Old 06-23-2002, 02:57 PM   #1
dallas_wrx_blue
Member#: 16563
1987 Supra MKIII
3" Turboback, MBC
Default Do I have to buy new gaskets for...
an up-pipe or can I use the stock ones. My car has 17.5k miles and was wondering if it would be best to order new gaskets when installing an aftermarket up-pipe. Any help is appreciated.
dallas_wrx_blue is offline   Reply With Quote
Old 06-23-2002, 03:17 PM   #2
tmroreswrx
Member#: 17053
2002 imperza
blue
yes get new gaskets it might be o.k. with out but you really don't want to find out. do it right the first time. and tighten from bottom to top.
tmroreswrx is offline   Reply With Quote
Old 06-23-2002, 04:02 PM   #3
dallas_wrx_blue
Member#: 16563
1987 Supra MKIII
3" Turboback, MBC
thanks for the reply!
Old 06-23-2002, 04:34 PM   #4
gryphon
Member#: 11807
I re-used my stock gaskets and I have a leak. I don't know if it is BECAUSE of those gaskets or my incompetency (no comments please )
gryphon is offline   Reply With Quote
Old 06-23-2002, 06:07 PM   #5
relayer66
Member#: 14614
Platinum Silver
you really should get new gaskets for both sides of uppipe, the turbo-downpipe gasket and also exhaust manifolds. i did that and used vishnu's instructions, and have no leaks.
relayer66 is offline   Reply With Quote
Old 07-07-2002, 10:04 PM   #6
Zeorymer
Member#: 14086
2000 Impreza RS
While on the topic of gaskets...
Is the only thing the gasket does, is keep the exhuast from leaking? It serves no other purpose, correct?
Thanks for the help,
Zeorymer is offline   Reply With Quote
Old 07-08-2002, 12:04 PM   #7
fueledbymetal
Member#: 14425
2002 WRX Sedan
SOLD!
Correct. It's made with a deformable material that will act as a seal between the joined piping pieces. When you swicth parts, like the upipe, a new gasket is important because the old gasket is already deformed to the surface of the old pipe.
fueledbymetal is offline   Reply With Quote
Old 07-08-2002, 12:10 PM   #8
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
i would buy a couple of them i used 3 on my godspeed uppipe, because of leaks.
MAXXPSI is offline   Reply With Quote
Old 07-08-2002, 03:53 PM   #9
Austin
Member#: 7089
2016 STi
Yes, get new gaskets.
Austin is offline   Reply With Quote
Old 07-08-2002, 04:01 PM   #10
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Uhhh, it's a four-layer steel gasket with a fire ring. When I ordered mine at the dealership, the parts guy thought I was nuts for replacing them. I explained what I was doing, and he said, "We reuse them all the time unless they have physical damage, they are designed to be reused." That's also been my experience with every other multi-layer steel gasket for flat surfaces, such as the gaskets on my nissan.
I don't disagree with buying new ones, but frankly, I wouldn't consider it mandatory.
Conduit is offline   Reply With Quote
Old 07-08-2002, 04:56 PM   #11
Nutter
Member#: 7185
2015 FoST
Oxford White
Anyone have part # and cost for these ?
Nutter is offline   Reply With Quote
Old 07-08-2002, 05:03 PM   #12
Conduit
Member#: 6162
Search under my name, the part numbers are all there from my previous inquiry
Old 07-08-2002, 05:13 PM   #13
Nutter
Member#: 7185
2015 FoST
Oxford White
Thumbs up thanks !
Thanks
for anyone else look H E R E
Old 07-08-2002, 07:44 PM   #14
fueledbymetal
Member#: 14425
2002 WRX Sedan
SOLD!
When just disassembling/reassembling the same set of pipes, reusing gaskets isn't such a big deal. But if you're switching pipes and the differences in imperfections between the pipes you're exchanging are severe enough, there will be a problem. If anything, consider it a cheap insurance policy (an extra $20 spent on a $200-$300 part plus labor is cheap )
Best place to buy new gaskets and bolts for Helix Downpipe? STiMUL8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-31-2006 07:46 AM
How many people do you have to buy xmas gifts for? stuttgart Off-Topic 19 12-17-2005 06:02 PM
my ej257 has 3k miles on it....do i have to get it bored for new pistons White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-15-2005 03:49 PM
Do you have to buy 1942 expansion packs? m750 Off-Topic 9 11-15-2003 05:20 PM
Catback exhaust. if its catback do you have to buy a mid pipe?? Confused Keith Technical Forum Archive 11 05-27-2000 09:57 AM
