Old 09-08-2010, 05:06 PM   #1
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Default Oil pump and bearing clearance recommendations for EJ20 build
After a few days of searching and reading. I haven't been able to find much information on some recommendations for specs on a EJ20 build.
I spun a bearing in my engine after 105k miles on a high RPM pull, so building to avoid that is I suppose part of the paranoia.
With that said, Will the 11mm pump work with the EJ20 block? The goal for the engine is eventually around 310whp and maintaining the stock redline. My plan was to use the 11mm pump and run on the loose side of the stock specs of bearing clearances, however, someone with more insight that could give me more concrete numbers would be a huge help.
Final thought, is it true that the 04 and up crank has better oiling than the earlier production models?
Thanks in advance for any help.
340Duster is offline   Reply With Quote
Old 09-08-2010, 05:07 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
what oil were you using when your engine expired?
jigga is offline   Reply With Quote
Old 09-08-2010, 05:10 PM   #3
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Rotella 5-40w, It was in a 5th gear pull up to about 5k, kinda lost power so I killed it and had it towed home the next day. I haven't had the time to pull the engine yet, only about half way there. It is/was running on a new tune at about 19psi in 4th-5th.
Old 09-08-2010, 08:35 PM   #4
xstock
Member#: 109654
I just posted a similar question in the 2.0 turbo section.
Are the new EJ205 blocks built 'better' than the ones from 2002?
I too was doing a high RPM pull and pooched the bearings and if I rebuild that thing or buy a new EJ205 I'd prefer to not have that happen again.
I was running Mobil 1 5W/30 so you were a lot smarter than I was.
Hopefully someone can answer this.
xstock is offline   Reply With Quote
Old 09-08-2010, 08:44 PM   #5
kenikh
Member#: 212677
1999 Forester S
Bone stock...for now
Pin your case. High RPM and high power on an opposed cylinder motor makes the mains walk, causing the bearing to spin. Pinning the case keeps the mains aligned.
kenikh is offline   Reply With Quote
Old 09-09-2010, 01:03 PM   #6
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
No insight in changes in the crank from 02 to 05? Or if the 11mm pump will work with the EJ20 case?
oil pump or bearing? 93SubieImpreza Normally Aspirated Powertrain 10 07-07-2010 08:06 PM
OEM oil pump and OEM water pump jblaine Engine/Power/Exhaust 0 12-27-2006 11:12 AM
What oil pump and water pump for Spec C EJ207? moss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-27-2006 01:06 PM
will a WRX oil pump and water pump RollingOnAll4 Subaru Conversions 7 02-20-2006 12:58 AM
Looking for Help doing Oil pump and timing belt yebokmj New England Impreza Club Forum -- NESIC 4 07-21-2002 04:35 PM
