Old 06-23-2002, 02:52 PM   #1
ohsfan
Member#: 14263
2002 WRX Wagon
Question Attn all Cyclists...OEM bike rack or aftermarket?
I'm planning to buy a bike rack (and bike) in the next few weeks. Just wondering what the pros and cons of each rack were. Which bike attachment do you use and why?
BTW, the bike will not have disc brakes.
Also, is that wind shield (ferring ?) worth the money?
Thanks for your input.
(Hope this is in the right forum.)
ohsfan is offline   Reply With Quote
Old 06-23-2002, 07:14 PM   #2
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Post
I went with the Thule rack. Feet attaches to the factory rails. Also added the fairing and reduced wind noise substantially.
Pics are posted in this forum somewhere.
KwanDDS is offline   Reply With Quote
Old 06-23-2002, 10:42 PM   #3
jesse370
Member#: 12147
2005 g-35
ivory pearl
All through highschool and college I worked at different shops. I wouldn't recomend using any roof rack that attaches via your stock roof rack setup. Most aren't designed to handle the weight and stresses that a rack and a bike can put on it. Yakima has some good racks, saris while a pain in the ass to setup are I think some of the best out right now. And the issue with discs is a moot point unless you run a 30mm front axle like I have on my dh/ds bike I would suggest one that uses a clamp on the downtube instead of taking your front wheel off.
jesse370 is offline   Reply With Quote
Old 06-23-2002, 11:48 PM   #4
ohsfan
Member#: 14263
2002 WRX Wagon
So...are you suggesting an upright mount over a fork mount no matter what type of bike I get or only if I have disc brakes?
Why use an upright vs. fork mounted rack?
Just curious.
OF
Old 06-24-2002, 12:38 AM   #5
Rancid
Member#: 3272
2016 VW Golf R
Hey, I just put my Thule aftermarket rack on. I say go aftermarket, becasue then you can get the wide bars (58" I think...either that or 53...but anyway) With the wide bars, you can mount the bike racks on the outside of the roof and then your wagon trunk can still open all the way. Other bike racks will make your wagon lid only open very slightly. I will take pictures tommrow for ya if ya want. Email me for more info... [email protected]
IAn
Rancid is offline   Reply With Quote
Old 06-24-2002, 01:17 AM   #6
ohsfan
Member#: 14263
2002 WRX Wagon
Ian,
Pictures would be much appreciated. BTW, how much was your whole set up (racks, bars, towers, etc.)?
Thanks.
Old 06-24-2002, 02:33 AM   #7
BurntJamb
Member#: 13538
Default Yakima LowRider
I bought a Yakima LowRider setup for skiing this past season and it worked out well with the stock factory rails. One annoying thing was that the rails were positioned too far from the front, which becomes an issue when you want to open the hatch and the spoiler gets in the way of what you're carrying on top (bike tire, tray, ski, etc.).
With the feet and crossbars and no attachments, I would get a major howling noise above 55 MPH. Attaching the fairing solved that issue. You can probably get one cheap off ebay.
Personally, I'm going for a trailer hitch mounted bike rack solution. Why?
1) more aerodynamic
2) cost is about the same, or less if you need to carry multiple bikes. Trailer hitch for the WRX wagon is around $100, the rack for the hitch is like another $150 or so. The Yakima low rider + two fork mounted bike trays will run around $350. I'd lose the versatility of the yakima, but I can always just carry skis in the back with one seat folded down (and unfortunately one less passenger).
3) it's way more compatible for my bike, a Cannondale Jekyll w/ Lefty fork,. The only viable rooftop solution for me would be the new Yakima Cobra or Sportwork's Bob Ratchet.
BurntJamb is offline   Reply With Quote
Old 06-24-2002, 02:37 AM   #8
iflybyu
Member#: 20292
2002 Impreza WRX
Platinum Silver
Post Yakima w/ disc
I had a Yak rack w/ Viper trays .. and had a bike w/ full disc (Hayes hydros) and had no issue with clearance in mounting. As far as aerodynamics go, a fork mount tray is much better than a downtube system, and much more stable at speed. I would suggest a Yak system w/ the Viper trays - they make clips that attatch directly to the factory rails that looks nice. I would imagine a total setup would be around 120 a piece for trays, 60 for the towers, 50 for the load bars, and 50 for locks. Figure about 40-50 for the fairing too. (get the fairing - big time difference in noise reduction and aerodynamics.
Just my 2 1/2 cents.
iflybyu is offline   Reply With Quote
Old 06-24-2002, 07:03 AM   #9
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Post
I have no problems with clearance of the wing. I cut the tray for a custom fit. PM me if you want pictures.
Old 06-24-2002, 08:35 AM   #10
tsbarro
Member#: 18358
02 WRX Wagon
Midnight black pearl
As with most people replying, I would hands down say go for aftermarket -- way more options and IMO just as stable/strong. Personally I have the thule in which the feet attach to the factory rails.. I would also say to definatly go for the fork mount rack only!! THe downtube mount is much more unstable, more wind resistence, and I think more prone to theft (though, probably not!).. On my thule rack, I've managed to put on 5 bikes when I had to (safely), which you'd never be able to do on the factory rack. As far as disk brakes, its really not a big issue -- I have discs on one of my bikes, and all I did was take a dremel to the Thule tray and cut out the part where the disc would hit it.. It took about 10 minutes and works perfectly.
Ts
tsbarro is offline   Reply With Quote
Old 06-24-2002, 01:37 PM   #11
Rancid
Member#: 3272
2016 VW Golf R
Haha, I didn't know I was gonna sleep in so late today. Here are the pictures in a Yahoo! photo album. My whole set up cost $600 but I also have snowboard racks. The bars are 58" bars, and the fairing was mounted on top of the front bar. It is suppose to be mounted on the bottom, but it wouldn't fit that way. The snowbaord rack comes with spacers, so hopefully they are tall enough to clear the fairing holder thingies. Anymore questions, feel free to ask away. Here's the link:
Roof Rack
Old 06-24-2002, 05:50 PM   #12
True06
Member#: 14139
2002 2.5 RS
Flossin purple
i hope you guys arent those dick heads that ride their "racing bikes" dressed in yellow spandex in the middle of car traffic... if you are i need to let you know how annoying you are while trying to drive and pass you while you take up half the lane going 10 mph.
True06 is offline   Reply With Quote
Old 06-24-2002, 07:03 PM   #13
jesse370
Member#: 12147
2005 g-35
ivory pearl
no your refering to roadies. they suck. I'm buying a roadbike just for the fact that you can scream on one. As far as downtube mounts go. I've used the saris type and it is AS sturdy as a fork mount no question about it. And my bike is a 35lb dh/ds racing bike. I also have no choice because I have a 30mm clamp on front wheel. Its all personal preference. But also about the downtube racks, the thule and yaks that I have seen look cheap and flimsy. The saris on the other hand is thick aluminum with a massive clamp. another perk to the saris is the rails are a wedge shape to cut through the air better. I think they are the best racks on the market but are a pain in the ass to setup!
but don't trust your bikes on the stock rails. I know a few auto companies even say they can't withstand over 40lbs and a certain amount of pressure put on them because of the rack and the drag associated with it. but my experince is from riding over 7 years and working in shops over 5.
Old 06-24-2002, 07:58 PM   #14
alan ling
Member#: 5233
Thumbs up
I had a hidden hitch intalled and bought a hitch style bick rack. The bikes never touch the car so no scratches. You can also lock the rack up better (or so I think). You can carry three on mine. I also bought a ski rack adapter (through Cap-It) which works with the bike rack. It allows you to carry 6 pairs of skis vertically or 2 snowboards. And it too is lockable. Again no scratches to the car and no roof marring incidents. Mountain bikes tend to drop rocks and dirt on your roof. You can also go through drive throughs without knocking your bike off the roof. I think it ended up costing 300 or so. And should I ever want to I could tow a small trailer for the gokart.
alan ling is offline   Reply With Quote
Old 06-24-2002, 08:36 PM   #15
phantasm
Member#: 10008
2002 WR Pearl Blue
Impreza WRX
I went with the OEM package but not primarily for a bicycle although there is a simple attachment for it.
phantasm is offline   Reply With Quote
Old 06-24-2002, 09:40 PM   #16
Asha'man
Member#: 9158
02 WRX Wagon 5spd
Platinum Silver Metallic
Default Trailer Hitch Rack
I have a Yakima GetAway, which slides into a trailer hitch reciever. It locks, is secure and stable, somewhat aerodynamic, and doesn't cause problems with low trees or garage ceilings.
Asha'man is offline   Reply With Quote
Old 06-25-2002, 07:57 PM   #17
Jay2MTB
Member#: 20105
2002 WRX Wagon
hey there man. i have a wrx wagon, and like you...i am a cyclist. i was the assistant manager of a bike shop back in tn, so i have seen plenty of racks and various ways to carry bikes on different cars. on my wagon, i routinely carry 4 bikes, so i needed a strong rack. personally...i went with the yakima rack with the double cross mounts. these mount directly to the stock roof rack rails on your wagon. however, you should only be carrying about 100lbs using this system. your other alternative is to use the yakimi Q-Towers. this style is the type that mounts inside of the door jam. the use of the Q-towers will increase your carrying capacity by 50lbs to a total of 150lbs. personally..i prefer the double cross because there is nothing touching the fragile paint of the wrx. in conjuction with that...i would go with either the steel head, or the viper bike mount from yakima. the steel head is your everyday fork mount system with lockable cores. the viper has a wider tray (better for 26x2.25"tires and bigger) and is shaped in a way that will allow the trays to accomodate the calipers on bikes that are equipped with disc brakes. and with regards to the fairing....on any car carrying bikes with a fork mount system...i recommend using the fairing. usually around 65-75mph most of the racks will whistle, quite annoying. so i recommend you get it all, a set of 8 lock cores, and lock it all onto your rex and take off driving and riding. hope it has all been helpful, and should you have any questions.....lemme know. keep the rubber side down.
Jay Spry
Jay2MTB is offline   Reply With Quote
Old 06-26-2002, 05:30 PM   #18
ohsfan
Member#: 14263
2002 WRX Wagon
Thanks to everyone for their $.02 esp. Jay2MTB! Like Jay, I'll probably end up getting the yakima system (lowrider towers w/the viper mounts). I'll probably end up getting the fairing too! I've had a few buddies recommend this set up as well.
Now the real question is to buy the set up from a bike dealer or over the internet?
Thanks again guys.
OF
Old 07-01-2002, 10:12 PM   #19
MNbiker
Member#: 18148
'08 WRX
Dark Gray
OF,
Thought you might be interested in a picture of my Yakima rack system, as it's pretty much what you're looking to get. I picked up the entire setup from REI for $414 incl. tax. I'm using the Lowrider mounts, Viper trays, 48" bars & 32" fairing. A few things worth noting about this setup.
1. I trimmed approx. 5" off the front bar and 6 1/2" off the back bar, so they wouldn't stick out so far past the mounts.
2. I mounted the bikes backwards, so the trays/wheels wouldn't hit the rear spoiler with the hatch raised. I tried them facing forward with the spoiler removed, but didn't care for the "spoilerless" look.
3. I went with the small 32" fairing, because it fits between the stock rails. It looks beter than using the larger recommended one, and still kills the howling noise from the bars.
MNbiker is offline   Reply With Quote
WTB: BK Legacy OEM Bike Rack MyogiNightKid Private 'Wanted' Classifieds 1 04-01-2009 04:31 PM
OEM bike rack Jonson Newbies & FAQs 5 02-05-2008 06:41 AM
FS: 2002 Service Manuals, OEM Bike Rack, Cross Bars Necromancer North West Impreza Club Forum -- NWIC 0 03-27-2004 10:36 PM
OEM Oil filter??? or aftermarket one? CJK Newbies & FAQs 11 01-30-2003 03:00 PM
('93-'01) OEM racks or aftermarket SnObOaRdEr_X Impreza Forum 3 10-17-2001 11:53 AM
