Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 09-08-2010, 10:57 PM   #1
Fmjhp594
Member#: 120743
2006 WRX STI
Question How do I remove house paint from my car?
I picked up a used miata last week. Theres a decent amount of splatter/spray and lines of house paint on the passenger side of the car. Massive amounts under the car and in the wheel wells, but I don't care about those areas. Its from when the old owner drove through a puddle of wet house paint.... at speed... 'a few years ago'....
I tried using some rubbing compound on a few of the smaller splatter marks, it worked with a lot of time and effort. I also tried using a clay bar, that did nothing. The paint is thick, its not feasible to use rubbing compound to get all of it off. I was thinking of trying goof-off, but I'm afraid it might etch the clear coat or something.
Anyone have any ideas or suggestions? Or perhaps first hand experience of what did or didn't work?
Thanks!
Mike
Fmjhp594 is offline   Reply With Quote
Old 09-08-2010, 11:44 PM   #2
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Goo gone?
I bet the paint is oil based...
Smoke is offline   Reply With Quote
Old 09-08-2010, 11:53 PM   #3
Fmjhp594
Member#: 120743
2006 WRX STI
Do we know if goo-gone is safe for the clear coat?
I dont want to find out the hard way that it will take off the house paint and the clear coat....
I understand the wax will be removed, but I plan on waxing it right after getting the tan house paint off of the silver car.
Old 09-08-2010, 11:54 PM   #4
kbobomber89
Member#: 231418
2006 WRX
depending on the paint...try acetone. or thinner. if those dont work....wet sand buff it =/
kbobomber89 is offline   Reply With Quote
Old 09-09-2010, 12:01 AM   #5
Fmjhp594
Member#: 120743
2006 WRX STI
Acetone... hmm got plenty of that in the garage...
I'll try putting some of that on a rag and rubbing the paint off tomorrow. See if that works...
Old 09-09-2010, 02:20 AM   #6
Void16
Member#: 200954
Generally when I see people that have swapped paint due to running into something or bumpers colliding it can be buffed off.
Find a friend or a local detailer that can buff it for you.
Void16 is offline   Reply With Quote
Old 09-09-2010, 02:42 AM   #7
cristianosREX
Member#: 231701
03 wrx
sonic yella
if you're going to use "goof-off" be careful not to rub to hard/much, let it sit/soak or over saturate the rag. Just use caution and wash the area right after you're finished.
cristianosREX is offline   Reply With Quote
Old 09-12-2010, 07:33 PM   #8
Fmjhp594
Member#: 120743
2006 WRX STI
Well just for an update, acetone and goof-off didn't work. Goof-off would, but you had to soak small areas for over five minutes and then rub like no tomorrow... not time effective at all...
I was able to get it off using an 'eraser wheel' from a body shop. I had one from a previous adventure and figured I'd give it a try... It worked wonders.
Sprayed my stockers black, how do u remove the paint? JustAnotherSubie Interior & Exterior Modification 32 03-06-2009 05:21 PM
how to remove House Paint sprinkled on car???... mjd85la Car Care & Detailing 23 04-11-2008 09:20 AM
How do I remove the clock from the center pod housing the clock? impRSa Electrical & Lighting 3 03-30-2005 11:25 AM
How to remove garage paint form my car? Pre-diddy Interior & Exterior Modification 1 03-26-2005 10:37 AM
how do i remove bad smell from a car? MaxPower Off-Topic 24 10-07-2003 06:12 PM
