Old 09-14-2010, 05:34 PM   #1
RoadTrippin
Member#: 161175
Default Grinding at Idle?
At idle (and even during acceleration) there is loud grinding noise coming from under the hood. At first I thought the bearings in the alternator were shot or on their way out but the alt is charging fine and after putting on a different alternator the grinding was still there. I thought power steering pump but turning it by hand didnt produce any grinding and running the a/c also made no difference.
Ideas?
It's not heat shield grind, it def. sounds more like a bearing on something going out grinding.
RoadTrippin is offline   Reply With Quote
Old 09-14-2010, 05:41 PM   #2
Xclusive
Member#: 225704
2010 Impreza 2.5i
Timing belt idler? That's what happened to me. Then it blew up.
Xclusive is offline   Reply With Quote
Old 09-14-2010, 05:44 PM   #3
RoadTrippin
Member#: 161175
Assuming that's the culprit how common is it for those to go bad?
Car has 161k, timing belt service was done at 105k
Old 09-14-2010, 06:35 PM   #4
renyo
Member#: 93577
98 Impreza
Could be the AC idler or AC pulley itself. Both of those were bad on mine. I couldn't hear either by turning the engine by hand, but when the belt was off and I turned the AC pulley, I could hear the grinding/whining noise. Same thing with the tensioner, although it was easier to tell it was bad than the pulley.
renyo is offline   Reply With Quote
Old 09-14-2010, 06:50 PM   #5
RoadTrippin
Member#: 161175
How would I go about checking the idler pulley just to be sure? There are no metal shavings in the oil so I am somewhat certain it may not be a timing belt issue vs an idler pulley issue.
steering grinding especially when turning at idle Sir Punk Brakes, Steering & Suspension 10 04-13-2010 11:24 AM
very rough idle lean afr's at idle TDagen Open Source Reflashes 8 07-07-2008 04:28 PM
Grinding Noise at Idle on a 04 STi ! viaburn26 Transmission (AT/MT) & Driveline 2 04-23-2008 03:34 AM
Clutch/gear grinding noise at idle? rhinotech Transmission (AT/MT) & Driveline 0 12-13-2007 04:27 PM
My idle speed is inconsistent at Idle, is this normal? LisaPhish Legacy Forum 17 07-15-2003 02:01 AM
