Old 09-09-2010, 03:41 AM   #1
ryanx
Member#: 252646
2002 stage2 wrx
aspen white
Default scratches on drivers and passenger window
ok so a couple weeks ago i noticed that my drivers side window had two vertical bars on small scratches and my passenger side front window has the same thing but not as bad
my question is what could be causing this and is there any way to get the scratches out without actually buying a brand new window?
ryanx is offline   Reply With Quote
Old 09-09-2010, 04:23 AM   #2
AutoAesthetica
Member#: 246785
Ryanx I just sent you a bit of info on an option.
The problem with glass is its so incredibly hard that you need something even harder to polish out light marks. There are specific chemicals for this in the oxide family. Its time consuming compared to quickie fixes but its worth it otherwise.
AutoAesthetica is offline   Reply With Quote
Old 09-09-2010, 02:29 PM   #3
ryanx
Member#: 252646
2002 stage2 wrx
aspen white
does any one know what could be causing this? it looks like its caused by something scratching it when i roll it up and down
Old 09-09-2010, 02:38 PM   #4
RaineMan
Member#: 256727
2007 2.5I Wagon
It could be something as simple as a rock chip or speck of dust caught in the window seal. Try getting some canned air and spraying around the seals, might dislodge it.
The last car I owned had horrible scratches on the headlights and glass all the way around because the numbnut former owner took it through a crappy car wash with brushes.
RaineMan is offline   Reply With Quote
Old 09-09-2010, 03:34 PM   #5
AutoAesthetica
Member#: 246785
Are you sure its scratches? Sometimes I get it on my windows but its just a lil grime that is probably stuck on the inside of the exterior window rubber. I panicked one time thinking it was a scratch but it was just some oily substance on the outside.
If its truly light scratches it means you probably have a tiny pebble or some type of grit lodged in the seal where the window slides up and down. You could try clean them with a pipe cleaner or something small and similar.
Old 09-09-2010, 03:51 PM   #6
kylea1
Member#: 255452
2002 PSM wrx
2016 WRBP STI
i have the same issue what were the details you sent to the OP about removing them?
kylea1 is offline   Reply With Quote
Old 09-09-2010, 03:55 PM   #7
ryanx
Member#: 252646
2002 stage2 wrx
aspen white
ill try to take some pictures in a little bit
its in the same two places on both front windows
Old 09-09-2010, 03:56 PM   #8
RaineMan
Member#: 256727
2007 2.5I Wagon
same place on both windows? sounds like something inside the door with the power window mechanism itself
Old 09-09-2010, 04:12 PM   #9
AutoAesthetica
Member#: 246785
Yea now it does. How long had you had the car before you started noticing these?
Old 09-09-2010, 04:45 PM   #10
ryanx
Member#: 252646
2002 stage2 wrx
aspen white
uhh well i didnt notice it until i got my windows tinted about a month ago and ive only had the car for a couple months if that
edit: i found this really old thread that seems to be about my problem but it doesnt really say how to correct it...
http://forums.nasioc.com/forums/showthread.php?t=51684
Old 09-17-2010, 06:41 AM   #11
pr0d1gy ice
Member#: 220876
2007 WRX STI
i have the same problem... was just going to replace my windows. my rear has to be replaced because the antenna and the defroster were destroyed by the previous owner/tint person
pr0d1gy ice is offline   Reply With Quote
Old 09-17-2010, 09:40 AM   #12
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
I had these on my Forester and I took it into the dealer to fix since I was within the 36k miles warranty. Most likely the window has become misaligned with the rollers, that's why there are vertical marks in the glass. It's only on the glass facing outside, correct? My dealer took apart the door trim, realigned the glass, and greased the rollers. I haven't had any new marks appear since then, but there are still scratches in the glass near the top of the window before the repair was performed.
I keep my windows rolled up as much as I can, so I don't notice the scratches.
yuephoria is online now   Reply With Quote
Old 09-17-2010, 10:37 AM   #13
J03
Member#: 256378
2011 WRX
I had a decently deep scratch on my passenger side window on my bmw. Up until then, it was the first time I have ever seen anything like that happen. Never happened with any of my other cars.
J03 is offline   Reply With Quote
Old 09-21-2010, 08:57 AM   #14
Vew
Member#: 74229
2004 PSM WRX
It's just caused by dirt and debris getting stuck between the rollers and your window. Over time it will eventually put an etch into your window since it's acting like sandpaper. Mine are deep enough to be felt with a finger nail.
What you can try which I highly doubt will get rid of it depending on how deep yours are is to use a glass polish with an buffer equipped with glass cutting pads.
Vew is offline   Reply With Quote
Old 09-27-2010, 08:54 PM   #15
psm05sti
Member#: 249075
i have the same problem.. inside the door there is a vertical bar pressing the window from the outside in, now where the bar makes contact with the window theres a piece of felt that lets the windlow slide on.. that felt may have been distorted.. i was able to find that much but havent gotten around fixing the felt yet. and the scratches on the glass is the reason i searched for this thread.. now can someone tell me where i can get this glass polish?
psm05sti is offline   Reply With Quote
Old 09-29-2010, 04:15 AM   #16
ctrent86
Member#: 129199
The issue is there are some felt scrubbers in the door that rub on the windows in those locations. Over time with dirty windows these scrubbers become dirty and need to be cleaned (taking door panel off and hit them with some APC and you are good to go)
ctrent86 is offline   Reply With Quote
Old 09-29-2010, 10:52 AM   #17
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....a kit like this might be a better bet for you. It includes leveling disks and the product needed to help correct blemishes in glass. The only issue is that it appears you need a rotary or DA to use the supplied backing plate:
http://www.diamondite.com/diamondite...epair-kit.html
With a little digging, I'm sure you can find other kits out there that attach to a drill, etc. You can also research cerium oxide but I think I would stick with a kit for simplicity sake.
Kean is offline   Reply With Quote
FS : (IL) '05 STI Driver and Passenger Window Glass nsx2tall Exterior/Styling 1 11-22-2010 10:59 PM
FS: Driver and Passenger Window Regulators dunk MAIC Private Classifieds 0 10-12-2008 08:24 PM
Pig Sticker on driver and passenger door. What company? Gjrizz0 Newbies & FAQs 7 10-03-2008 10:12 AM
WTB: Driver & Passenger window glass idkew Private 'Wanted' Classifieds 6 04-04-2006 12:48 PM
Help! Window guides in both driver and passenger sides are scratching the windows! Michael General Forum Archive 7 03-16-2001 09:23 AM
