Old 09-09-2010, 05:08 PM   #1
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Default 98 Forester issues - CEL codes
Hey guys my forester has been stumbling and stalling qiute a bit, sometimes it doesnt even want to start and others you won't be able to tell there is a problem.
Its throwing a starter circuit code, p0102 MAF low voltage, and a rear 02 sensor code.
I swapped out mafs and the problem wasn't fixed. My questions is it possible for an 02 sensor thats messed up to make the car sometimes not run? Could it be a grounding issue?
If anyone has some insight or advice, please let me know.
007WRX is offline   Reply With Quote
Old 09-13-2010, 04:51 PM   #2
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
No one has any hints? Is it really possible for an 02 sensor to cause the car to stall out and not want to fire up after for a while?
Old 09-14-2010, 12:53 AM   #3
Inane Cathode
Member#: 257508
Hmm, sounds like it could be a voltage thing, if those problems are connected. Did you say it still threw the maf code after you switched maf's?
Something to try is a voltage drop test, put your meter (if you have a meter, that is) on the engine block, and the negative battery post (the post, not the clamp or any other battery wires). Set the meter to volts, and have someone start the car while you watch the meter. There shouldnt really be any voltage shown on the meter, nothing more than half a volt or so. This is a way to see if any voltage is 'trying' to leave the block, but can't for some reason.
Have you checked charging voltages, and given the motor a good once around to check for corrosion on connectors, and specifically ground points?
Post back up if you're still having issues, i can look at my diagrams and see if those sensors share grounds (i know the o2 sensor doesnt, that's a weird one but its one of the more 'sensitive' codes, i'd ignore it for now)
Inane Cathode is offline   Reply With Quote
Old 10-21-2010, 04:59 PM   #4
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
I got my hands on a set of new/used 02 sensors that I still need to put in, so I'll try that. You think it could be a grounding issue?
The previous owner used it as a ski vehicle, so salts and such probably couldve gotten in there.
The maf I tried wasn't brand new, but it was a friends that he said worked. The likely hood of using two messed up mafs is pretty low.
Old 10-21-2010, 05:15 PM   #5
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Also, I got stuck so I unlplugged the maf to put it in limp mode, and it fired right up.
TONS of CEL codes, no CEL... jagman Open Source Reflashes 4 06-17-2010 10:41 AM
Major Issues 2.2 Only Running On 2 Cylinders After I Cleared Cel Codes (iacv) bcustom561 Service & Maintenance 2 05-20-2010 08:17 PM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 09:43 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
98 Forester, tire rubbing. Possible strut from a non-forester? (pics) thrdeye Forester Forum 1 01-04-2005 10:42 AM
