Old 09-09-2010, 12:18 AM   #1
meo
Member#: 206936
06' STI WRB
15' STI 09' GTR 1300whp
Default Which gaskets?,2010 sti short block with 04 wrx heads
so im putting a 25 shortblock in my car 04 wrx heads Just wondering what you guys think are the best choice of head gaskets? and what size as welll
I would like to use cosworth but i was told 60mm would be the best, however cosworth does not make 60mm
meo is offline   Reply With Quote
Old 09-09-2010, 09:43 AM   #2
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Well you have a few options.
first is use a OEM sti hasket. Your comp will be high.
next is to use a 0.051 cometic head gasket to bring the comp down to about 8.5-1
The best thing to do is have the combustion chamber on you cylinder heads to 2.5 bore spec. This is the best option but also costs the most...
rexworx is offline   Reply With Quote
Old 09-09-2010, 08:45 PM   #3
TRDRacer
Member#: 212793
2003 Built 2.5L 35R
World Rally Blue
Cometics have no firering on there gaskets which is why many have problems blowing them up! Cosworth would be close to the 1.1mm which would give you a closer ratio as a real STI but then you run a chance of poping them cause they are so thich.
If you look up under my name I have a post that states what gaskets to use on a simial motor and a link to a compression calculator to get you the right thickness!
TRDRacer is offline   Reply With Quote
Old 09-10-2010, 01:51 AM   #4
Strider327
Member#: 131280
2004 Impreza WRX
The one you want is the 20000916 part number from Cosworth. DO NOT Cometic.
Strider327 is offline   Reply With Quote
Old 09-13-2010, 04:35 PM   #5
meo
Member#: 206936
06' STI WRB
why not go cometic? can anyone comment on this?
Old 09-13-2010, 04:51 PM   #6
meo
Member#: 206936
06' STI WRB
im pretty sure im gonna go .80 cometic... i think 1.1 will be over kill
Old 09-13-2010, 11:47 PM   #7
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Just do the 1996-1998 2.5 DOHC oem head gasket..it's thicker than the STI & will help keep the comp down...DO NOT USE THE COMETIC......YOU HAVE BEEN WARNED
sense of nature is offline   Reply With Quote
V7 STI block with 04 WRX heads = Emsission friendly? ilgdrummer Subaru Conversions 2 07-30-2008 06:58 PM
V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? saab-on-the-cobb Subaru Conversions 6 09-18-2006 07:03 PM
usdm sti short block with head gaskets sjs41379 Private 'For Sale' Classifieds 8 08-06-2005 10:20 PM
STi short block with Phase II 2.5RS heads? WRC1 Subaru Conversions 8 01-23-2005 12:20 AM
04 sti short block with 02 heads? wrxtuner02 Subaru Conversions 13 11-26-2003 08:38 PM
