Welcome to the North American Subaru Impreza Owners Club Tuesday September 16, 2014
Old 09-07-2010, 06:54 PM   #1
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Default spec's for a 500-600hp ej207 build?
So here is the short story. I swapped my 04 outback sport with a mint 12,000km EJ207(version8) and stopped modding after it was done because my employer moved to Mexico. So now I landed a great new Job and we all know what that means.;-)
Here is the goal, lmk your opinions on the motor mods.
Full-race gen2 rotated twin scroll Borg warner s362(35r size)
Weekend car only and will only run vp in it.
Final goal of 500 awhp to 600 depending on final tune, psi, and Oct.
I was thinking stock bottom end, cosie rods n pistons, bc 280's, bc valvetrain, Apr head studs. Keep it simple but yet effective.
prokaw875 is offline   Reply With Quote
Old 09-07-2010, 07:47 PM   #2
cubuff
Member#: 38345
2004 WRB WRX
read my PM
cubuff is offline   Reply With Quote
Old 09-07-2010, 08:02 PM   #3
MainFrame
Member#: 218739
2002 WRX hybrid
I would go with Kelford, or GSC cams and valve train. Kelford 272s are going to have more lift than BC 280s.
MainFrame is offline   Reply With Quote
Old 09-08-2010, 06:14 PM   #4
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
why do you say stock bottom end then talk about rods and pistons? Ditch the idea about the bc stuff, use kelford or cosworth.
scby rex is offline   Reply With Quote
Old 09-08-2010, 07:23 PM   #5
teiva-boy
Member#: 22825
Find a reliable and trusted builder here on NASIOC. Ask them, they have the right answers. At this point your picking at what sounds cool.
You can also already buy premade short and long blocks that can support this power level. This makes the decision process that much easier. At those power levels, you will have to have you heads worked too IMO.
teiva-boy is offline   Reply With Quote
Old 09-08-2010, 08:40 PM   #6
kenikh
Member#: 212677
1999 Forester S
Bone stock...for now
There is only one spec for an EJ207 w/ that kind of power:
kenikh is offline   Reply With Quote
Old 09-08-2010, 08:44 PM   #7
cubuff
Member#: 38345
2004 WRB WRX
And thats different from a 257 how? Are you speaking with any experience with a 207? The 207 is actually a stronger block than a 257.
Old 09-08-2010, 08:48 PM   #8
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
jigga is offline   Reply With Quote
Old 09-08-2010, 09:01 PM   #9
kenikh
Member#: 212677
1999 Forester S
It's no different, other than you are trying to make power with .5L less displacement. Big power costs money...lots of it, especially with less displacement. The closed deck case is pretty much inconsequential (from the EJ207), because it has nothing to do with the power you make, only with increased margin for reliability once you get there.
Don't even ask me how much I've spent building my 2.3L twin turbo 911 motor. I will say I could have bought a stock 3.3L 930 for less than the motor. If you want to build a "mighty mite" motor, costs go up in a j-curve and the things that can go wrong get amplified exponentially over an equivalent larger displacement motor.
The earlier advice was best: find a builder that has done it, has proven their setup reliable, open your check book, grease up the seat of your pants and say thank you after every check you write.
Old 09-08-2010, 09:17 PM   #10
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Why spend all that money and use POS BC stuff? GSC s1's make more power then the 280's.
Joe@ASFmachine is your man, he is a vendor on here!
project_skyline is offline   Reply With Quote
Old 09-08-2010, 09:54 PM   #11
Prevent
Member#: 149114
V8 207, thats debatable..
Hypercast pistons like the EJ257., blahblahblahblha.
Prevent is offline   Reply With Quote
Old 09-09-2010, 02:17 AM   #12
cubuff
Member#: 38345
2004 WRB WRX
The 207 is a stronger block less the internals. The cylinder sleeves are a considerable amount thicker than the 257.
Old 09-09-2010, 02:27 AM   #13
cubuff
Member#: 38345
2004 WRB WRX
Sure... but, you can say that for any motor that is larger. But doesnt that take some of the meaning out of the hobby? If all the power seeking car guru's all had the same big v8's that would be boring. The point was the cost of making 500-600 hp on an ej207 is really no different than making it on a 257. I would argue that it is the exact same amount. Forged internals and a 35r or bigger. They will make similar numbers with the 257 edging it out slightly.
When I built my 207 the price different wouldnt have been any different to build a 257. I choose the 207 for higher revs and to do something different than my previous 2 257 builds. I have a 600hp ej207, so I am one who has done it.
Would love to see some info on your 2.3 tt porsche. That sounds pretty awesome. Have always been a huge fan of fast porsches.
Old 09-09-2010, 07:25 AM   #14
iana
Member#: 252934
I don't understand the question. One is 20% more than the other???? That's a huge ask.
What do you want to build?
iana is offline   Reply With Quote
Old 09-09-2010, 10:44 AM   #15
kenikh
Member#: 212677
1999 Forester S
Here you go - I haven't updated it in a while, so it still shows the single turbo that is going into my EJ22T project. The 911 will use twin small Garretts.
http://forums.pelicanparts.com/porsc...part-deux.html
This was the same rationale I had with the 911, so let me warn you about what you get into trying to "make more with less". Less displacement means you need to strain parts more, machine to tighter tolerances, run closer to the ragged edge of tune, go for more aggressive came lobes and valve train, lighter internals everywhere, etc, etc...anything in pursuit of decreasing parasitic drag, increasing VE, you name it, in trying to compensate for that lack of displacement.
The 911 motor above? If I'd gone with a 3.3L 930 motor, I could have reached the power numbers I am after with a $5000 used motor and be done with it. Instead, I am building a motor, that in parts and machining alone, would allow the purchase of a WRX STi that is still under factory warranty.
When you go for the edge, costs rapidly spiral into realms one would never imagine. The thing I love about Subaru tuning so much is that you can make so much power for such a cheap pricetag, relative to other cars (e.g. Porsches, BMWs, etc.). If your goal is to build a Ken Block replica, realize that you could pretty much buy anything, so you'd better be committed.
big turbo ej207 build finaly done! cubuff Built Motor Discussion 34 10-11-2009 10:33 AM
What pistons are the best for ej207 build?? Sammidavis Built Motor Discussion 3 02-02-2009 08:19 PM
500-600hp Miata 1.8 long block Georonimo Tri-State Area Private Classifieds 8 12-04-2008 12:36 PM
EJ207 Build Up EJ25I Built Motor Discussion 20 06-16-2007 02:26 PM
Best Transmission for 500-600hp 2.5RS-T ChAi Transmission (AT/MT) & Driveline 17 11-22-2003 03:33 AM
