Old 09-07-2010, 11:04 PM   #1
A1y50n
Member#: 130194
2007 Impreza 2.5i SW
Newport Blue Pearl
Default Installed Stock Intake, car stalls when depressing clutch.
So, after messing with the intake, checking for vacuum leaks, I decided to put on the stock intake to rid myself of this headache.
I made sure to reset the ecu but even with the stock intake, when I depress my clutch while slowing down, it will stall.
After I stop, the engine will idle once I start the car up again.
What gives?
A1y50n is offline   Reply With Quote
Old 09-08-2010, 12:33 AM   #2
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Just let the car idle for at least 15 min. This will relearn idle.
kewlboxer2 is offline   Reply With Quote
Old 09-13-2010, 02:25 AM   #3
A1y50n
Member#: 130194
Newport Blue Pearl
Throttle plate was dirty.... I failed to clean it thoroughly.
It's good now.
High pitch whistling/squeaky sound when depressing clutch halfway FreytheViking Newbies & FAQs 9 05-10-2012 01:16 PM
Scraping noise when depressing clutch pedal/letting off gas rage941 Transmission (AT/MT) & Driveline 2 07-02-2010 10:45 PM
05 2.5rs Stalls when push clutch in if cold & idle question Bamboorex Normally Aspirated Powertrain 9 05-07-2009 01:38 PM
Noise when depressing clutch JJL330 Transmission (AT/MT) & Driveline 2 01-04-2006 04:54 PM
Bump from the rear when depressing clutch - normal? newsman Transmission (AT/MT) & Driveline 2 12-11-2004 03:22 PM
