK but still smells slightly rich.
No codes are coming back but then I havent been able to get the car running long enough to see if a code reoccurs.
Bad MAF ?
I unplugged the upstream O2 sesnor to see if it would run and no avail.
unbolted the exhaust mani to test to see if it was a plugged cat - no avail.
Hmmm..... help ?
trendyincdotbiz is offline   Reply With Quote
Old 09-07-2010, 09:03 PM   #2
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Make sure you hooked the fuel hoses back up properly. The one coming off of the filter should go to the top hard line on the manifold.
geronimo81 is offline   Reply With Quote
Old 09-07-2010, 09:48 PM   #3
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
I would check for a leak between the maf and tb
AQ Motorsports is offline   Reply With Quote
Old 09-07-2010, 11:21 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Vacuum leak somewhere. Spray starter fluid around gaskets/areas of vacuum to see if idle changes.
Old 09-08-2010, 01:50 PM   #5
trendyincdotbiz
Member#: 200687
1997 Impreza
Thanx all for the input.
Did the starting fluid techique on all vac lines and gaskets - no leaks.
Even installed a New used good working MAF and front O2 sensor to no avail.
Still stumped.
Car died while driving and wont stay running now, need your help!! nbiesold Service & Maintenance 1 03-24-2009 09:34 PM
New boots for X-Mas. Now socks wont stay up Obnoxio Off-Topic 16 12-24-2008 05:24 PM
Just Installed TurboXS FMIC and have a PO113, car wont stay running! vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-21-2006 06:42 PM
car wont stay running! squeeking and clacking noise yamaha1995 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-30-2004 02:20 AM
