Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-08-2010, 11:45 PM   #1
SnowgodCCR
Member#: 256968
2008 STi
Red
Default PIAA vs. Hella lighting
Will a 5" driving light fit into the USDM stock fog bezel?
I'm wanting to upgrade the (now) fogs on my '02 WRX, but I'm torn between PIAA and Hella. I do about 2 hours of driving every day in the dark, and would really like more light, but I'm not ready to commit to a light bar yet.
If I went with Hellas, it would be their Rallye 4000 model with the "Eurobeam" pattern (or maybe the "cornering" beam).
If I go with the PIAAs, it would be the 540 series with the driving beam.
SnowgodCCR is offline   Reply With Quote
Old 09-09-2010, 12:11 AM   #2
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Hella FF500's will fit. Get them with the clear driving lenses, a set of amber bulbs, and a pair of the clear stone-guard covers and you're all set.
I like both Hella and PIAA, but PIAA's are usually very expensive, both initially and if you need replacement parts.
Old 09-09-2010, 01:39 AM   #3
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
I've got four hella 500ff on a light bar on the front of the car, and two piaa 540 fogs in JDM fog bezels. I can tell you that the output on the piaa is much better than the hella 500ff (can't speak for the rallye 4000, though). The piaas are brighter and have a more even spread and a sharper cut off. Plus the lamp itself is just constructed better. The piaas are made of metal, where the hellas are made of cheap plastic. Hellas will get the job done, but if you can afford piaas, go with them.
OUScooby is offline   Reply With Quote
Old 09-09-2010, 09:11 AM   #4
SnowgodCCR
Member#: 256968
2008 STi
Red
I think I'm pretty settled on the PIAA 540s, they come ou cheaper than the Hella rallye 4000s after you buy two R4000s, the harness, and stone guards...
They should fit in my USDM housings with the kartboy brackets, right?
Old 09-09-2010, 06:06 PM   #5
cantseejack
Member#: 225097
Does any know, between the Rallye 4000 Halogens and the PIAA 540s, which are brighter?
cantseejack is offline   Reply With Quote
Old 10-29-2010, 03:39 AM   #6
japanesestar
Member#: 212037
2005 wrx sedan
black
I had a set of Hella rallye 4000's on my old cherokee (that I am considering mounting on my 05 wrx) and I loved them. They were the euro beam and had great coverage and distance. The only drawback is the size. The housings are aluminum and they can be aimed without the use of tools. My father has had two sets of PIAAs that have rusted pretty bad..Not to fault the performance of the light itself though..that was pretty good. I ran 55w halogens in them and were excellent, however, with how inexpensive HID's are, I would love to see some 3500-4000k bulbs in them!!! If I do it I will post it!!
japanesestar is offline   Reply With Quote
02-03 Impreza Fog Light Options... PIAA or Hella... Opinions needed! chrisarella Electrical & Lighting 37 10-31-2008 02:54 AM
PIAA or Hella? mangoman Interior & Exterior Modification 3 12-23-2005 08:10 PM
piaa or hella? xsmooth69x Electrical & Lighting 19 11-09-2005 10:02 PM
PIAA or Hella Headlights for 2001(UK)+ WRX Zahnster Interior & Exterior Modification 6 01-25-2002 09:40 AM
PIAA vs Hella... reardonb Interior & Exterior Modification 5 12-13-2001 04:07 AM
